I have also gone into the permissions for the executable and set file permissions for my user to have control. Still no luck to get the compiler to not return an error with not having permission to write the file in the temp space.
I have uninstalled arduino 1.6.7 and installed 1.6.4 and the compiler still complains about not being able to write due to ownership. 1.6.4 does not see the daughter board on the USB port.
So now I am looking at changing the OS. Perhaps I will search the forum for Win-10 success as an OS for Arduino. I hate to ask for a subsitute Arduino IDE in this forum, wouldn't that be inappropriate?
Itnmay not be folder permissions and I may never find out.
I took your advice to heart and did not find a place to turn off the firewall.
But I did turn off two anti malware programs and that may have done the trick.
Inalso spent a LOT of time changing file permissions in my own temp folder which is where the compiler was pointing to and complaining about.
IT NOW WORKS ! Thank you all
now I just have to learn how to write code. My friends warn.me about disappearing down that rabbit hole. But I have two projects that need to be done and shared with the community . One is fault alarms on garden sprinklers that text me the alarm.
Why the hell this software continuously giving this error?
I had arduino ide from months and not had even a single problems like this. All of sudden this error strikes. Now i have tried installed 1.6.5/6/9/10 but cant came above this problem. Oh god somebody help.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar: unable to rename 'core\core.a'; reason: Permission denied
exit status 1
Error compiling for board Arduino/Genuino Uno.
From somewhere an antimalware program was installed on my computer...called bytefence. I removed it and it fixed this problem. I never installed it! Some day the governments of the world are going to put severe punishments on these dirt bags and they will stop.
If you have installed to a different drive swap the drive letter as needed.
If you also have an unzipped IDE installed that path should also be added to exclusions
FIREWALL
Some third party firewalls also cause issues and again look to exclude the above folders from that.
The following should also be allowed through your firewall
"Java(TM) Platform SE binary"
Depending on how your network is set up you may have to allow Home/Work (Private) and also Public.
If you have CREATE installed ensure that is also allowed through the firewall
"arduino_create_bridge.exe"
Beware that not all "antimalware" software is actually what it says. There are rogue versions out there so ensure it is a "reputable" brand and not some obscure name.
Mark_Grass:
same here!!! for some reason bytefence installed on my computer and i just had to remove it
