Error I don't understand
Morning experts. I am fairly new to the GPS end of Arduino. I am using example code from the new tinyGPS++ library and I am getting an error that I can't seem to understand why it doesn't like this. I have looked up the definition and I don't understand what that is either. Your help in finding my issue and describing what that error means when it shows up would be most appreciated. Here is my complete code
//display
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);//set to I2C address, number of digits, number of rows)
//gps
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
SoftwareSerial gpsSerial(2,3); //TX=2 RX=3
TinyGPSPlus gps;
//Declarations
float lattitude,longitude;
int count=0;
const int fixLED = 13;
const float deg2rad = 0.01745329251994;
const float rEarth = 6371000.0;                                          //can replace with 3958.75 mi, 6370.0 km, or 3440.06 NM
float range = 3000;                                                      // distance from HERE to THERE in meters to open box, (diameter of circle that enables opening)
String here;                                                             //variable to hold destination location.
//Servo
#include <PWMServo.h>
PWMServo servoLatch;
int servoPin = 9;                                                        // pin for servo
int servoLock = 110;                                                     // angle (deg) of "locked" servo
int servoUnlock = 0;
const double WALKING_BRIGDE_LAT = 38.732792;
const double WALKING_BRIDGE_LNG = -120.745646;
 gpsSerial.begin(9600);
 lcd.begin();
 servoLatch.attach(SERVO_PIN_A);
 servoLatch.write(servoLock);
 delay(50);
 pinMode (fixLED, OUTPUT);
 digitalWrite(fixLED, HIGH);
 delay(250);
 digitalWrite(fixLED, LOW);
  }//setup
while (gpsSerial.available() > 0)
  gps.encode(gpsSerial.read());
Serial.print("LAT=");  Serial.println(gps.location.lat(), 6);
Serial.print("LONG="); Serial.println(gps.location.lng(), 6);
Serial.print("ALT=");  Serial.println(gps.altitude.feet());
 if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println("No GPS detected");
    while(true);
 //fix LED lit when good fix available. Blue light will flash upon startup to verify connections then will light when GPS fix is obtained
 if (gps.location.age()<1500){digitalWrite(fixLED, HIGH);}
 if (gps.location.age()>1500){digitalWrite(fixLED, LOW);}
if (gps.location.isUpdated())
  lcd.home();
  lcd.print("current fix");
  lcd.setCursor(0,1);
  lcd.print("lat= ");
  lcd.print(gps.location.lat(), 6);
  lcd.setCursor(0,2);
  lcd.print("long= ");
  lcd.print(gps.location.lng(), 6);
  lcd.setCursor(0,3);
  lcd.print("alt= ");
  lcd.print(gps.altitude.feet());
double distanceKm =
  TinyGPSPlus.distanceBetween(
    gps.location.lat(),
    gps.location.lng(),
    WALKING_BRIGDE_LAT,
    WALKING_BRIDGE_LNG) / 1000.0;
double courseTo =
  TinyGPSPlus.courseTo(
    gps.location.lat(),
    gps.location.lng(),
    WALKING_BRIGDE_LAT,
    WALKING_BRIDGE_LNG);
Serial.print("Distance (km) to Walking Bridge: ");
Serial.println(distanceKm);
Serial.print("Course to Walking Brigde: ");
Serial.println(courseTo);
Serial.print("Human directions: ");
Serial.println(TinyGPSPlus.cardinal(courseTo));
}//loop
here is the error message that I'm getting.
C:\Users\machine\Documents\Arduino\Reverse_geocashe_buildup_MK1_Mod4\Reverse_geocashe_buildup_MK1_Mod4.ino: In function 'void loop()':
Reverse_geocashe_buildup_MK1_Mod4:103:14: error: expected primary-expression before '.' token
Reverse_geocashe_buildup_MK1_Mod4:111:14: error: expected primary-expression before '.' token
exit status 1
additional details. Arduino Uno, 4x20 LCD, UBLOX GY-NEO6MV2
I'm still working up a version of a reverse geocashe box but I want to understand what everything is doing so that I can use it in other places. Thank you for your attention
a machine tech
TinyGPSPlus.distanceBetween(i think it is telling you that you can not just call a library function like that, but that you should call the function through the object (gps)
If you look at the example code that comes with the library you'll see the call formats you want are:
TinyGPSPlus::distanceBetween()
TinyGPSPlus::courseTo()
Give it a try.
Steve
@slipstick
I copied the code directly from the website with the example. However I made the change from TinyGPSPlus to just gps and it compiled and worked. Thank you for your help folks. It is truly appreciated.
Now the code looks like this
//display
#include <Wire.h>
//gps
TinyGPSPlus gps;
//Declarations
int count=0;
//Servo
 lcd.begin();
 delay(50);
 delay(250);
  }//setup
    while(true);
  lcd.home();
  lcd.setCursor(0,1);
  lcd.print("lat= ");
  lcd.setCursor(0,2);
  lcd.setCursor(0,3);
  lcd.print("alt= ");
double distanceKm =
  gps.distanceBetween(               //change made here
    gps.location.lat(),
    gps.location.lng(),
    WALKING_BRIGDE_LAT,
double courseTo =
  gps.courseTo(                     // and change made here
    gps.location.lat(),
    gps.location.lng(),
    WALKING_BRIGDE_LAT,
Serial.println(gps.cardinal(courseTo));
}//loop
Thanks for your help
a machine tech
Edit: after reading Deva_Rishi's post again this what was suggested and I didn't understand. Thanks for your insight.
you're welcome !
