Error - expected primary expression
hello, I'm new to the forum can you please check errors for this code?
// include the library
#include <LiquidCrystal.h>
#include <Time.h>
#include <TimeLib.h>
#include <EEPROM.h>
#include <Arduino.h>
#include <Wire.h>
String months[12] = { "January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December" };
String dayofweek[7] = { "Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday" };
String setModes[6] = { "Seconds", "Minutes", "Hours", "Date", "Month", "Year" };
unsigned long setTimeInt[6] = { 1, 60, 3600, 3600 * 24, 2629743, 31556926 };
int setMode = 0;
tmElements_t my_time;   // time elements structure
time_t unix_timestamp;  // a timestamp
#define TIME_MSG_LEN 11  // time sync to PC is HEADER and unix time_t as ten ascii digits
#define TIME_HEADER 255  // Header tag for serial time sync message
#define TIME_HEADER "T"  // Header tag for serial time sync message
#define TIME_REQUEST 7   // ASCII bell character requests a time sync message
String zero = "0";
String one = "1";
String two = "2";
String three = "3";
String four = "4";
String five = "5";
String six = "6";
String seven = "7";
String eight = "8";
String nine = "9";
int Tmonth = month();
String date = String(((day() / 10) % 10)) + String((day() % 10));
String yearLib = String(((year() / 1000) % 10)) + String(((year() / 100) % 10)) + String(((year() / 10) % 10)) + String((year() % 10));
void convertUnixTime() {
  my_time.Second = second();
  my_time.Hour = hour();
  my_time.Minute = minute();
  my_time.Day = day();
  my_time.Month = month();
  my_time.Year = year() - 1970;  // years since 1970, so deduct 1970
  unix_timestamp = makeTime(my_time);
  Tmonth = month();
// initialize the interface pins
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
void digitalClockDisplay() {
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
  Serial.print(" ");
  Serial.println("A),A1,A2 ");
  Serial.print(digitalRead(A0));
  Serial.print(" ");
  Serial.print(digitalRead(A1));
  Serial.print(" ");
  Serial.print(digitalRead(A2));
  Serial.print(" ");
  Serial.println("Set Time: " + setModes[setMode % 6]);
void printDigits(int digits) {
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if (digits < 10)
    Serial.print('0');
  Serial.print(digits);
void processSyncMessage() {
  unsigned long pctime;
  const unsigned long DEFAULT_TIME = 1357041600;  // Jan 1 2013
  if (Serial.find(TIME_HEADER)) {
    pctime = Serial.parseInt();
    if (pctime >= DEFAULT_TIME) {  // check the integer is a valid time (greater than Jan 1 2013)
      setTime(pctime);             // Sync Arduino clock to the time received on the serial port
time_t requestSync() {
  Serial.write(TIME_REQUEST);
  return 0;  // the time will be sent later in response to serial mesg
void eepromSetDateTime(int hours, int minutes, int seconds, int date, int month, int year) {
  EEPROM.write(0, hours);
  EEPROM.write(1, minutes);
  EEPROM.write(2, seconds);
  EEPROM.write(3, date);
  EEPROM.write(4, month);
  EEPROM.write(5, year);
void changeMode() {
  lcd.clear();
  setMode = setMode + 1;
  while (digitalRead(A2) == HIGH) {
    eepromSetDateTime(hour(), minute(), second(), day(), month(), year());
    lcd.setCursor(0,0);
    lcd.print("Set Time: " + setModes[setMode % 6]);
    lcd.setCursor(0, 1);
  lcd.print( String(dayofweek[dayOfWeek(unix_timestamp + ()) % 7]) + ", " + String(((hour() / 10) % 10)) + String((hour() % 10)) + ":" + String(((minute() / 10) % 10)) + String((minute() % 10)) + ":" + String(((second() / 10) % 10)) + String((second() % 10)) );
  lcd.setCursor(0, 2);
  lcd.print(months[Tmonth - 1] + " " + String(((day() / 10) % 10)) + String((day() % 10)) + ", " + String(((year() / 1000) % 10)) + String(((year() / 100) % 10)) + String(((year() / 10) % 10)) + String((year() % 10)));
//SETUP
  lcd.begin(20, 4, "LCD_5x8DOTS");
  lcd.clear();
  convertUnixTime();
  setTime(EEPROM.read(0), EEPROM.read(1), EEPROM.read(2), EEPROM.read(3), EEPROM.read(4), EEPROM.read(5));
  lcd.setCursor(4, 0);
  lcd.print("Initializing");
  lcd.setCursor(6, 1);
  lcd.print("Clock...");
  delay(1500);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Your clock seems to");
  lcd.print("be out of date");
  lcd.print("Please set the clock");
  lcd.setCursor(0, 3);
  lcd.print("NOW");
  delay(3500);
  lcd.clear();
//LOOP
  //set time feature
  if (digitalRead(A1) == HIGH) {
    setMode = 0;
    lcd.clear();
    while (digitalRead(A1) == HIGH) {
      lcd.setCursor(0,1);
  lcd.setCursor(0,2);
      //changes set time mode
      if (digitalRead(A2) == HIGH) {
        changeMode();
    //increments time
    if (digitalRead(A0) == HIGH) {
      if (setTimeInt[setMode % 6] > 10000) {
        for (int x = 0; x < (setTimeInt[setMode % 6] / 3600); x++) {
          unix_timestamp = unix_timestamp + 3600;
        unix_timestamp = unix_timestamp + setTimeInt[setMode % 6];
        setTime(unix_timestamp);
    lcd.clear();
    while (digitalRead(A0) == HIGH) {
      lcd.setCursor(0,0);
      lcd.setCursor(0,1));
  lcd.setCursor(0,2);
      //shows the TIME
    lcd.clear();
  //end
  convertUnixTime();
  if (Serial.available()) {
    processSyncMessage();
    lcd.clear();
    convertUnixTime();
  if (timeStatus() != timeNotSet) {
    digitalClockDisplay();
    convertUnixTime();
  lcd.setCursor(0,0);
lcd.setCursor(0,1);
  lcd.setCursor(0,2);
Welcome to the forum
Split from an unrelated topic
@arduino_guy9212 Do not hijack old topics
Hello arduino_guy9212
Welcome to the best Arduinoforum ever.
Post the error code provided by the IDE.
Does it compile? If not, paste entire error message. If it does compile, then please describe, clearly and completely, what it is doing, and what you think it should be doing.
Thanks
sry i just fix the error -- but my LCD display wont work even though my code is right, no errors, and the hardware wiring if correct.
#include <Time.h>
#include <EEPROM.h>
#include <Wire.h>
unsigned long setTimeInt[6] = { 1, 60, 3600, 86400 , 2629743, 31556926 };
int setMode = 0;
String zero = "0";
String one = "1";
String two = "2";
String three = "3";
String four = "4";
String five = "5";
String six = "6";
String seven = "7";
String eight = "8";
String nine = "9";
String stringTime = dayofweek[dayOfWeek(unix_timestamp % 7)] + ", " + String((hour() / 10) % 10) + String((hour() % 10)) + ":" + String(((minute() / 10) % 10)) + String((minute() % 10)) + ":" + String(((second() / 10) % 10)) + String((second() % 10));
String stringDate = months[Tmonth - 1] + " " + String(((day() / 10) % 10)) + String((day() % 10)) + ", " + String(((year() / 1000) % 10)) + String(((year() / 100) % 10)) + String(((year() / 10) % 10)) + String((year() % 10));
void updateTime() {
 stringTime =dayofweek[ dayOfWeek(unix_timestamp  % 7 )] + ", " + String((hour() / 10) % 10) + String((hour() % 10)) + ":" + String(((minute() / 10) % 10)) + String((minute() % 10)) + ":" + String(((second() / 10) % 10)) + String((second() % 10));
  Tmonth = month();
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print("A0,A1,A2 ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print("setTimeInt = " + String(setTimeInt[setMode % 6]));
  Serial.println(" SetMode mod 6 = " + String(setMode % 6));
  Serial.print(":");
  if (digits < 10)
    Serial.print('0');
void changeMode() {
lcd.begin(20, 4 ,LCD_5x8DOTS);
updateTime();
  lcd.clear();
    lcd.print(stringTime);
    lcd.print(stringDate);
//SETUP
  lcd.begin(20, 4);
  lcd.clear();
  convertUnixTime();
  delay(1500);
  lcd.clear();
  lcd.print("NOW");
  delay(3500);
  lcd.clear();
//LOOP
updateTime();
setMode = 1;
  //set time feature
    updateTime();
    setMode = 0;
    lcd.clear();
updateTime();
        changeMode();
    //increments time
    lcd.clear();
      updateTime();
      //shows the TIME
    //end of whileA0
    lcd.clear();
  //end
updateTime();
  convertUnixTime();
    lcd.clear();
    convertUnixTime();
    convertUnixTime();
and also i know its not broken because it worked like before my first reply here.
Clearly, your code is not "right"; it may compile, but if it were "right" you'd be done and gone. So, please describe what it is doing that is not correct.
Also, if you got this code somewhere, and have modified it, please point to the source code.
Tell us what section you were last working on, since you think it worked before.
New code [i will explain after this reply]:
  #include <Time.h>
  #include <EEPROM.h>
  #include <Wire.h>
  int setMode = 0;
  String zero = "0";
  String one = "1";
  String two = "2";
  String three = "3";
  String four = "4";
  String five = "5";
  String six = "6";
  String seven = "7";
  String eight = "8";
  String nine = "9";
  void updateTime() {
    Tmonth = month();
  const int rs = 12, en = 11, rw = 10, d0 = 9, d1 = 8, d2 = 7, d3 = 6, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
  LiquidCrystal lcd(rs, en, rw, d0, d1, d2, d3, d4, d5, d6, d7);
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(":");
    if (digits < 10)
      Serial.print('0');
  void changeMode() {
  lcd.begin(20, 4 ,LCD_8BITMODE);
  updateTime();
    lcd.clear();
  //SETUP
    lcd.begin(20,4,LCD_5x8DOTS  );
    lcd.clear();
    convertUnixTime();
    delay(1500);
    lcd.clear();
    lcd.print("NOW");
    delay(3500);
    lcd.clear();
  //LOOP
  updateTime();
  setMode = 1;
    //set time feature
      updateTime();
      setMode = 0;
      lcd.clear();
  updateTime();
          changeMode();
      //increments time
      lcd.clear();
        updateTime();
        //shows the TIME
      //end of whileA0
      lcd.clear();
    //end
  updateTime();
    convertUnixTime();
      lcd.clear();
      convertUnixTime();
      convertUnixTime();
Order of functions
  1. Sets variables for LCD and Clock
  2. Initializes LCD [I am using a 20x4 Green 5x8dots, also i forgot to replace 5x8 with 8bitmode]
  3. Prepares functions
  4. Shows message that clock is initializing
  5. shows clock
    -while that is happening, it checks if the switch to set the time is on[A1]
    --checks if A0[increment] is on, then increments it by the nth[setMode] value in the array
    --checks if A2[change mode] is on, then increments the setMode variable
Product: Circuitrocks Nano CH340
Configuration: Nano, ATmega328p Old Bootloader
then this error code:
FQBN: arduino:avr:nano:cpu=atmega328old
Using board 'nano' from platform in folder: C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\sketch\LCD-Clock.ino.cpp -o nul
Alternatives for LiquidCrystal.h: [LiquidCrystal@1.0.7 LiquidCrystal@1.0.7]
ResolveLibrary(LiquidCrystal.h)
  -> candidates: [LiquidCrystal@1.0.7 LiquidCrystal@1.0.7]
C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\LiquidCrystal\src C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\sketch\LCD-Clock.ino.cpp -o nul
Alternatives for TimeLib.h: [Time@1.6.1]
ResolveLibrary(TimeLib.h)
  -> candidates: [Time@1.6.1]
C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\LiquidCrystal\src -IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\Time C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\sketch\LCD-Clock.ino.cpp -o nul
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
  -> candidates: [EEPROM@2.0]
C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\LiquidCrystal\src -IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\Time -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM\src C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\sketch\LCD-Clock.ino.cpp -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\LiquidCrystal\src -IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\Time -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM\src -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\sketch\LCD-Clock.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\ZombieArmor9212\Documents\Arduino\libraries\LiquidCrystal\src\LiquidCrystal.cpp
Using cached library dependencies for file: C:\Users\ZombieArmor9212\Documents\Arduino\libraries\Time\DateStrings.cpp
Using cached library dependencies for file: C:\Users\ZombieArmor9212\Documents\Arduino\libraries\Time\Time.cpp
Using cached library dependencies for file: C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\utility\twi.c
Generating function prototypes...
C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\LiquidCrystal\src -IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\Time -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM\src -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\sketch\LCD-Clock.ino.cpp -o C:\Users\ZombieArmor9212\AppData\Local\Temp\2586378243\sketch_merged.cpp
C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\ZombieArmor9212\AppData\Local\Temp\2586378243\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\ZombieArmor9212\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\ZombieArmor9212\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\ZombieArmor9212\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\ZombieArmor9212\\Documents\\Arduino\\libraries\\LiquidCrystal\\src" "-IC:\\Users\\ZombieArmor9212\\Documents\\Arduino\\libraries\\Time" "-IC:\\Users\\ZombieArmor9212\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\ZombieArmor9212\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286\\sketch\\LCD-Clock.ino.cpp" -o "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286\\sketch\\LCD-Clock.ino.cpp.o"
Compiling libraries...
Compiling library "LiquidCrystal"
Using previously compiled file: C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\libraries\LiquidCrystal\LiquidCrystal.cpp.o
Compiling library "Time"
Using previously compiled file: C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\libraries\Time\DateStrings.cpp.o
Using previously compiled file: C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\libraries\Time\Time.cpp.o
Compiling library "EEPROM"
Compiling library "Wire"
Using previously compiled file: C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\libraries\Wire\utility\twi.c.o
Using previously compiled file: C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\libraries\Wire\Wire.cpp.o
Compiling core...
Using precompiled core: C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\cores\arduino_avr_nano_cpu_atmega328old_1ae55d1f58e9e3fa5b67e1bbc72f629f\core.a
Linking everything together...
"C:\\Users\\ZombieArmor9212\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.elf" "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286\\sketch\\LCD-Clock.ino.cpp.o" "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286\\libraries\\LiquidCrystal\\LiquidCrystal.cpp.o" "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286\\libraries\\Time\\DateStrings.cpp.o" "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286\\libraries\\Time\\Time.cpp.o" "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286/..\\..\\cores\\arduino_avr_nano_cpu_atmega328old_1ae55d1f58e9e3fa5b67e1bbc72f629f\\core.a" "-LC:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286" -lm
"C:\\Users\\ZombieArmor9212\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.elf" "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.eep"
"C:\\Users\\ZombieArmor9212\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.elf" "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.hex"
Multiple libraries were found for "LiquidCrystal.h"
  Used: C:\Users\ZombieArmor9212\Documents\Arduino\libraries\LiquidCrystal
  Not used: C:\Users\ZombieArmor9212\AppData\Local\Arduino15\libraries\LiquidCrystal
Using library LiquidCrystal at version 1.0.7 in folder: C:\Users\ZombieArmor9212\Documents\Arduino\libraries\LiquidCrystal
Using library Time at version 1.6.1 in folder: C:\Users\ZombieArmor9212\Documents\Arduino\libraries\Time
Using library EEPROM at version 2.0 in folder: C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM
Using library Wire at version 1.0 in folder: C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
"C:\\Users\\ZombieArmor9212\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\ZombieArmor9212\\AppData\\Local\\Temp\\arduino\\sketches\\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.elf"
Sketch uses 12386 bytes (40%) of program storage space. Maximum is 30720 bytes.
Global variables use 997 bytes (48%) of dynamic memory, leaving 1051 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM3" -b57600 -D "-Uflash:w:C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf2
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf2
avrdude done.  Thank you.
Failed uploading: uploading error: exit status 1
No point in messing with your code, your Arduino is not connected. Check/change cables, try another Arduino, change USB ports if you can, all the usual drill.
my Arduino IS connected and I uploaded the code.
But the main problem is:
my stupid lcd is not showing anything, last time is was showing random gibberish
Okay, have it your way.
is definitive.
Perhaps someone else can convince you. I'm done.
It is not connected and you code didn't upload.
This message is prove for it:
alright but now i uploaded it but my stoopid LCD is not showing [and yes, i meant to spell stupid like that]
im uploading a video to my drive for proof
video: VID20231109192334.mp4 - Google Drive
Show the updated IDE message.
Programs do what the programmer wrote. If the display is not broken, then with the correct code it would work. If it doesn't work, then the code is incorrect. There is no other way.
if the code was incorrect, the compiler would give me an error
CODE
  #include <Time.h>
  #include <EEPROM.h>
  #include <Wire.h>
  int setMode = 0;
  String zero = "0";
  String one = "1";
  String two = "2";
  String three = "3";
  String four = "4";
  String five = "5";
  String six = "6";
  String seven = "7";
  String eight = "8";
  String nine = "9";
  void updateTime() {
    Tmonth = month();
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(" ");
    Serial.print(":");
    if (digits < 10)
      Serial.print('0');
  void changeMode() {
  updateTime();
    lcd.clear();
  //SETUP
    lcd.clear();
    convertUnixTime();
    delay(1500);
    lcd.clear();
    lcd.print("NOW");
    delay(3500);
    lcd.clear();
  //LOOP
  updateTime();
  setMode = 1;
    //set time feature
      updateTime();
      setMode = 0;
      lcd.clear();
  updateTime();
          changeMode();
      //increments time
      lcd.clear();
        updateTime();
        //shows the TIME
      //end of whileA0
      lcd.clear();
    //end
  updateTime();
    convertUnixTime();
      lcd.clear();
      convertUnixTime();
      convertUnixTime();
OUTPUT/LOG
C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\LiquidCrystal\src -IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\Time -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM\src -IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\sketch\LCD-Clock.ino.cpp -o C:\Users\ZombieArmor9212\AppData\Local\Temp\3589374516\sketch_merged.cpp
C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\ZombieArmor9212\AppData\Local\Temp\3589374516\sketch_merged.cpp
Compiling sketch...
"C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino" "-IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs" "-IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\LiquidCrystal\src" "-IC:\Users\ZombieArmor9212\Documents\Arduino\libraries\Time" "-IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM\src" "-IC:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src" "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\sketch\LCD-Clock.ino.cpp" -o "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\sketch\LCD-Clock.ino.cpp.o"
Compiling core...
"C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.elf" "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\sketch\LCD-Clock.ino.cpp.o" "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\libraries\LiquidCrystal\LiquidCrystal.cpp.o" "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\libraries\Time\DateStrings.cpp.o" "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\libraries\Time\Time.cpp.o" "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\libraries\Wire\Wire.cpp.o" "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286\libraries\Wire\utility\twi.c.o" "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286/..\..\cores\arduino_avr_nano_cpu_atmega328old_1ae55d1f58e9e3fa5b67e1bbc72f629f\core.a" "-LC:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286" -lm
"C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.elf" "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.eep"
"C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.elf" "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.hex"
"C:\Users\ZombieArmor9212\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.elf"
     Using Port                    : COM3
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : Arduino
     Description     : Arduino
     Hardware Version: 2
     Firmware Version: 1.16
     Vtarget         : 0.0 V
     Varef           : 0.0 V
     Oscillator      : Off
     SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\ZombieArmor9212\AppData\Local\Temp\arduino\sketches\B3F4984BBB25F53995F0867834B6E286/LCD-Clock.ino.hex"
avrdude: writing flash (12386 bytes):
Writing | ################################################## | 100% 3.34s
avrdude: 12386 bytes of flash written
This is wrong suggestion.
The compiler only looks for syntax errors. The situation when the code compiles but does not work is very typical. This means that there are logical errors in the code.
Identifying and correcting such errors is called debugging. Debugging often takes several times longer than writing code itself.
