Error compiling for board Arduino/Genuino Uno.
right so here's the project How to Make Fingerprint Door Lock at Home - YouTube I'm referring
Adafruit_Fingerprint (1).cpp (13.6 KB)
Adafruit_Fingerprint (3).cpp (15.7 KB)
We shouldn't be required to watch a YouTube video to help you.
Please post your full sketch. If possible, you should always post code directly in the forum thread as text using code tags (</> button on the toolbar). This will make it easy for anyone to look at it, which will increase the likelihood of you getting help. If the sketch is longer than the forum will allow then it's OK to add it as an attachment. After clicking the "Reply" button, you will see an "Attachments and other settings" link.
Please always do an Auto Format (Tools > Auto Format in the Arduino IDE or Ctrl + B in the Arduino Web Editor) on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read.
When your code requires a library that's not included with the Arduino IDE please post a link (using the chain links icon on the toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
When you encounter an error, you'll see a button on the right side of the orange bar "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button. In a message here, click the code tags button (</> on the forum toolbar) and then paste the error. If the text exceeds the forum's 9000 character limit, save it to a text file and post it as an attachment. If you click the "Reply" button here, you will see an "Attachments and other settings" link.
Sorry about that I'm new here. so here's the sketch
#include "Adafruit_Fingerprint.h"
#if defined(__AVR__) || defined(ESP8266)
    #include <SoftwareSerial.h>
#endif
#if ARDUINO >= 100
  #define SERIAL_WRITE(...) mySerial->write(__VA_ARGS__)
#else
  #define SERIAL_WRITE(...) mySerial->write(__VA_ARGS__, BYTE)
#endif
#define SERIAL_WRITE_U16(v) SERIAL_WRITE((uint8_t)(v>>8)); SERIAL_WRITE((uint8_t)(v & 0xFF));
#define GET_CMD_PACKET(...) \
  uint8_t data[] = {__VA_ARGS__}; \
  Adafruit_Fingerprint_Packet packet(FINGERPRINT_COMMANDPACKET, sizeof(data), data); \
  writeStructuredPacket(packet); \
  if (getStructuredPacket(&packet) != FINGERPRINT_OK) return FINGERPRINT_PACKETRECIEVEERR; \
  if (packet.type != FINGERPRINT_ACKPACKET) return FINGERPRINT_PACKETRECIEVEERR;
#define SEND_CMD_PACKET(...) GET_CMD_PACKET(__VA_ARGS__); return packet.data[0];
Adafruit_Fingerprint::Adafruit_Fingerprint(SoftwareSerial *ss, uint32_t password) {
  thePassword = password;
  theAddress = 0xFFFFFFFF;
  hwSerial = NULL;
  swSerial = ss;
  mySerial = swSerial;
Adafruit_Fingerprint::Adafruit_Fingerprint(HardwareSerial *hs, uint32_t password) {
  swSerial = NULL;
#endif
  hwSerial = hs;
  mySerial = hwSerial;
void Adafruit_Fingerprint::begin(uint32_t baudrate) {
  delay(1000);  // one second delay to let the sensor 'boot up'
  if (hwSerial) hwSerial->begin(baudrate);
  if (swSerial) swSerial->begin(baudrate);
#endif
boolean Adafruit_Fingerprint::verifyPassword(void) {
  return checkPassword() == FINGERPRINT_OK;
uint8_t Adafruit_Fingerprint::checkPassword(void) {
  GET_CMD_PACKET(FINGERPRINT_VERIFYPASSWORD,
                  (uint8_t)(thePassword >> 24), (uint8_t)(thePassword >> 16),
                  (uint8_t)(thePassword >> 8), (uint8_t)(thePassword & 0xFF));
  if (packet.data[0] == FINGERPRINT_OK)
    return FINGERPRINT_OK;
uint8_t Adafruit_Fingerprint::getImage(void) {
  SEND_CMD_PACKET(FINGERPRINT_GETIMAGE);
uint8_t Adafruit_Fingerprint::image2Tz(uint8_t slot) {
  SEND_CMD_PACKET(FINGERPRINT_IMAGE2TZ,slot);
uint8_t Adafruit_Fingerprint::createModel(void) {
  SEND_CMD_PACKET(FINGERPRINT_REGMODEL);
uint8_t Adafruit_Fingerprint::storeModel(uint16_t location) {
  SEND_CMD_PACKET(FINGERPRINT_STORE, 0x01, (uint8_t)(location >> 8), (uint8_t)(location & 0xFF));
uint8_t Adafruit_Fingerprint::loadModel(uint16_t location) {
  SEND_CMD_PACKET(FINGERPRINT_LOAD, 0x01, (uint8_t)(location >> 8), (uint8_t)(location & 0xFF));
uint8_t Adafruit_Fingerprint::getModel(void) {
  SEND_CMD_PACKET(FINGERPRINT_UPLOAD, 0x01);
uint8_t Adafruit_Fingerprint::deleteModel(uint16_t location) {
  SEND_CMD_PACKET(FINGERPRINT_DELETE, (uint8_t)(location >> 8), (uint8_t)(location & 0xFF), 0x00, 0x01);
uint8_t Adafruit_Fingerprint::emptyDatabase(void) {
  SEND_CMD_PACKET(FINGERPRINT_EMPTY);
uint8_t Adafruit_Fingerprint::fingerFastSearch(void) {
  GET_CMD_PACKET(FINGERPRINT_HISPEEDSEARCH, 0x01, 0x00, 0x00, 0x00, 0xA3);
  fingerID = 0xFFFF;
  confidence = 0xFFFF;
  fingerID = packet.data[1];
  fingerID <<= 8;
  fingerID |= packet.data[2];
  confidence = packet.data[3];
  confidence <<= 8;
  confidence |= packet.data[4];
uint8_t Adafruit_Fingerprint::getTemplateCount(void) {
  GET_CMD_PACKET(FINGERPRINT_TEMPLATECOUNT);
  templateCount = packet.data[1];
  templateCount <<= 8;
  templateCount |= packet.data[2];
uint8_t Adafruit_Fingerprint::setPassword(uint32_t password) {
  SEND_CMD_PACKET(FINGERPRINT_SETPASSWORD, (password >> 24), (password >> 16), (password >> 8), password);
void Adafruit_Fingerprint::writeStructuredPacket(const Adafruit_Fingerprint_Packet & packet) {
  SERIAL_WRITE_U16(packet.start_code);
  SERIAL_WRITE(packet.address[0]);
  SERIAL_WRITE(packet.address[1]);
  SERIAL_WRITE(packet.address[2]);
  SERIAL_WRITE(packet.address[3]);
  SERIAL_WRITE(packet.type);
  uint16_t wire_length = packet.length + 2;
  SERIAL_WRITE_U16(wire_length);
  uint16_t sum = ((wire_length)>>8) + ((wire_length)&0xFF) + packet.type;
  for (uint8_t i=0; i< packet.length; i++) {
    SERIAL_WRITE(packet.data[i]);
    sum += packet.data[i];
  SERIAL_WRITE_U16(sum);
  return;
uint8_t Adafruit_Fingerprint::getStructuredPacket(Adafruit_Fingerprint_Packet * packet, uint16_t timeout) {
  uint8_t byte;
  uint16_t idx=0, timer=0;
  while(true) {
    while(!mySerial->available()) {
      delay(1);
      timer++;
      if( timer >= timeout) {
#ifdef FINGERPRINT_DEBUG
  Serial.println("Timed out");
#endif
  return FINGERPRINT_TIMEOUT;
    byte = mySerial->read();
    Serial.print("<- 0x"); Serial.println(byte, HEX);
#endif
    switch (idx) {
      case 0:
        if (byte != (FINGERPRINT_STARTCODE >> 8))
    continue;
        packet->start_code = (uint16_t)byte << 8;
      case 1:
        packet->start_code |= byte;
        if (packet->start_code != FINGERPRINT_STARTCODE)
    return FINGERPRINT_BADPACKET;
      case 2:
      case 3:
      case 4:
      case 5:
        packet->address[idx-2] = byte;
      case 6:
  packet->type = byte;
      case 7:
  packet->length = (uint16_t)byte << 8;
      case 8:
  packet->length |= byte;
      default:
        packet->data[idx-9] = byte;
        if((idx-8) == packet->length)
    idx++;
and here I've attached the error, cause it exceeds the allowed character length
It appears that you grabbed the .cpp file from the Adafruit Fingerprint library and are attempting to compile it as if it was a sketch. You can't do that. Libraries are collections of functions you can use in your own code. They are not a complete program, thus the error.
Luckily, the library does come with some example sketches, which are complete programs. You will find these listed in the Arduino IDE at File > Examples > Adafruit Fingerprint Sensor Library. Open some of those, upload them to your Arduino to try them out, then you can study the example code to understand how to use the library in your own project.
You also might find this information to be useful.
