Error compiling for board ATmega32
Arduino: 1.8.19 (Windows 10), Board: "ATmega32, Yes (UART0), EEPROM retained, Standard pinout, BOD 2.7V, LTO disabled, External 16 MHz"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\cjdeliverio\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\cjdeliverio\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\cjdeliverio\Documents\Arduino\libraries -fqbn=MightyCore:avr:32:bootloader=uart0,eeprom=keep,pinout=standard,BOD=2v7,LTO=Os,clock=16MHz_external -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\CJDELI~1\AppData\Local\Temp\arduino_build_701061 -warnings=none -build-cache C:\Users\CJDELI~1\AppData\Local\Temp\arduino_cache_892616 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.avrdude-6.3.0-arduino18.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.arduinoOTA.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\CJDELI~1\AppData\Local\Temp\arduino_modified_sketch_623695\sketch_nov17b.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\cjdeliverio\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\cjdeliverio\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\cjdeliverio\Documents\Arduino\libraries -fqbn=MightyCore:avr:32:bootloader=uart0,eeprom=keep,pinout=standard,BOD=2v7,LTO=Os,clock=16MHz_external -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\CJDELI~1\AppData\Local\Temp\arduino_build_701061 -warnings=none -build-cache C:\Users\CJDELI~1\AppData\Local\Temp\arduino_cache_892616 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.avrdude-6.3.0-arduino18.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.arduinoOTA.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\CJDELI~1\AppData\Local\Temp\arduino_modified_sketch_623695\sketch_nov17b.ino
Using board '32' from platform in folder: C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3
Using core 'MCUdude_corefiles' from platform in folder: C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3
Detecting libraries used...
"C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega32 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega32 -DARDUINO_ARCH_AVR "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\cores\MCUdude_corefiles" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\variants\standard" "C:\Users\CJDELI~1\AppData\Local\Temp\arduino_build_701061\sketch\sketch_nov17b.ino.cpp" -o nul
Alternatives for ATmega_Slow_PWM.h: [ATmega_Slow_PWM-1.0.0@1.0.0 ATmega_Slow_PWM-1.0.0@1.0.0]
ResolveLibrary(ATmega_Slow_PWM.h)
-> candidates: [ATmega_Slow_PWM-1.0.0@1.0.0 ATmega_Slow_PWM-1.0.0@1.0.0]
"C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega32 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega32 -DARDUINO_ARCH_AVR "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\cores\MCUdude_corefiles" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\variants\standard" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src" "C:\Users\CJDELI~1\AppData\Local\Temp\arduino_build_701061\sketch\sketch_nov17b.ino.cpp" -o nul
Alternatives for ICSC.h: [ICSC-master@1.3.6]
ResolveLibrary(ICSC.h)
-> candidates: [ICSC-master@1.3.6]
"C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega32 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega32 -DARDUINO_ARCH_AVR "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\cores\MCUdude_corefiles" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\variants\standard" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ICSC-master\src" "C:\Users\CJDELI~1\AppData\Local\Temp\arduino_build_701061\sketch\sketch_nov17b.ino.cpp" -o nul
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@2.0]
"C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega32 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega32 -DARDUINO_ARCH_AVR "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\cores\MCUdude_corefiles" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\variants\standard" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ICSC-master\src" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\libraries\EEPROM\src" "C:\Users\CJDELI~1\AppData\Local\Temp\arduino_build_701061\sketch\sketch_nov17b.ino.cpp" -o nul
Alternatives for Sensir.h: [HumidSHT17]
ResolveLibrary(Sensir.h)
-> candidates: [HumidSHT17]
"C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega32 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega32 -DARDUINO_ARCH_AVR "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\cores\MCUdude_corefiles" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\variants\standard" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ICSC-master\src" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\libraries\EEPROM\src" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\HumidSHT17" "C:\Users\CJDELI~1\AppData\Local\Temp\arduino_build_701061\sketch\sketch_nov17b.ino.cpp" -o nul
Error while detecting libraries included by C:\Users\CJDELI~1\AppData\Local\Temp\arduino_build_701061\sketch\sketch_nov17b.ino.cpp
"C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega32 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega32 -DARDUINO_ARCH_AVR "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\cores\MCUdude_corefiles" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\variants\standard" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ICSC-master\src" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\libraries\EEPROM\src" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\HumidSHT17" "C:\Users\cjdeliverio\Documents\Arduino\libraries\ICSC-master\src\ICSC.cpp" -o nul
"C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega32 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega32 -DARDUINO_ARCH_AVR "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\cores\MCUdude_corefiles" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\variants\standard" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ICSC-master\src" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\libraries\EEPROM\src" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\HumidSHT17" "C:\Users\cjdeliverio\Documents\Arduino\libraries\HumidSHT17\Sensir.cpp" -o nul
Generating function prototypes...
"C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega32 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega32 -DARDUINO_ARCH_AVR "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\cores\MCUdude_corefiles" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\variants\standard" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\ICSC-master\src" "-IC:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\libraries\EEPROM\src" "-IC:\Users\cjdeliverio\Documents\Arduino\libraries\HumidSHT17" "C:\Users\CJDELI~1\AppData\Local\Temp\arduino_build_701061\sketch\sketch_nov17b.ino.cpp" -o "C:\Users\CJDELI~1\AppData\Local\Temp\arduino_build_701061\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src/ATmega_Slow_PWM.h:27:0,
             from C:\Users\CJDELI~1\AppData\Local\Temp\arduino_modified_sketch_623695\sketch_nov17b.ino:4:
C:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src/ATmega_Slow_PWM.hpp:93:4: error: #error Old MightyCore AVR ATmega8535, ATmega16, ATmega32 not supported, try ATmega164, ATmega324, ATmega644, ATmega1284
In file included from C:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src/ATmega_Slow_PWM_ISR.h:27:0,
             from C:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src/ATmega_Slow_PWM.h:30,
C:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0\src/ATmega_Slow_PWM_ISR.hpp:94:4: error: #error Old MightyCore AVR ATmega8535, ATmega16, ATmega32 not supported, try ATmega164, ATmega324, ATmega644, ATmega1284
Multiple libraries were found for "ATmega_Slow_PWM.h"
Used: C:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0
Not used: C:\Program Files (x86)\Arduino\libraries\ATmega_Slow_PWM-1.0.0
Using library ATmega_Slow_PWM-1.0.0 at version 1.0.0 in folder: C:\Users\cjdeliverio\Documents\Arduino\libraries\ATmega_Slow_PWM-1.0.0
Using library ICSC-master at version 1.3.6 in folder: C:\Users\cjdeliverio\Documents\Arduino\libraries\ICSC-master
Using library EEPROM at version 2.0 in folder: C:\Users\cjdeliverio\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.1.3\libraries\EEPROM
Using library HumidSHT17 in folder: C:\Users\cjdeliverio\Documents\Arduino\libraries\HumidSHT17 (legacy)
exit status 1
Error compiling for board ATmega32.
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Please post the sketch that produced the errors, using code tags when you do
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
That's pretty clear, isn't it? The Slow_PWM library doesn't support the ATmega32.
(the ATmega32 is an older chip, similar to the ATmega8. It has different timers than the newer chips like the ATmega328p used in Uno and Nano, so it's not TOO surprising that it doesn't support some libraries that are likely to be using timers.)
