Error compilling for board NodeMCU 1.0 (ESP-12E Module)
I changed my PC and copied my files on it, and it wasnt compiling again.This was the message i got during compilation. I don't understand what's really happening please.
Arduino: 1.8.19 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\MIKE\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\MIKE\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\MIKE\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10819 -build-path C:\Users\MIKE\AppData\Local\Temp\arduino_build_303238 -warnings=none -build-cache C:\Users\MIKE\AppData\Local\Temp\arduino_cache_335964 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python3.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mkspiffs-3.1.0-gcc10.3-e5f9fec.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.1.0-gcc10.3-e5f9fec.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs-3.1.0-gcc10.3-e5f9fec.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -verbose C:\Users\MIKE\Documents\Arduino\Server_Control_Servor\Server_Control_Servor.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\MIKE\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\MIKE\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\MIKE\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10819 -build-path C:\Users\MIKE\AppData\Local\Temp\arduino_build_303238 -warnings=none -build-cache C:\Users\MIKE\AppData\Local\Temp\arduino_cache_335964 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python3.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mkspiffs-3.1.0-gcc10.3-e5f9fec.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.1.0-gcc10.3-e5f9fec.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs-3.1.0-gcc10.3-e5f9fec.path=C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -verbose C:\Users\MIKE\Documents\Arduino\Server_Control_Servor\Server_Control_Servor.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
Using core 'esp8266' from platform in folder: C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
"C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/mkbuildoptglobals.py" "C:\Program Files (x86)\Arduino" 10819 "C:\Users\MIKE\AppData\Local\Temp\arduino_build_303238" "C:\Users\MIKE\AppData\Local\Temp\arduino_build_303238/core/build.opt" "C:\Users\MIKE\Documents\Arduino\Server_Control_Servor/Server_Control_Servor.ino.globals.h" "C:\Users\MIKE\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266/CommonHFile.h"
exit status -1073741819
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
Did you have version 3.1.2 installed on your old computer ?
No. It must have been an earlier version. I cant remember the version.
Then I suggest you try compiling blink. If this works, you could try version 2.7.4 for example.
this error occured while compiling the blink example : The directory name is invalid.
c:\program files\common files\system\symsrv.dll.000
Access is denied.
A Windows user could help more than me.
