Upload NodeMCU 1.0 board (ESP-12E module)
Good morning
I have a problem with a NodeMCU 1.0 board (ESP-12E module): it works normally in the Arduino IDE, but I can't upload to the board via USB in Arduino Cloud.
Thank you
If it uploads fine from the IDE, the board and driver are OK. Cloud Editor can't touch USB by itself, it goes through the Arduino Cloud Agent. Check three things:
  1. Agent is installed and actually running (tray icon). If the editor doesn't show a port, reinstall the agent and restart the browser.
  2. Close Arduino IDE and any serial monitor first. Only one program can hold the COM port, and the IDE usually wins.
  3. Board is set to "NodeMCU 1.0 (ESP-12E Module)" in the Cloud Editor and the port it shows is the same COM number the IDE uses.
If it still fails, post the exact error from the Cloud Editor console. "Can't upload" covers about ten different problems.
Hi @proclimac. I confirm there is currently a bug in Arduino Cloud IoT that makes it impossible to upload to ESP8266 and ESP32-based Devices.
I apologize for any inconvenience this has caused.
The problem has been reported to the Arduino Cloud developers and they are working to get it fixed soon. I'll post an update here if I receive any news from them on the subject.
Hello again @proclimac. The bug in Arduino Cloud has been fixed.
Please try again. Hopefully everything will work as expected now.
Just let us know if you still encounter any problems using Arduino Cloud.
