error compiling for board arduino leonardo
hello everyone
i really want to make a capacitive sensor keypad like the one SquashyBoy made in his video.
but, because i'm literally a newbie on programming arduino, i don't know what to do to fix this error
the error:
C:\Users\zakit\AppData\Local\Temp\ccLCueWf.ltrans0.ltrans.o: In function `CapacitiveKey::keyUpdate(bool)':
C:\Users\zakit\AppData\Local\Temp\arduino_build_148351\sketch/capacitiveKey.h:23: undefined reference to `CapacitiveSensor::capacitiveSensorRaw(unsigned char)'
C:\Users\zakit\AppData\Local\Temp\ccLCueWf.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_KappaPad.ino.cpp.o.2177':
:(.text.startup+0x136): undefined reference to `CapacitiveSensor::CapacitiveSensor(unsigned char, unsigned char)'
:(.text.startup+0x17c): undefined reference to `CapacitiveSensor::CapacitiveSensor(unsigned char, unsigned char)'
collect2.exe: error: ld returned 1 exit status
Using library Keyboard at version 1.0.2 in folder: C:\Program Files (x86)\Arduino\libraries\Keyboard
Using library HID at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\HID
exit status 1
Error compiling for board Arduino Leonardo.
Please post your full code. Before doing so, please read How to use this forum - please read. - Installation & Troubleshooting - Arduino Forum and pay special attention to point #7 about posting code using code tags.
Please post a link to the CapacitiveSensor library that you're using.
Most probably your CapacitiveSensor library (which exactly?) does not support the Leonardo.
Find a different library that is applicable to the Leonardo.
It looks like all of the errors are in the linker... the stage of the build where the various compiled binary files are linked together into a program. I suspect that one ort more source files are missing from the CapacitiveSensor library. Did you copy a CapacitiveSensor.h without the CapacitiveSensor.cpp file?
sterretje:
Please post your full code. Before doing so, please read How to use this forum - please read - Website and Forum - Arduino Forum and pay special attention to point #7 about posting code using code tags.
#include "CapacitiveSensor.h"
#include <Keyboard.h>
#include "capacitiveKey.h"
//#define SERIAL_OUTPUT
#define DISABLE_PIN 15
#ifdef SERIAL_OUTPUT
#endif
Keyboard.begin();
pinMode(DISABLE_PIN, INPUT_PULLUP);
CapacitiveKey key0 = CapacitiveKey(
2, //Capacitive Send Pin
7, //Capacitive Sense Pin
6, //LED Pin
6, //Capacitive Treshold
'z', //Keyboard Key
255 //LED Brightness (0-255)
CapacitiveKey key1 = CapacitiveKey(
4, //Capacitive Send Pin
8, //Capacitive Sense Pin
10, //LED Pin
5, //Capacitive Treshold
'x', //Keyboard Key
bool keyboardActive = digitalRead(DISABLE_PIN);
key0.keyUpdate(keyboardActive);
key1.keyUpdate(keyboardActive);
Serial.print(key0.sample);
Serial.print(",");
Serial.println(key1.sample);
#endif
here is the link: GitHub - fb39ca4/kappa-pad: Initial Commit
You did NOT read the link that I gave you :frowning:
You missed an important part in https://github.com/fb39ca4/kappa-pad:
Software
The Arduino Sketch is located in the KappaPad directory of this repository. It requires the CapacitiveSensor library so install that first.
