Error: Expected primary-expression before ',' token
hello there. Im currently working on my university project. Im working on a smart traffic light that can indicate the traffic. Right now im stucked on the coding and i cant seem to understand the error. Help me pls :frowning:
here is the code where there is an error
void set3()
  lcd.setCursor(colx, 0);
  lcd.print("NA ");
  lcd.setCursor(colx, 1);
  lcd.print("OK!!");
here is the error
error: expected primary-expression before ',' token
jajel:73: error: expected primary-expression before ',' token
Your error is more than likely caused by some code that you have not shown. Please provide your complete code.
sorry for that. here is my full code
#define colx
#include <LiquidCrystal.h>
int inputPin1 = 9;              //choose the input pin (for PIR1 sensor)
int inputPin = 8;               // choose the input pin (for PIR sensor)
int pirState = LOW;             // we start, assuming no motion detected
int sensor1, sensor2;
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
int val = 0;                    // variable for reading the pin status
int val1 = 0;
  pinMode(sensor1, INPUT);
  pinMode(sensor2, INPUT);
  lcd.begin (16, 2);
  lcd.setCursor(0, 0);
  lcd.print("Sensor1:");
  lcd.setCursor(0, 1);
  lcd.print("Sensor2:");
void set1()
  lcd.print("OK!!");
  lcd.print("OK!!");
void set2()
  lcd.print("OK!!");
  lcd.print("NA ");
void set3()
  lcd.print("NA ");
  lcd.print("OK!!");
void default()
  lcd.print("NA ");
  lcd.print("NA ");
void set1()
  lcd.print("OK!!");
  lcd.print("OK!!");
void set2()
  lcd.print("OK!!");
  lcd.print("NA ");
void set3()
  lcd.print("NA ");
  lcd.print("OK!!");
void default()
  lcd.print("NA ");
  lcd.print("NA ");
  int senread1 = digitalRead(sensor1);
  int senread2 = digitalRead(sensor2);
  if (senread1 == HIGH && senread2 == HIGH )
    set1();
  else if (senread1 == !HIGH && senread2 == HIGH )
    set2();
  else if (senread1 == HIGH && senread2 == !HIGH )
    set3();
    default();
  delay(1);
Delta_G:
#define colx
You've defined colx as nothing. #define things get replaces before compilation. So that line when the compiler sees it looks like
lcd.setCursor( , 0);
And now you see the error
YOU ARE MY HERO MAN. That did the trick. Thank you thank you thank you thank you
(deleted)
