Error compiling for board Arduino/Genuino Mega or Mega 2560.
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\Kasutaja\Desktop\Marlin-1.1.x\Marlin-1.1.x\Marlin\Marlin.ino:45:110: fatal error: U8glib.h: No such file or directory
#include <U8glib.h> // library for graphics LCD by Oli Kraus (GitHub - olikraus/U8glib_Arduino: U8glib library for Arduino)
compilation terminated.
exit status 1
option enabled in File -> Preferences.
Then i downloaded and added GitHub - olikraus/U8glib_Arduino: U8glib library for Arduino
( U8glib_Arduino/U8glib.h at master · olikraus/U8glib_Arduino · GitHub ) to
**C:\Users\Kasutaja\Desktop\Marlin-1.1.x\Marlin-1.1.x\Marlin\ **
but there is no changes
And i cannot find such path
Only till
KaurGR:
Then i downloaded and added [u]https://github.com/olikraus/U8glib_Arduino[/u]
( U8glib_Arduino/src/U8glib.h at master · olikraus/U8glib_Arduino · GitHub ) to
Because that's not how you install an Arduino library.
Do this:
  • Sketch > Include Library > Manage Libraries
  • Wait for the download to finish
  • In the "Filter your search..." box, type "U8glib"
  • Scroll down through the results until you see "U8glib by oliver". Click on it.
  • Click "Install"
  • Wait for installation to finish.
  • Click "Close".
More information:
https://www.arduino.cc/en/Guide/Libraries
New error cannot fit here
Uus tekstidokument (2).txt (20.7 KB)
KaurGR:
Those numbers at the end indicate the line number and column where the error occurred in the file. So the error is at line 45, column 110.
pert:
Okay, got you.
whats the " 'rx_buffer' was not declared in this scope " about?
void MarlinSerial::flush(void) {
// Don't change this order of operations. If the RX interrupt occurs between
// reading rx_buffer_head and updating rx_buffer_tail, the previous rx_buffer_head
// may be written to rx_buffer_tail, making the buffer appear full rather than empty.
CRITICAL_SECTION_START;
rx_buffer.head = rx_buffer.tail; ~Error from this line
CRITICAL_SECTION_END;
I have Redone 6 times and always comes " 'rx_buffer' was not declared in this scope " DonT Know What To Do!
This Marlin is set up by the factory
ring_buffer_pos_t MarlinSerial::available(void) {
const ring_buffer_pos_t h = atomic_read_rx_head(), t = rx_buffer.tail; ~ERROR
return (ring_buffer_pos_t)(RX_BUFFER_SIZE + h - t) & (RX_BUFFER_SIZE - 1);
Error message.txt (21.4 KB)
In order to get help, you are probably going to have to show people where rx_buffer gets defined.
That's where the problem is likely to be.
DaleScott:
Ugh...
https://www.upload.ee/image/8765580/Marlin_-_MarlinSerial.cpp___Arduino_1.8.5_04.08.2018_01_38_09.png
sorry I dont understand :drooling_face:
Okay got it fixed #define SERIAL_PORT should been 0 .now lcd screen is not working ... you can close this topic . wont be expecting any response
É so deixar desmarcado
serial port 0
