Error compiling for board XIAO_ESP32C3
pls advice me how to solve this error.
Welcome to the forum
As your topic does not relate directly to the installation or operation of the IDE it has been moved to the Programming category of the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Please post your full sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
It is also helpful to post full error messages in code tags as it makes it easier to scroll through them and copy them for examination
#include <WiFi.h>
#include <WiFiClient.h>
#include <WebServer.h>
#include "index.h"
#include <LoRaE5.h>
unsigned char buffer[128] = {0, };
String incomingString;
//Grove Port >> GND/5V/G13/G4
#define GROVE_TX 13
#define GROVE_RX 4
WebServer server(80);
//Enter your SSID and PASSWORD
const char* ssid = "AK_CODING";
const char* password = "1234567890";
// This routine is executed when you open its IP in browser
void handleRoot() {
 String s = MAIN_PAGE_IDREAMS;
 server.send(200, "text/html", s);
void handleGPS() {
 server.send(200, "text/plane", incomingString);
// Setup
void setup(void){
  lora.init();    //lora.init(GROVE_RX, GROVE_TX);
  delay(2000);
  lora.initP2PMode(866, SF12, BW125, 12, 15, 14);
//ESP32 connects to your wifi
  WiFi.mode(WIFI_STA);          //Connect to your wifi
  WiFi.begin(ssid, password);
  Serial.println("Connecting to ");
  Serial.print(ssid);
  //Wait for WiFi to connect
  while(WiFi.waitForConnectResult() != WL_CONNECTED){
      Serial.print(".");
  //If connection successful show IP address in serial monitor
  Serial.println("");
  Serial.println("Connected to: ");
  Serial.print(ssid);
  Serial.println("");
  Serial.println("IP address: ");
  Serial.print(WiFi.localIP());  //IP address assigned to your ESP
  Serial.println("");
  server.on("/", handleRoot);
  server.on("/gpsDATA", handleGPS);
  server.begin();
  Serial.println("HTTP server started");
void loop(void){
  server.handleClient();
  delay(1);
  short length = 0;
  short rssi = 0;
  memset(buffer, 0, 128);
  length = lora.receivePacketP2PMode(buffer, 128,  &rssi, 1);
  if(length){
    incomingString = String((char*)buffer);
    String Data = incomingString + "|";
    Serial.print(Data);
	//Serial.flush();
this is the error message.
Error compiling for board XIAO_ESP32C3.
(index.h)
const char MAIN_PAGE_IDREAMS[] PROGMEM = R"=====(
<html lang="en">
<head>
	<base target="_top">
	<meta charset="utf-8">
	<meta name="viewport" content="width=device-width, initial-scale=1">
	<link href="data:image/x-icon;base64,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" rel="icon" type="image/x-icon" />
	<title>E5MAT: LoRa GPS Tracker</title>
    <link rel="stylesheet" href="https://unpkg.com/leaflet@1.9.3/dist/leaflet.css" integrity="sha256-kLaT2GOSpHechhsozzB+flnD+zUyjE2LlfWPgU04xyI=" crossorigin=""/>
    <script src="https://unpkg.com/leaflet@1.9.3/dist/leaflet.js" integrity="sha256-WBkoXOwTeyKclOHuWtc+i2uENFpDZ9YPdf5Hf+D7ewM=" crossorigin=""></script>
	<style>
		html, body {
			height: 100%;
			margin: 0;
		.leaflet-container {
			height: 400px;
			width: 600px;
			max-width: 100%;
			max-height: 100%;
		img.huechange { filter: hue-rotate(240deg); }
		img.huecchange { filter: hue-rotate(140deg); }
	</style>
	<style>body { padding: 0; margin: 0; } #map { height: 100%; width: 100vw; }</style>
</head>
<body>
<div id='map'></div>
<script>
	setInterval(function() {
	  // Call a function repetatively with 2 Second interval
	  getGPSData();
	}, 2000); //2000 mSeconds update rate
  var PhoneIcon = L.icon({
    iconUrl: 'data:image/png;base64,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',
    iconSize: [40, 40], //size of the icon
	var prevLat, prevLong;
	var phoneLat, phoneLong;
	var zoomLevel = 16;
	var theMarker = {};
	const map = L.map('map').fitWorld();
	const tiles = L.tileLayer('https://tile.openstreetmap.org/{z}/{x}/{y}.png', {
	//const tiles = L.tileLayer('https://api.mapbox.com/styles/v1/mapbox/streets-v9/tiles/{z}/{x}/{y}?access_token=YOUR_KEY', {
		maxZoom: 19,
		//attribution: '&copy; <a href="http://www.openstreetmap.org/copyright">OpenStreetMap</a>'
	}).addTo(map);
	function getGPSData() {
	  var xhttp = new XMLHttpRequest();
	  xhttp.onreadystatechange = function() {
		if (this.readyState == 4 && this.status == 200) {
		  let text = this.responseText;
		  const myArray = text.split(",");
		  ShowMarker(myArray[0], myArray[1]);
	  xhttp.open("GET", "gpsDATA", true);
	  xhttp.send();
	function ShowMarker(lat, lng) {
		if (!(isEmpty(lat)) || !(isEmpty(lng))){
			if (lat != prevLat && lng != prevLong) {
				var mapCenter = [lat,lng];
				if (theMarker != undefined) {
					  map.removeLayer(theMarker);
					  if ((prevLat != undefined) & (prevLong != undefined)) {
							theMarker = L.marker([prevLat, prevLong]).addTo(map);
							theMarker._icon.classList.add("huecchange");
				if ((phoneLat != undefined) & (phoneLong != undefined)) {
					var distance = getDistanceBetweenTwoPoints(phoneLat, phoneLong, lat, lng, 'K');
					var distanceRound = Math.round(distance*1000)/1000;
					theMarker = L.marker([lat, lng]).addTo(map)
					.bindPopup('Distance from you: ' + distanceRound + ' K');
					theMarker._icon.classList.add("huechange");
					map.setView(new L.LatLng(lat, lng), zoomLevel);
					SendtoGoogleSheet(lat, lng);
					//map.flyTo(new L.LatLng(lat, lng), zoomLevel);
					theMarker = L.marker([lat, lng]).addTo(map);
				prevLat = lat;
				prevLong = lng;
		//prevLat = lat;
		//prevLong = lng;
	function SendtoGoogleSheet(Lat, Lng){
	  const Http = new XMLHttpRequest();
		const url='https://docs.google.com/forms/d/e/1FAIpQLSdcyvFZC-Hw4fsx9qnQuoW-dgS8wmpoRtF_lvYjZAb3dBi-8g/formResponse?&submit=Submit?usp=pp_url&entry.1211826835=' + Lat + '&entry.972490377=' + Lng + '&entry.949707414=LoRaTracker1';
		Http.open("GET", url);
		Http.send();
		Http.onreadystatechange = (e) => {
		  console.log(Http.responseText);
		Http.onreadystatechange = function() {
	function isEmpty(value) {
	  return (
		(value == null) ||
		(value.hasOwnProperty('length') && value.length === 0) ||
		(value.constructor === Object && Object.keys(value).length === 0)
//var distance = getDistanceBetweenTwoPoints(51.5112139, -0.119824, 48.8567, 2.3508, 'K');
//round to 3 decimal places
//console.log(Math.round(distance*1000)/1000);  //displays 343.548
	function getDistanceBetweenTwoPoints(lat1, lon1, lat2, lon2, unit) {
	 if ((lat1 == lat2) && (lon1 == lon2)) {
		return 0;
	  else {
		var radlat1 = Math.PI * lat1/180;
		var radlat2 = Math.PI * lat2/180;
		var theta = lon1-lon2;
		var radtheta = Math.PI * theta/180;
		var dist = Math.sin(radlat1) * Math.sin(radlat2) + Math.cos(radlat1) * Math.cos(radlat2) * Math.cos(radtheta);
		if (dist > 1) {
		  dist = 1;
		dist = Math.acos(dist);
		dist = dist * 180/Math.PI;
		dist = dist * 60 * 1.1515;
		if (unit=="K") { dist = dist * 1.609344 }
		if (unit=="N") { dist = dist * 0.8684 }
		return dist;
	function onLocationFound(e) {
		//const radius = Math.round(e.accuracy / 2);
		//const locationMarker = L.marker(e.latlng,{icon: L.divIcon({className: 'poi', html: '<b>📱</b>'})}).addTo(map);
    const locationMarker = L.marker(e.latlng, {icon: PhoneIcon}).addTo(map)
      .bindPopup('Your location is: [' + e.latlng.lat + ', ' + e.latlng.lng + ']');
      phoneLat = e.latlng.lat;
      phoneLong= e.latlng.lng;
	  //.bindPopup(`You are within ${radius} meters from this point`);
		//const locationCircle = L.circle(e.latlng, radius).addTo(map);
	function onLocationError(e) {
		//alert('Please enable location permission in device settings and try again.');
		alert(e.message);
	map.on('locationfound', onLocationFound);
	map.on('locationerror', onLocationError);
	map.locate({setView: true, maxZoom: 16});
</script>
</body>
</html>
Your screenshot in the opening post shows that there is more in the error (^~~~~~~~~). Please copy the full output and paste it here using code tags.
Arduino: 1.8.18 (Windows 10), Board: "XIAO_ESP32C3, Enabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 160MHz (WiFi), QIO, 80MHz, 4MB (32Mb), 921600, None, Disabled"
In file included from C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:29:
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'void LoRaE5Class::init()':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.h:34:21: error: 'Serial2' was not declared in this scope
  #define SerialLoRa Serial2  //M5Stack ESP32 Camera Module Development Board
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:41:5: note: in expansion of macro 'SerialLoRa'
     SerialLoRa.begin(9600);    //For SAMD Variant and XIAO NRF
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.h:34:21: note: suggested alternative: 'Serial1'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'void LoRaE5Class::init(uint8_t, uint8_t)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:46:9: note: in expansion of macro 'SerialLoRa'
         SerialLoRa.begin(9600, SERIAL_8N1, rx, tx); //M5Stack ESP32 Camera Module Development Board
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'void LoRaE5Class::getVersion(char*, short int, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:55:16: note: in expansion of macro 'SerialLoRa'
         while (SerialLoRa.available()) SerialLoRa.read();
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'void LoRaE5Class::getId(char*, short int, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:63:16: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'bool LoRaE5Class::transferPacket(char*, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:262:12: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:265:38: note: in expansion of macro 'SerialLoRa'
     for (int i = 0; i < length; i++) SerialLoRa.write(buffer[i]);
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'bool LoRaE5Class::transferPacket(unsigned char*, unsigned char, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:292:12: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:297:9: note: in expansion of macro 'SerialLoRa'
         SerialLoRa.write(temp);
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'bool LoRaE5Class::transferPacketWithConfirmed(char*, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:318:12: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:321:38: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'bool LoRaE5Class::transferPacketWithConfirmed(unsigned char*, unsigned char, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:371:12: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:376:9: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'bool LoRaE5Class::transferProprietaryPacket(char*, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:487:12: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:490:38: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'bool LoRaE5Class::transferProprietaryPacket(unsigned char*, unsigned char, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:507:12: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:512:9: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'void LoRaE5Class::transferPacketP2PMode(char*)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:793:38: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'void LoRaE5Class::transferPacketP2PMode(unsigned char*, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:804:9: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'short int LoRaE5Class::receivePacketP2PMode(unsigned char*, short int, short int*, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:814:12: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'void LoRaE5Class::loraDebug()':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:885:13: note: in expansion of macro 'SerialLoRa'
             SerialLoRa.write(c);
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:887:13: note: in expansion of macro 'SerialLoRa'
         if (SerialLoRa.available()) SerialUSB.write(SerialLoRa.read());
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'void LoRaE5Class::sendCommand(const char*)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:922:5: note: in expansion of macro 'SerialLoRa'
     SerialLoRa.print(command);
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'void LoRaE5Class::sendCommand(const __FlashStringHelper*)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:926:5: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'short int LoRaE5Class::readBuffer(char*, short int, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:938:20: note: in expansion of macro 'SerialLoRa'
             while (SerialLoRa.available()) {
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'short int LoRaE5Class::readLine(char*, short int, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:961:20: note: in expansion of macro 'SerialLoRa'
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp: In member function 'short int LoRaE5Class::waitForResponse(char*, unsigned char)':
C:\Users\User\Documents\Arduino\libraries\LoRaE5-main\LoRaE5.cpp:984:13: note: in expansion of macro 'SerialLoRa'
         if (SerialLoRa.available()) {
Multiple libraries were found for "WiFi.h"
 Used: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.8\libraries\WiFi
 Not used: C:\Users\User\Documents\Arduino\libraries\WiFi
exit status 1
option enabled in File -> Preferences.
Disclaimer: not familiar with your board (or ESP32 boards in general), also not familiar with LoRa.
Which library are you using? I think it is GitHub - idreamsi/LoRaE5: Arduino library for working with the Seeed Studio Wio-E5 Wireless Module. but please confirm.
The error seems clear to me, your board does not have a Serial2. I suspect that you have to hack the library.
For the linked library, file LoraE5.h
#if defined(ESP32)
#else
	#define SerialLoRa Serial1		//For SAMD Variant and XIAO NRF
#endif
If you change Serial2 to Serial1 the p2p_rx example that comes with the linked library will compile.
If it suites your needs is something else.
Where did you get your code from? If you would have compiled the examples that come with the library that you use I'm sure that you would have realised earlier that your code would not compile.
