Error Combining Sketches + Vishay Thermistor question
I'm trying to combine to working sketches and I'm getting an error message when compiling the error message is " getTemperature " is not declared in this sketch,
How do I fix this please ?
Also I have 2 different types of temperature probes used in a project and I would like both to be used with arduino one is a simple Dallas one wire which works fine the other is a Vishay 10K thermistor NTCLE203E3103FB0 which I've been advised wont work well with arduino due to it being none linear,
I s there a way to use this probe accurately with arduino ?
Thanks Pete
We need to see the code before we could possibly help.
Please use the code tags <CODE>
Just click on the icon and follow the instructions.
All thermistors are non-linear but are still quite usable with any Arduino
Sorry I should have attached the 2 sketches
sketch_Stienhart_MutipleProbes.ino (1.3 KB)
sketch_Johny_5.ino (18.6 KB)
Show the combined sketch that did not work
this is it
sketch_Johnny5_Test.ino (19.7 KB)
The sketch_Johny_5.ino is all screwed up and does not compile.
So it could not be a working sketch.
Please post the working sketch.
try this one
Does it compile witout errors?
the one I have open live now does, the one I've uploaded should be the same one
No, I had to remove an extra "}" to make it compile.
Ahh ok sorry about that, can you see how they dont combine ?
I combined the two and it compiles withot errors.
I don't know what the Johny_5 program does so I'm not sure if the combined program does what you want.
// Pins used 2, 7, 12, 14, 15, 16 22, 24 26 28, 29, 36, 40,
#include "OneWire.h"
#include "DallasTemperature.h"
// Define to which pin of the Arduino the 1-Wire bus is connected:
#define ONE_WIRE_BUS 9
#include <math.h>
// Steinhart-Hart parameters
#define THERMISTORNOMINAL 10000
#define TEMPERATURENOMINAL 25
#define BCOEFFICIENT 3950
#define SERIESRESISTOR 10000
// Analog pins for the thermistors
const int THERMISTOR_PIN_1 = A0;
const int THERMISTOR_PIN_2 = A1;
const int THERMISTOR_PIN_3 = A2;
const int THERMISTOR_PIN_4 = A3;
// Create a new instance of the oneWire class to communicate with any OneWire device:
OneWire oneWire(ONE_WIRE_BUS);
// Pass the oneWire reference to DallasTemperature library:
DallasTemperature sensors(&oneWire);
int ledpin = 13; // initialize pin 13
int inpin = 7; // initialize pin 7
int val;// define val for Worm Barrel overflow sensor
const int PumpPin = 29;                    // for Worm Barrel pump
const int     WBMotor1Pin  = 22;    // For Worm Barrel In put water valve
const int     WBMotor2Pin  = 23;
const int     WBEnablePin  = 24;
const byte WBSensorInterrupt = 0;  // 1 = pin 2; 0 = pin 3  // For Worm Barrel hall sensor
const byte WBSensorPin       = 2;
volatile byte WBPulseCount;
float WBCalibrationFactor = 4.5;
float         WBFlowRate;
unsigned int  WBFlowMilliLitres;
float         WBTotalMilliLitresA;
unsigned long WBTotalMilliLitresB;
unsigned long WBOldTime;
float WBTargetTemperature = 20 ;  // For Obstention temperature
float WBActualTemperature;
const int ChillStillHead = 40;  // Input from BSC460 for Still Head
const int ChillThumper1 = 41;   // Input from BSC460 For Inline Thumper 1
const int ChillThumper2 = 42;  // Input from BSC460 for Inline Thumper 2
const int     Rectification1Motor1Pin  = 30;   // For Inline Thumper 1
const int     Rectification1Motor2Pin  = 31;
const int     Rectification1EnablePin  = 32;
const byte Rectification1SensorInterrupt = 1;  // 1 = pin 2; 0 = pin 3
const byte Rectification1SensorPin       = 5;  // For Inline Thumper 1 hall sensor
float         Rectification1FlowRate;
unsigned int  Rectification1FlowMilliLitres;
float         Rectification1TotalMilliLitresA;
unsigned long Rectification1TotalMilliLitresB;
unsigned long Rectification1OldTime;
volatile byte Rectification1PulseCount;
float Rectification1CalibrationFactor = 4.5;
const int     Rectification2Motor1Pin  = 16;    // For Inline Thumper 2
const int     Rectification2Motor2Pin  = 14;
const int     Rectification2EnablePin  = 15;
const byte Rectification2SensorInterrupt = 3;  // 1 = pin 2; 0 = pin 3
const byte Rectification2SensorPin       = 6; // For Inline Thumper 2 hall sensor
float         Rectification2FlowRate;
unsigned int  Rectification2FlowMilliLitres;
float         Rectification2TotalMilliLitresA;
unsigned long Rectification2TotalMilliLitresB;
unsigned long Rectification2OldTime;
volatile byte Rectification2PulseCount;
float Rectification2CalibrationFactor = 4.5;
const int     StillHeadMotor1Pin  = 19;
const int     StillHeadMotor2Pin  = 18;
const int     StillHeadEnablePin  = 17;
const byte StillHeadSensorInterrupt = 1;  // 1 = pin 2; 0 = pin 3
const byte StillHeadSensorPin       = 4;
float         StillHeadFlowRate;
unsigned int  StillHeadFlowMilliLitres;
float         StillHeadTotalMilliLitresA;
unsigned long StillHeadTotalMilliLitresB;
unsigned long StillHeadOldTime;
volatile byte StillHeadPulseCount;
float StillHeadCalibrationFactor = 4.5;
float getTemperature(int pin) {
  int rawADC = analogRead(pin);
  float resistance = SERIESRESISTOR / ((1023.0 / rawADC) - 1.0);
  float steinhart;
  steinhart = resistance / THERMISTORNOMINAL;
  steinhart = log(steinhart);
  steinhart /= BCOEFFICIENT;
  steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15);
  steinhart = 1.0 / steinhart;
  steinhart -= 273.15;
  return steinhart;
  sensors.begin();
  pinMode ( PumpPin, OUTPUT);
  digitalWrite ( PumpPin,  HIGH) ;
  pinMode          (WBMotor1Pin, OUTPUT);
  pinMode          (WBMotor2Pin, OUTPUT);
  pinMode          (WBEnablePin, OUTPUT);
  pinMode          (Rectification1Motor1Pin, OUTPUT);
  pinMode          (Rectification1EnablePin , OUTPUT);
  pinMode          (Rectification2Motor1Pin, OUTPUT);
  pinMode          (Rectification2EnablePin , OUTPUT);
  pinMode          (StillHeadMotor1Pin, OUTPUT);
  pinMode          (StillHeadEnablePin , OUTPUT);
  pinMode(ledpin, OUTPUT); // set LED pin as “output”
  pinMode(inpin, INPUT); // set button pin as “input”
  pinMode (ChillThumper1, INPUT);
  pinMode (ChillThumper2, INPUT);
  pinMode (ChillStillHead, INPUT);
  digitalWrite (ChillThumper1, LOW);
  digitalWrite (ChillThumper2, LOW);
  digitalWrite (ChillStillHead, LOW);
  float temp1 = getTemperature(THERMISTOR_PIN_1);
  float temp2 = getTemperature(THERMISTOR_PIN_2);
  float temp3 = getTemperature(THERMISTOR_PIN_3);
  float temp4 = getTemperature(THERMISTOR_PIN_4);
  Serial.print("Still Body: ");
  Serial.print(temp1);
  Serial.println(" *C");
  Serial.print("Still Head: ");
  Serial.print(temp2);
  Serial.print("THumper 1: ");
  Serial.print(temp3);
  Serial.print("Thumper 2: ");
  Serial.print(temp4);
  // delay(1000);
  // Send the command for all devices on the bus to perform a temperature conversion:
  sensors.requestTemperatures();
  // Fetch the temperature in degrees Celsius for device index:
  float tempC = sensors.getTempCByIndex(0); // the index 0 refers to the first device
  // Fetch the temperature in degrees Fahrenheit for device index:
  float tempF = sensors.getTempFByIndex(0);
  WBActualTemperature = tempC ;
  val = digitalRead(inpin); // read the level value of pin 7 and assign if to val
  delay(100);
  if (val == LOW) //  if yes, turn on the LED
  { digitalWrite(ledpin, LOW);
    digitalWrite(WBEnablePin, HIGH);
    digitalWrite(WBMotor1Pin, LOW);
    digitalWrite(WBMotor2Pin, HIGH);
    //digitalWrite(WBEnablePin, HIGH);
    //      digitalWrite(WBMotor1Pin, HIGH);
    //      digitalWrite(WBMotor2Pin, LOW);
  { digitalWrite(ledpin, HIGH);
      if (WBActualTemperature <= WBTargetTemperature ) WBValveOpenControl();
      if (WBActualTemperature >= WBTargetTemperature ) WBValveCloseControl();
      if (WBActualTemperature <= 16) digitalWrite (PumpPin,  LOW);
      else digitalWrite ( PumpPin , HIGH);
  if (ChillThumper1 == HIGH)
  { Rectification1ValveOpenControl(); // Input to chill thumper 1 from BSC460
    Rectification1ValveCloseControl();
  if (ChillThumper2 == HIGH)
  { Rectification2ValveOpenControl(); // Input to chill thumper 1 from BSC460
    Rectification2ValveCloseControl();
  if (ChillStillHead == HIGH)
  { StillHeadValveOpenControl(); // Input to chill thumper 1 from BSC460
    StillHeadValveCloseControl();
  if ((millis() - WBOldTime) > 1000) {
    detachInterrupt(WBSensorInterrupt);
    WBFlowRate = ((1000.0 / (millis() - WBOldTime)) * WBPulseCount) / WBCalibrationFactor;
    WBOldTime = millis();
    WBFlowMilliLitres = (WBFlowRate / 60) * 1000;
    // Add the millilitres passed in this second to the cumulative total
    WBTotalMilliLitresA += WBFlowMilliLitres;
    WBTotalMilliLitresB += WBFlowMilliLitres;
    unsigned int WBFrac;
    WBFrac = (WBFlowRate - int(WBFlowRate)) * 10;
    // Reset the pulse counter so we can start incrementing again
    WBPulseCount = 0;
    // Enable the interrupt again now that we've finished sending output
    attachInterrupt(WBSensorInterrupt, WBPulseCounter, FALLING);
  if ((millis() - Rectification1OldTime) > 1000)  {
    detachInterrupt(Rectification1SensorInterrupt);
    Rectification1FlowRate = ((1000.0 / (millis() - Rectification1OldTime)) * Rectification1PulseCount) / Rectification1CalibrationFactor;
    Rectification1OldTime = millis();
    Rectification1FlowMilliLitres = (Rectification1FlowRate / 60) * 1000;
    Rectification1TotalMilliLitresA += Rectification1FlowMilliLitres;
    Rectification1TotalMilliLitresB += Rectification1FlowMilliLitres;
    unsigned int Rectification1Frac;
    Rectification1Frac = (Rectification1FlowRate - int(Rectification1FlowRate)) * 10;
    Rectification1PulseCount = 0;
    attachInterrupt(Rectification1SensorInterrupt, Rectification1PulseCounter, FALLING);
  if ((millis() - Rectification2OldTime) > 1000)  {
    detachInterrupt(Rectification2SensorInterrupt);
    Rectification2FlowRate = ((1000.0 / (millis() - Rectification2OldTime)) * Rectification2PulseCount) / Rectification2CalibrationFactor;
    Rectification2OldTime = millis();
    Rectification2FlowMilliLitres = (Rectification2FlowRate / 60) * 1000;
    Rectification2TotalMilliLitresA += Rectification2FlowMilliLitres;
    Rectification2TotalMilliLitresB += Rectification2FlowMilliLitres;
    unsigned int Rectification2Frac;
    Rectification2Frac = (Rectification2FlowRate - int(Rectification2FlowRate)) * 10;
    Rectification2PulseCount = 0;
    attachInterrupt(Rectification2SensorInterrupt, Rectification2PulseCounter, FALLING);
  if ((millis() - StillHeadOldTime) > 1000)  {
    detachInterrupt(StillHeadSensorInterrupt);
    StillHeadFlowRate = ((1000.0 / (millis() - StillHeadOldTime)) * StillHeadPulseCount) / StillHeadCalibrationFactor;
    StillHeadOldTime = millis();
    StillHeadFlowMilliLitres = (StillHeadFlowRate / 60) * 1000;
    StillHeadTotalMilliLitresA += StillHeadFlowMilliLitres;
    StillHeadTotalMilliLitresB += StillHeadFlowMilliLitres;
    unsigned int StillHeadFrac;
    StillHeadFrac = (StillHeadFlowRate - int(StillHeadFlowRate)) * 10;
    StillHeadPulseCount = 0;
    attachInterrupt(StillHeadSensorInterrupt, StillHeadPulseCounter, FALLING);
    Serial.print( "Worm Barrel L ") ;
    Serial.print (WBTotalMilliLitresA);
    Serial.print ("  Still Head L ");
    Serial.print (StillHeadTotalMilliLitresA);
    Serial.print ("  Thumper 1 L ");
    Serial.print (Rectification1TotalMilliLitresA);
    Serial.print ("  Thumper 2 L ");
    Serial.print (Rectification2TotalMilliLitresA);
    Serial.print("  Obstention Temperature: ");
    Serial.print(tempC);
    Serial.print(" \xC2\xB0"); // shows degree symbol
    Serial.print("C  |  ");
void WBPulseCounter() {
  // Increment the pulse counter
  WBPulseCount++;
void Rectification1PulseCounter() {
  Rectification1PulseCount++;
void Rectification2PulseCounter() {
  Rectification2PulseCount++;
void StillHeadPulseCounter() {
  StillHeadPulseCount++;
void openWBValve() {
void closeWBValve() {
void WBValveOpenControl() { // MLTFill Open valve control for sparge
  long interval = 100;
  long shortInterval = 50;
  long previousMillis = 0;
  unsigned long SIcurrentMillis = millis();
  long SIpreviousMillis = 0;
  if (currentMillis - previousMillis > interval) {
    ////////////// A delay may be required here as the valve ages
  if (SIcurrentMillis - SIpreviousMillis > shortInterval) {
    SIpreviousMillis = SIcurrentMillis;
void WBValveCloseControl() { // MLTFill Close valve control for sparge
    ////////////// A delay may be requireed as the valve ages
void openRectification1Valve() {
  digitalWrite(Rectification1EnablePin, HIGH);
  digitalWrite(Rectification1Motor1Pin, LOW);
  digitalWrite(Rectification1Motor2Pin, HIGH);
void closeRectification1Valve() {
  digitalWrite(Rectification1Motor1Pin, HIGH);
  digitalWrite(Rectification1Motor2Pin, LOW);
void Rectification1ValveOpenControl() { // Rectification1 Open valve control for sparge
void Rectification1ValveCloseControl() { // Rectification1 Close valve control for sparge
void openRectification2Valve() {
  digitalWrite(Rectification2EnablePin, HIGH);
  digitalWrite(Rectification2Motor1Pin, LOW);
  digitalWrite(Rectification2Motor2Pin, HIGH);
void closeRectification2Valve() {
  digitalWrite(Rectification2Motor1Pin, HIGH);
  digitalWrite(Rectification2Motor2Pin, LOW);
void Rectification2ValveOpenControl() { // Rectification2 Open valve control for sparge
void Rectification2ValveCloseControl() { // Rectification2 Close valve control for sparge
void openStillHeadValve() {
  digitalWrite(StillHeadEnablePin, HIGH);
  digitalWrite(StillHeadMotor1Pin, LOW);
  digitalWrite(StillHeadMotor2Pin, HIGH);
void closeStillHeadValve() {
  digitalWrite(StillHeadMotor1Pin, HIGH);
  digitalWrite(StillHeadMotor2Pin, LOW);
void StillHeadValveOpenControl() { // StillHead Open valve control for sparge
void StillHeadValveCloseControl() { // StillHead Close valve control for sparge
You've put thing in a different order, I wonder if that was all it was, thank you very much though.
Is the sketch I have the best way to use the probes ?
Programming Electronics Academy released a video on combining sketches... to save all those words.
