Error compiling for ESP32
Sketch uses 1314058 bytes (100%) of program storage space. Maximum is 1310720 bytes.text section exceeds available space in board
Global variables use 51780 bytes (15%) of dynamic memory, leaving 275900 bytes for local variables. Maximum is 327680 bytes.
Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
Error compiling for board ESP32 Dev Module.
Can someone help me with this Error? under is the code. I am trying things but nothing is working... :frowning:
#include <ThingSpeak.h> // add librery
#include <WiFi.h>
#include "BluetoothSerial.h"
BluetoothSerial SerialBT;
WiFiClient client;
unsigned long counterChannelNumber = 1; // Channel ID
const char * myCounterReadAPIKey = ""; // Read API Key
const int FieldNumber1 = 1; // The field you wish to read
String ssid_pass;
char *SSID1 = "";
char *PASS = "";
String ssid;
String pass;
const int LED1 = 12;
const int LED_BT = 13;
const int SW = 14;
bool flag = false;
pinMode(LED1,OUTPUT);
pinMode(LED_BT,OUTPUT);
pinMode(SW,INPUT_PULLUP);
WiFi.begin(SSID1, PASS); // write wifi name & password
Serial.print("Connecting");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.print("Connected, IP address: ");
ThingSpeak.begin(client);
if(!SerialBT.begin("ESP32"))
Serial.println("An error occurred initializing Bluetooth");
digitalWrite(LED_BT, LOW);
int input = digitalRead(SW);
Serial.print("input: ");Serial.println(input);
if(input == 0)
delay(50);
flag = true;
digitalWrite(LED_BT, HIGH);
while(flag == true)
while(SerialBT.available())
  ssid_pass = SerialBT.readString();
  //Serial.write(SerialBT.read());
  Serial.println(ssid_pass);
  for (int i = 0; i < ssid_pass.length(); i++)
    if (ssid_pass.substring(i, i+1) == ",")
      ssid = ssid_pass.substring(0, i);
      pass = ssid_pass.substring(i+1);
      Serial.print("SSID = ");Serial.println(ssid);
      Serial.print("Password = ");Serial.println(pass);
      delay(2000);
      flag = false;
      int n1 = ssid.length();
char char_array1[n1 + 1];
strcpy(char_array1, ssid.c_str());
int n2 = pass.length();
char char_array2[n2 + 1];
strcpy(char_array2, pass.c_str());
WiFi.begin(char_array1, char_array2);                 // write wifi name & password
  Serial.print(".");
int A = ThingSpeak.readLongField(counterChannelNumber, FieldNumber1, myCounterReadAPIKey);
Serial.println(A);
digitalWrite(LED1,A);
Welcome to the forum
Use [color = red]code tags[/color] (the </> icon above the compose window) to make it easier to read and copy for examination
The ESP32 only has ONE, 1 wireless transmitter.
BT and WiFi are loaded to core number 0.
The BT code takes up about 50% of the RAM available to core0. WiFi takes up about 50% of the ram available to core0. Then add in BT and WiFi stack space and you run out of RAM for core0.
Under Tools->Partition Scheme pick something other than the default (1.2MB APP, 1.5MB SPIFFS).
I would try "Minimal SPIFFS" which will give you 1.9MB of program space instead of 1.2MB.
