Error compiling nodemcu with IFTTT webhook library
Hello there,
I am working on a project that sends a notification to your phone if your plant needs watering using nodemcu and IFTTT and its app.
However, when I try to compile I get this error message :
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
This was not highlighted in the error message but the font color was red :
C:\Users\jehad\Desktop\Documents\Arduino\libraries\ESP8266Webhook-master\ESP8266Webhook.cpp: In member function 'int Webhook::trigger(String, String, String)':
C:\Users\jehad\Desktop\Documents\Arduino\libraries\ESP8266Webhook-master\ESP8266Webhook.cpp:48:13: error: call to 'HTTPClient::begin' declared with attribute error: obsolete API, use ::begin(WiFiClient, url)
   48 |   http.begin("http://maker.ifttt.com/trigger/"+_event_name+"/with/key/"+_api_key+"?value1="+value_1+"&value2="+value_2+"&value3="+value_3);
From my knowledge I think there is something wrong with the webhook library, I'm not sure.
Here is the code :
#include <ESP8266Webhook.h>
#include <ESP8266WiFi.h>
#define _SSID "private info"      // Your WiFi SSID
#define _PASSWORD "private info"  // Your WiFi Password
#define KEY "private info"        // Webhooks Key
#define EVENT "plant_watering"      // Webhooks Event Name
Webhook webhook(KEY,EVENT);
#define sensorpin A0
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  // Connect to WiFi
  Serial.print("Connecting to: ");
  Serial.println(_SSID);
  WiFi.begin(_SSID, _PASSWORD);
    Serial.print("-");
  Serial.println("");
  Serial.println("WiFi Connected");
  // Print the IP address
  Serial.print("Use this URL to connect: ");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
  digitalWrite(LED_BUILTIN, HIGH);
analogRead(sensorpin);
if (analogRead(sensorpin)>750) {
  webhook.trigger();
delay(36000000);
Help or advice is very much appreciated.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
The webhook library used an older version of the ESP8266 libraries. You can fix it by passing the WiFiClient as a new first argument to HTTPClient::begin() (http.begin()).
Thank you very much, the code compiled successfully.
