system
December 3, 2011, 10:15pm
1
Hello everybody,
I have a problem with the bootloader of my nano. So I want burn the bootloader on this with the help of my second arduino nano.
Then the problem starts...
When I have tried to burn the bootloader the IDE says to me :
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
I have tried to change this line:
atmega328.upload.protocol=stk500
on this:
atmega328.upload.protocol=arduino
but that doesn't resolve the problem...
I need your help !
Thanks !
NB I have yet connect a 120 Ohm resistor on the 5V pin and Reset pin
MarkT
December 5, 2011, 1:30pm
2
Check what the actual chip on your Nano is, and check in boards.txt to see you have a setting that's right for it?
system
December 5, 2011, 5:29pm
3
model of my Nano chip: MEGA328P AU 1134
my boards.txt:
atmega328.name=Arduino Duemilanove or Nano w/ ATmega328
atmega328.upload.maximum_size=30720
atmega328.upload.speed=57600
atmega328.bootloader.low_fuses=0xFF
atmega328.bootloader.high_fuses=0xDA
atmega328.bootloader.extended_fuses=0x05
atmega328.bootloader.path=atmega
atmega328.bootloader.file=ATmegaBOOT_168_atmega328.hex
atmega328.bootloader.unlock_bits=0x3F
atmega328.bootloader.lock_bits=0x0F
atmega328.build.mcu=atmega328p
atmega328.build.f_cpu=16000000L
atmega328.build.core=arduino
Thanks for your help !
Have you an explication ?
MarkT
December 5, 2011, 6:02pm
4
Does avrdude say what the signature it actually read is? An 328P should have signature bytes 1E,95,0F. The situation is confusing because when you program a bootloader (using Arduino as ISP?) the Arduino software has to be set to the correct hardware, but when using the bootloader to upload code the signature bytes have to match the one's compiled into the bootloader (I've had trouble with the 168 and 168p before - don't this is your issue though).
The chip should be reporting signature 1E,95,0F, and the avrdude should have target set to atmega328p (and thus expecting 1E,95,0F). More output from avrdude should confirm. Might just be dodgy connections between the Arduino as ISP and the target Arduino.
You have programmed the first Arduino with ArduinoISP?
system
December 5, 2011, 6:20pm
5
No, it's my first tried to burn a bootloader on an Nano. But yes i am using a Arduino (my other Nano) as ISP.
I have check many time the connections between the two nano, but they are all ok =/
i have connected the 10pin on reset pin, 13pin on 13pin, 12pin on 12pin, 11pin on 11pin, 5V on 5V and GND on GND
So why this problem ? =/
MarkT
December 5, 2011, 6:24pm
6
Can avrdude tell you anything more? verbose options perhaps?
system
December 5, 2011, 6:26pm
7
I am using the avrdude into the IDE arduino. And no he say me nothing more =/
MarkT
December 6, 2011, 12:29am
8
Had a delve around in the code, try "upload.verbose=true" in your preferences file?
system
December 6, 2011, 11:47am
9
Where need I put this line ? Which file ? Thanks !
MarkT
December 6, 2011, 2:34pm
10
preferences.txt - depends which OS where it lives, ~/.arduino/preferences.txt on Linux... Try searching for the filename, that's how things get found...
system
December 6, 2011, 4:20pm
11
It's more beautiful !
C:\Users\Marie-Joëlle\Downloads\arduino-0023\arduino-0023\hardware/tools/avr/bin/avrdude -CC:\Users\Marie-Joëlle\Downloads\arduino-0023\arduino-0023\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM8 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
System wide configuration file is "C:\Users\Marie-Joëlle\Downloads\arduino-0023\arduino-0023\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM8
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: Recv:
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: A [41] . [81] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: A [41] . [82] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: A [41] . [98] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
avrdude: Send: A [41] . [84] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: A [41] . [85] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: A [41] . [86] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: A [41] . [87] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: A [41] . [89] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: P [50] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75] [20]
avrdude: Recv:
################################################## | 100% 0.05s
avrdude: Device signature = 0x000000
this check.
avrdude: Send: Q [51] [20]
avrdude: Recv:
avrdude: Recv:
avrdude done. Thank you.
So you now why I have a problem ?
Thanks so much !
MarkT
December 6, 2011, 4:21pm
12
MISO is shorted to ground perhaps? Its reading all zeroes.
system
December 6, 2011, 4:27pm
13
I have re-check but no =/
system
December 6, 2011, 4:57pm
14
I have re-tried to use mega as ISP but that make more problem...
C:\Users\Jean-Baptiste\Dropbox\PPE 2011-2012\programmation\arduino-0023\hardware/tools/avr/bin/avrdude -CC:\Users\Jean-Baptiste\Dropbox\PPE 2011-2012\programmation\arduino-0023\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM145 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
System wide configuration file is "C:\Users\Jean-Baptiste\Dropbox\PPE 2011-2012\programmation\arduino-0023\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM145
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: Recv:
avrdude: Recv:
system
December 6, 2011, 5:23pm
15
I have re-tried to make the connections between my two nano, same problem:
C:\Users\Jean-Baptiste\Dropbox\PPE 2011-2012\programmation\arduino-0023\hardware/tools/avr/bin/avrdude -CC:\Users\Jean-Baptiste\Dropbox\PPE 2011-2012\programmation\arduino-0023\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM146 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
Using Port : \\.\COM146
avrdude: Recv:
avrdude: Recv:
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
Hardware Version: 2
Topcard : Unknown
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
################################################## | 100% 0.03s
this check.
avrdude: Recv:
avrdude: Recv:
