Hello everyone, I want to compile this modified version of multiwii.
First of all, after I unzip the archive, When I want to open "MultiWii_2.4.2.ino", Arduino IDE tells me that it should be in a folder with "MultiWii_2.4.2" name, and I click on yes, and then I move all other files to the newly created folder.
Then in the config.h file, these are the changes that I do:
*Commenting this line: #define QUADX
*Uncommenting this line: #define FLYING_WING
*Uncommenting this line: #define GY_521
And I choose Arduino Nano as my board from tools menu of Arduino IDE
And I get this error message when I want to compile the code:
redefinition of 'void __vector_14()'
Here is the complete message:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\erfan\AppData\Local\Arduino15\packages -hardware C:\Users\erfan\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\erfan\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\erfan\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10815 -build-path C:\Users\erfan\AppData\Local\Temp\arduino_build_508139 -warnings=none -build-cache C:\Users\erfan\AppData\Local\Temp\arduino_cache_155457 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\erfan\Desktop\MultiWii-Nrf24l01-SingleBoard-main\MultiWii-Nrf24l01-SingleBoard-main\MultiWii+Nrf+BMP280\MultiWii_2.4.2\MultiWii_2.4.2.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\erfan\AppData\Local\Arduino15\packages -hardware C:\Users\erfan\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\erfan\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\erfan\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10815 -build-path C:\Users\erfan\AppData\Local\Temp\arduino_build_508139 -warnings=none -build-cache C:\Users\erfan\AppData\Local\Temp\arduino_cache_155457 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\erfan\Desktop\MultiWii-Nrf24l01-SingleBoard-main\MultiWii-Nrf24l01-SingleBoard-main\MultiWii+Nrf+BMP280\MultiWii_2.4.2\MultiWii_2.4.2.ino
Using board 'nano' from platform in folder: C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "C:\\Users\\erfan\\AppData\\Local\\Temp\\arduino_build_508139\\sketch\\MultiWii_2.4.2.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\Alarms.cpp
Using cached library dependencies for file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\EEPROM.cpp
Using cached library dependencies for file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\GPS.cpp
Using cached library dependencies for file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\IMU.cpp
Using cached library dependencies for file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\LCD.cpp
Using cached library dependencies for file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\MultiWii.cpp
Using cached library dependencies for file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\NRF24_RX.cpp
Alternatives for RF24.h: [RF24@1.4.1 RF24-master@1.1.5]
ResolveLibrary(RF24.h)
-> candidates: [RF24@1.4.1 RF24-master@1.1.5]
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "-IC:\\Users\\erfan\\Documents\\Arduino\\libraries\\RF24" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\SPI\\src" "C:\\Users\\erfan\\AppData\\Local\\Temp\\arduino_build_508139\\sketch\\Output.cpp" -o nul
Using cached library dependencies for file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\Protocol.cpp
Using cached library dependencies for file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\RX.cpp
Using cached library dependencies for file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\Sensors.cpp
Using cached library dependencies for file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\Serial.cpp
"C:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "-IC:\\Users\\erfan\\Documents\\Arduino\\libraries\\RF24" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\SPI\\src" "-IC:\\Users\\erfan\\Documents\\Arduino\\libraries\\RF24\\utility" "C:\\Users\\erfan\\Documents\\Arduino\\libraries\\RF24\\RF24.cpp" -o nul
"C:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "-IC:\\Users\\erfan\\Documents\\Arduino\\libraries\\RF24" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\SPI\\src" "C:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\SPI\\src\\SPI.cpp" -o nul
Generating function prototypes...
"C:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "-IC:\\Users\\erfan\\Documents\\Arduino\\libraries\\RF24" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\SPI\\src" "C:\\Users\\erfan\\AppData\\Local\\Temp\\arduino_build_508139\\sketch\\MultiWii_2.4.2.ino.cpp" -o "C:\\Users\\erfan\\AppData\\Local\\Temp\\arduino_build_508139\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\erfan\\AppData\\Local\\Temp\\arduino_build_508139\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "-IC:\\Users\\erfan\\Documents\\Arduino\\libraries\\RF24" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\SPI\\src" "C:\\Users\\erfan\\AppData\\Local\\Temp\\arduino_build_508139\\sketch\\MultiWii_2.4.2.ino.cpp" -o "C:\\Users\\erfan\\AppData\\Local\\Temp\\arduino_build_508139\\sketch\\MultiWii_2.4.2.ino.cpp.o"
Using previously compiled file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\NRF24_RX.cpp.o
Using previously compiled file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\LCD.cpp.o
Using previously compiled file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\MultiWii.cpp.o
"C:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\cores\\arduino" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\variants\\eightanaloginputs" "-IC:\\Users\\erfan\\Documents\\Arduino\\libraries\\RF24" "-IC:\\Users\\erfan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.3\\libraries\\SPI\\src" "C:\\Users\\erfan\\AppData\\Local\\Temp\\arduino_build_508139\\sketch\\Output.cpp" -o "C:\\Users\\erfan\\AppData\\Local\\Temp\\arduino_build_508139\\sketch\\Output.cpp.o"
Using previously compiled file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\Alarms.cpp.o
Using previously compiled file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\EEPROM.cpp.o
Using previously compiled file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\IMU.cpp.o
Using previously compiled file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\GPS.cpp.o
Using previously compiled file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\RX.cpp.o
Using previously compiled file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\Sensors.cpp.o
Using previously compiled file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\Protocol.cpp.o
Using previously compiled file: C:\Users\erfan\AppData\Local\Temp\arduino_build_508139\sketch\Serial.cpp.o
In file included from C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino/Arduino.h:30:0,
from C:\Users\erfan\Desktop\MultiWii-Nrf24l01-SingleBoard-main\MultiWii-Nrf24l01-SingleBoard-main\MultiWii+Nrf+BMP280\MultiWii_2.4.2\Output.cpp:1:
C:\Users\erfan\Desktop\MultiWii-Nrf24l01-SingleBoard-main\MultiWii-Nrf24l01-SingleBoard-main\MultiWii+Nrf+BMP280\MultiWii_2.4.2\Output.cpp: In function 'void __vector_14()':
Output.cpp:1013:27: error: redefinition of 'void __vector_14()'
#define SOFT_PWM_ISR2 TIMER0_COMPA_vect
C:\Users\erfan\Desktop\MultiWii-Nrf24l01-SingleBoard-main\MultiWii-Nrf24l01-SingleBoard-main\MultiWii+Nrf+BMP280\MultiWii_2.4.2\Output.cpp:1074:9: note: in expansion of macro 'SOFT_PWM_ISR2'
ISR(SOFT_PWM_ISR2) {
C:\Users\erfan\Desktop\MultiWii-Nrf24l01-SingleBoard-main\MultiWii-Nrf24l01-SingleBoard-main\MultiWii+Nrf+BMP280\MultiWii_2.4.2\Output.cpp:760:25: note: 'void __vector_14()' previously defined here
#define SERVO_ISR TIMER0_COMPA_vect
C:\Users\erfan\Desktop\MultiWii-Nrf24l01-SingleBoard-main\MultiWii-Nrf24l01-SingleBoard-main\MultiWii+Nrf+BMP280\MultiWii_2.4.2\Output.cpp:932:7: note: in expansion of macro 'SERVO_ISR'
ISR(SERVO_ISR) {
Multiple libraries were found for "RF24.h"
Used: C:\Users\erfan\Documents\Arduino\libraries\RF24
Not used: C:\Users\erfan\Documents\Arduino\libraries\RF24-master
Using library RF24 at version 1.4.1 in folder: C:\Users\erfan\Documents\Arduino\libraries\RF24
Using library SPI at version 1.0 in folder: C:\Users\erfan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\SPI
exit status 1
I couldn't understand what is wrong.
Thank you so much in advance for your help.
