Hey guys!
So I recently bought an Arduino Uno from Ebay. But when I plugged it into my PC, after downloading the Arduino Program for my Windows 10 PC, I wanted to play around with my new Arduino. So as a beginner I opened up an Arduino project from the Internet for my LED Strip. Then I got an error message (see below).
I thought maybe the project has an error and I tried out one of the examples. The same error occurred. Then I opened a few other examples (not at the same time of course) and got the same error message in each of them (see below).
So I got really frustrated and started googling. But nothing I found helped. I tried:
-reinstalling
-deleting the "Arduino15" folder
-opening Arduino as an Administrator
-deleting every Arduino folder I could possibly find, restarting the PC and installing the Arduino Programm again...
BUT NOTHING WORKED!!! >:(
So I decided to ask u guys for help! Any help is apreciated.
Error Message:
Arduino: 1.8.4 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Jonas\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10804 -build-path C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641 -warnings=none -build-cache C:\Users\Jonas\AppData\Local\Temp\arduino_cache_277291 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Jonas\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10804 -build-path C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641 -warnings=none -build-cache C:\Users\Jonas\AppData\Local\Temp\arduino_cache_277291 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\sketch\Blink.ino.cpp" -o "C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\sketch\Blink.ino.cpp" -o "C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\wiring_pulse.S.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\WInterrupts.c.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\hooks.c.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\wiring.c.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\wiring_analog.c.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\wiring_digital.c.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\wiring_pulse.c.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\wiring_shift.c.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\CDC.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\PluggableUSB.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\Print.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\Stream.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\Tone.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\USBCore.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\WMath.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\WString.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\abi.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\main.cpp.o
Using previously compiled file: C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\new.cpp.o
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs "C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\core.a" "C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\wiring_pulse.S.o"
c:\program files (x86)\arduino\hardware\tools\avr\bin../lib/gcc/avr/4.9.2/../../../../avr/bin/ar.exe: unable to rename 'C:\Users\Jonas\AppData\Local\Temp\arduino_build_765641\core\core.a'; reason: Permission denied
exit status 1
Error compiling for board Arduino/Genuino Uno.
Thanks for the help, Jonas!
