I have two files in my sketch folder: sketch.ino and sub.c
My .ino file looks like this:
#include "sub.c" void setup(){ doSetup(); } void loop() { }
My sub.c file looks like this:
#include "util/delay.h" void doSetup(); void doSetup() { delayMicroseconds(1000); }
But when I compile I get the following error:
lcd.c:48: error: 'delayMicroseconds' was not declared in this scope
What am I doing wrong?
Try to add #include "Arduino.h" into your sub.c
Worked like a charm, thank you!
Pito's answer works, but more importantly, do you understand why it works? Also, the #include directive was never intended to be used with source code files (e.g., .c). Instead, #include preprocessor directives should be used with header files (.h).
Rename sub.c to sub.cpp, remove the #include of sub.c from sketch.ino, restart the IDE and try again.
Pete
