Error getting location on NodeMcu ESP8266-12E using unwiredlabs api
I was trying to get the location of NodeMcu using unwiredlabs API obtained from www.unwiredlabs.com.
I referred this example: https://www.instructables.com/id/Location-Tracker-With-NodeMCU-ESP8266/ which is in ArduinoJson v5. I changed it to version v6. I compiled the below code, but it returned an error stated below :
#include <ESP8266HTTPClient.h>
#include  <ArduinoJson.h>
#include "ESP8266WiFi.h"
// your network SSID (name) & network password
char myssid[] = "your id";
char mypass[] = "your pass";
// unwiredlabs Hostname & Geolocation Endpoint url
const char* Host = "www.unwiredlabs.com";
String endpoint = "/v2/process.php";
// UnwiredLabs API_Token. Signup here to get a free token https://unwiredlabs.com/trial
String token = "your api";
String jsonString = "{\n";
// Variables to store unwiredlabs response
double latitude = 0.0;
double longitude = 0.0;
double accuracy = 0.0;
  // Set WiFi to station mode and disconnect from an AP if it was previously connected
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  Serial.println("Setup done");
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(myssid);
  WiFi.begin(myssid, mypass);
    Serial.print(".");
  Serial.println(".");
  char bssid[6];
  DynamicJsonDocument doc(1024); //V6
  // WiFi.scanNetworks will return the number of networks found
  int n = WiFi.scanNetworks();
  Serial.println("scan done");
  if (n == 0 ) {
    Serial.println("No networks available");
    Serial.print(n);
    Serial.println(" networks found");
  // now build the jsonString...
  jsonString = "{\n";
  jsonString += "\"token\" : \"";
  jsonString += token;
  jsonString += "\",\n";
  jsonString += "\"id\" : \"saikirandevice01\",\n";
  jsonString += "\"wifi\": [\n";
  for (int j = 0; j < n; ++j) {
    jsonString += "{\n";
    jsonString += "\"bssid\" : \"";
    jsonString += (WiFi.BSSIDstr(j));
    jsonString += "\"signal\": ";
    jsonString += WiFi.RSSI(j);
    jsonString += "\n";
    if (j < n - 1) {
      jsonString += "},\n";
      jsonString += "}\n";
  jsonString += ("]\n");
  jsonString += ("}\n");
  Serial.println(jsonString);
  WiFiClientSecure client;
  //Connect to the client and make the api call
  Serial.println("Requesting URL: https://" + (String)Host + endpoint);
  const char* sslFingerprint = "c3 3e 2f 21 cb 15 4e 02 d5 27 e5 f6 ef fb 31 ae 91 51 a3 5d";
  client.setFingerprint(sslFingerprint);
  if (client.connect(Host, 443)) {      //ERROR IS HERE, NO CONNECTS
    Serial.println("Connected");
    client.println("POST " + endpoint + " HTTP/1.1");
    client.println("Host: " + (String)Host);
    client.println("Connection: close");
    client.println("Content-Type: application/json");
    client.println("User-Agent: Arduino/1.0");
    client.print("Content-Length: ");
    client.println(jsonString.length());
    client.println();
    client.print(jsonString);
  else Serial.println("Client not connected");
  //Read and parse all the lines of the reply from server
  while (client.available()) {
    String line = client.readStringUntil('\r');
    DeserializationError error = deserializeJson(doc, line); //V6
    if (error)
      Serial.println("ERROR!");
      return;
    latitude    = doc["lat"];
    longitude   = doc["lon"];
    accuracy    = doc["accuracy"];
    Serial.print("Latitude = ");
    Serial.println(latitude, 6);
    Serial.print("Longitude = ");
    Serial.println(longitude, 6);
    Serial.print("Accuracy = ");
    Serial.println(accuracy);
  Serial.println("closing connection");
  client.stop();
  delay(4000);
But after running the code, it shows "Client not connected"
What may be the problem ?
That is just example code. Did you fill in the proper credentials for YOUR network?
and did your obtain and use a proper API Token?
Yes, I have tested many times, even I tried with Google Maps Geolocation API, but still shows the same error.
This says to use "us1.unwiredlabs.com" or "us2.unwiredlabs.com" depending on your location.
Screenshot (58)
After updating the fingerprint, client connected. But still there's error !
Again, you are connecting to 'www' and not one of the API addresses they provide.
Screenshot (61)_LI
I have modified the code by adding the SSL fingerprint, present below
const char *sslFingerprint = "2e cd e9 ee ff 45 5c 61 b4 a9 ca 53 47 39 d0 6e 97 46 51 7e";
char myssid[] = " ";
char mypass[] = " ";
const char* Host = "ap1.unwiredlabs.com";
String token = " ";
  WiFi.disconnect();
    Serial.print(".");
  char bssid[6];
    if (n == 0 ) {
        Serial.print(n);
      jsonString = "{\n";
          jsonString += "\n";
          if (j < n - 1) {
          client.println();
    auto error = deserializeJson(doc, line); //V6
    if (error)
      Serial.print(F("deserializeJson() failed with code "));
      Serial.println(error.c_str());
      return;
      client.stop();
      delay(5000);
Now the client "unwiredlabs" connects but cannot receive the location
Is the entire JSON document in one line?
No sir, below is the format
    "token": " ",
    "radio": "gsm",
    "mcc": 310,
    "mnc": 404,
    "cells": [{
        "lac": 7033,
        "cid": 17811
    "wifi": [{
        "bssid": "00:17:c5:cd:ca:aa",
        "channel": 11,
        "frequency": 2412,
        "signal": -51
        "bssid": "d8:97:ba:c2:f0:5a"
    "address": 1
My guess is that the deserialization won't work on a single line and you will have to read all of the characters before you deserialize. There may be an option in the library to do a line at a time. I have not used the library.
There are many reasons for which DeserializationJson Invalid Input error occurs, but I can't understand what is the exact problem
Try printing out 'line' before you pass it to deserializeJson(doc, line);. I expect you will see something like:
Connected
line="{"
deserializeJson() failed with code InvalidInput
Try changing:
to
String line = client.readString();
Thank you
