Hello,
I'm still pretty new to the Arduino scene, and I'm not much of a coding person.
I found this code online and I tried uploading it but I keep getting this error, and I haven't the slightest as to what it means.
Any assistance would be greatly appreciated (:
This is the code:
#include <Moodlamp.h> //this is a custom library I made you will need to download and install it
Moodlamp lamp; //declare the lamp
// Define colour sensor LED pins
int ledArray[] = {2, 3, 4};
void setColour(int colour);
void setPulse(int pulse);
// boolean to know if the balance has been set
boolean balanceSet = false;
//place holders for colour detected
int red = 0;
int green = 0;
int blue = 0;
//floats to hold colour arrays
float colourArray[] = {0, 0, 0};
float whiteArray[] = {0, 0, 0};
float blackArray[] = {0, 0, 0};
//place holder for average
int avgRead;
//setup the outputs for the colour sensor
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
//begin serial communication
checkBalance();
checkColour();
printColour();
setColour();
getReading(5);
void checkBalance() {
//check if the balance has been set, if not, set it
if (balanceSet == false) {
setBalance();
void setBalance() {
//set white balance
//the pulses are warning lights, to tell you to make sure the sensor is sitting over a white sample
lamp.pulse(255, 0, 0, 2, 2, 100); //pulse red
lamp.pulse(255, 255, 255, 1, 1, 10); //pulse white
delay(2000); //delay for two seconds, lights full on
//scan the white sample.
//go through each light, get a reading, set the base reading for each colour red, green, and blue to the white array
for (int i = 0; i <= 2; i++) {
digitalWrite(ledArray*, HIGH);*
- delay(100);*
- getReading(5); //number is the number of scans to take for average, this whole function is redundant, one reading works just as well.*
_ whiteArray = avgRead;_
_ digitalWrite(ledArray*, LOW);
delay(100);
//done scanning white, now it will pulse blue to tell you that it is time for the black (or grey) sample.
//If you are using the sensor for a different application you may want to use a true black, in which case the sensor returns a truer colour*
* //With a grey sample, what we are doing is tricking the sensor into thinking that colours are a bit darker than they actually are*
* //which is perfect when we are trying to mimic the colour with light*
* //this first quick pulse is just to say that white has been scanned, I like visual indicators*
* lamp.pulse(255, 255, 255, 2, 2, 10);
//set black balance*
* //pulse blue*
* lamp.pulse(0, 0, 255, 2, 2, 100);
//pulse white*
* lamp.pulse(255, 255, 255, 1, 1, 10);
delay(2000); //wait for slowpokes*
* //go ahead and scan, sets the colour values for red, green, and blue when exposed to black*
* for (int i = 0; i <= 2; i++) {
digitalWrite(ledArray, HIGH);
delay(100);
getReading(10);
blackArray = avgRead;
//blackArray = analogRead(2);
digitalWrite(ledArray, LOW);
delay(100);
//pulse to say done black scan*
//quick little animation cycle through the colours to show readiness*
* lamp.getColour(255, 0, 0);
delay(200);
lamp.getColour(0, 255, 0);
delay(200);
lamp.getColour(0, 0, 255);
delay(200);
lamp.pulse(255, 255, 255, 2, 1, 10);
//done blinking and whatnot turn lamp off*
* lamp.getColour(0, 0, 0);
delay(100);
//set boolean value so we know that balance is set*
* balanceSet = true;
//print the balance so you can see it*
* //printBalance();
void checkColour() {
digitalWrite(ledArray, HIGH); //turn or the LED, red, green or blue depending which iteration*
* delay(100); //delay to allow CdS to stabalize, they are slow*
* getReading(10); //take a reading however many times*
colourArray = avgRead; //set the current colour in the array to the average reading
float greyDiff = whiteArray - blackArray*; //the highest possible return minus the lowest returns the area for values in between*
colourArray = (colourArray - blackArray) / (greyDiff) * 255; //the reading returned minus the lowest value divided by the possible range multiplied by 255 will give us a value roughly between 0-255 representing the value for the current reflectivity(for the colour it is exposed to) of what is being scanned_
_ digitalWrite(ledArray*, LOW); //turn off the current LED*
* delay(100);
void setColour() {
//the math isn't perfect, and sometimes will return higher than 255 or lower than zero so we just fix the numbers before lighting the moodlamp*
if (colourArray > 255) {
colourArray = 255;
if (colourArray < 0) {
colourArray = 0;
//set the red, green, and blue place holders in accordance to the scanned colour array and print them*
* red = int(colourArray[0]);
Serial.println(red);
green = int(colourArray[1]);
Serial.println(green);
blue = int(colourArray[2]);
Serial.println(blue);
//set the lamp to the last scanned colour*
* lamp.getColour(red, green, blue);
delay(100); //short delay for my brain to catch up*
void getReading(int times) {
* int reading;
int tally = 0;
//take the reading however many times was requested and add them up*
* for (int i = 0; i < times; i++) {
reading = analogRead(2);
tally = reading + tally;
delay(10);
//calculate the average and set it*
* avgRead = (tally) / times;
//for debugging*
//prints the colour in the colour array, you could also send this to processing and write a little sketch to see how good the scanner works.
void printColour() {
* Serial.print("R = ");
Serial.println(int(colourArray[0]));
Serial.print("G = ");
Serial.println(colourArray[1], DEC);
Serial.print("B = ");
Serial.println(colourArray[2], DEC);
//delay(2000);
//for debugging*
//prints the black and white balances
void printBalance() {
* Serial.println("white balance");
Serial.println(int(whiteArray[0]));
Serial.println(whiteArray[1], DEC);
Serial.println(whiteArray[2], DEC);
//delay(1000);
Serial.println("black balance");
Serial.println(int(blackArray[0]));
Serial.println(blackArray[1], DEC);
Serial.println(blackArray[2], DEC);
delay(2000);
And here's the error:
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Mini, ATmega328"
sketch_aug30a.ino: In function 'void setBalance()':
sketch_aug30a:61: error: 'class Moodlamp' has no member named 'pulse'
sketch_aug30a:62: error: 'class Moodlamp' has no member named 'pulse'
sketch_aug30a:79: error: 'class Moodlamp' has no member named 'pulse'
sketch_aug30a:82: error: 'class Moodlamp' has no member named 'pulse'
sketch_aug30a:84: error: 'class Moodlamp' has no member named 'pulse'
sketch_aug30a:97: error: 'class Moodlamp' has no member named 'pulse'
sketch_aug30a:99: error: 'class Moodlamp' has no member named 'getColour'
sketch_aug30a:101: error: 'class Moodlamp' has no member named 'getColour'
sketch_aug30a:103: error: 'class Moodlamp' has no member named 'getColour'
sketch_aug30a:105: error: 'class Moodlamp' has no member named 'pulse'
sketch_aug30a:107: error: 'class Moodlamp' has no member named 'getColour'
sketch_aug30a.ino: In function 'void setColour()':
sketch_aug30a:150: error: 'class Moodlamp' has no member named 'getColour'
This report would have more information with*
* "Show verbose output during compilation"
enabled in File > Preferences.*_
