Error in Arduino Cloud Web Editor
Hi Experts, I am facing a problem in Arduino Cloud Sketch Web editor. The code is ending up with an error " 'SWSERIAL_8N1' was not declared in this scope". I am using the program for communicating to MODBUS meter. The library which I am using is ModbusRTU.h for modbus traffic. The same code is working properly in Arduino IDE, but when I configured the code in Arduino Cloud with the necessary changes, it is giving the error. I uploaded the same MODBUS library to Arduino Cloud Library Manager but still the same problem exists. What would have been the reason and what is wrong in my code? As far as I understand, no need to declare 'SWSERIAL_8N1 as it is taking from the library, am I right? kindly help me to resolve the problem.
#include "thingProperties.h"
#include "ModbusRTU.h"
#include "SoftwareSerial.h"
float InttoFloat(uint16_t Data0,uint16_t Data1) {
float x;
unsigned long p;
p = (unsigned long
)&x;
*p = (unsigned long)Data0 << 16 | Data1; //Big-endian
return(x);
SoftwareSerial S(D6, D7);
ModbusRTU mb;
bool cb(Modbus::ResultCode event, uint16_t transactionId, void* data) { // Callback to monitor errors
if (event != Modbus::EX_SUCCESS) {
Serial.print("Request result: 0x");
Serial.print(event, HEX);
return true;
uint16_t val[2];
uint16_t val1[2];
uint16_t val2[2];
uint16_t val3[2];
uint16_t val4[2];
// Initialize serial and wait for port to open:
S.begin(9600, SWSERIAL_8N1);
mb.begin(&S,D5); // RE/DE connected to D5 of ESP8266
mb.master();
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
void handleVoltage() {
if (!mb.slave()) {
mb.readIreg(1, 21, val, 2, cb);
while(mb.slave()) { // Check if transaction is active
mb.task();
delay(10);
Serial.println("Voltage: ");
//Serial.println(InttoFloat(val[0],val[1]));
voltage = (InttoFloat(val[0],val[1]));
Serial.println (voltage);
void handleCurrent() {
if (!mb.slave()) {
mb.readIreg(1, 23, val1, 2, cb);
mb.task();
delay(10);
Serial.println("Current: ");
//Serial.println(InttoFloat(val1[0],val1[1]));
current = (InttoFloat(val1[0],val1[1]));
Serial.println(current);
void handleWattage() {
if (!mb.slave()) {
mb.readIreg(1, 15, val3, 2, cb);
mb.task();
delay(10);
Serial.println("Kilo Watt: ");
//Serial.println(InttoFloat(val3[0],val3[1]));
power = (InttoFloat(val3[0],val3[1]));
Serial.println(power);
void handlekWH() {
if (!mb.slave()) {
mb.readIreg(1, 01, val4, 2, cb);
mb.task();
delay(10);
Serial.println("Kilo Watt Hour: ");
//Serial.println(InttoFloat(val4[0],val4[1]));
energy = (InttoFloat(val4[0],val4[1]));
Serial.println(energy);
ArduinoCloud.update();
// Your code here
handleVoltage();
handleCurrent();
handleWattage();
handlekWH();
The SWSERIAL_8N1 parameters and presumably others like it are used by the EspSoftwareSerial library but you are using the normal SoftwareSerial library
Which board are you using ?
Hi, I am using NODEMCU 1.
Have you tried the EspSoftwareSerial library ?
yes, I tried now, still the same issue
I have done some digging and experimentation
  • when you #include the espSoftwareSerial library it is referred to in the sketch as SoftWareSerial, which is confusing
  • using the SWSERIAL_8N1 parameter does not compile when you use an ESP8266 board
  • using the SWSERIAL_8N1 parameter does compile when you use an ESP32 board
This raises the question as to why you want to use SWSERIAL_8N1 in the first place
I am using the RS485 interface for communicating to the MODBUS devices. I am using the same code with the NODEMCU for reading the data from MODBUS Meters and MODBUS thermostats with the same code compiled through Arduino IDE. It is working perfectly. I really don't understand why the code is ending with the error. You can refer the library documentation from the below link.
The default is 8 bits, no parity, 1 stop bit so why do you need to specify it using SWSERIAL_8N1 ?
Please post the full error message that you get when you use SWSERIAL_8N1 so that we can see exactly where the error is occurring
What happens if you don't use the parameter ?
When I am using 'SoftwareSerial.h' library, I am getting only the error " 'SWSERIAL_8N1' was not declared in this scope" but when 'EspSoftwareSerial.h is using, I am getting the below errors:
/usr/local/bin/arduino-cli compile --fqbn esp8266:esp8266:nodemcuv2:baud=115200,dbg=Disabled,eesz=4M,exception=disabled,ip=lm2f,lvl=None____,vt=flash,wipe=none,xtal=80 --build-cache-path /tmp --output-dir /tmp/293049219/build --build-path /tmp/arduino-build-066A1CF1313387E15C0E432B0DD28B09 --library /mnt/create-efs/webide/00/60/00600645187e4d429dda9531df88ce7f:sunilpallikkara/libraries_v2/modbus-esp8266 --library /home/builder/opt/libraries/modbusrtu_1_0_1 --library /home/builder/opt/libraries/modbus_esp8266_4_1_0 --library /home/builder/opt/libraries/espsoftwareserial_8_1_0 /tmp/293049219/Electrical_Meter_mar08a
In file included from /home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:31:0,
from /home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:25,
from /tmp/293049219/Electrical_Meter_mar08a/Electrical_Meter_mar08a.ino:26:
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:48:43: error: expected initializer before 'vPtrToFunPtrExec'
ALWAYS_INLINE_ATTR inline R IRAM_ATTR vPtrToFunPtrExec(void* fn, P... args)
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:248:28: error: expected ';' at end of member declaration
DelegatePImpl& IRAM_ATTR operator=(std::nullptr_t)
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:248:62: error: ISO C++ forbids declaration of 'operator=' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:263:13: error: 'IRAM_ATTR' does not name a type
IRAM_ATTR operator bool() const
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:279:29: error: 'IRAM_ATTR' declared as an 'inline' field
static inline R IRAM_ATTR vPtrToFunAPtrExec(void* self, P... args) ALWAYS_INLINE_ATTR
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:279:29: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:279:29: error: 'R delegate::detail::DelegatePImpl<A, R, P>::IRAM_ATTR' conflicts with a previous declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:248:28: note: previous declaration 'delegate::detail::DelegatePImpl<A, R, P>& delegate::detail::DelegatePImpl<A, R, P>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:33:57: error: ISO C++ forbids declaration of 'vPtrToFunAPtrExec' with no type [-fpermissive]
#define ALWAYS_INLINE_ATTR __attribute__((always_inline))
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:279:80: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:341:15: error: expected ';' at end of member declaration
R IRAM_ATTR operator()(P... args) const
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:341:15: error: redeclaration of 'R delegate::detail::DelegatePImpl<A, R, P>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:341:47: error: ISO C++ forbids declaration of 'operator()' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h: In member function 'delegate::detail::DelegatePImpl<A, R, P>::operator delegate::detail::DelegatePImpl<A, R, P>::FunVPPtr() const':
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:290:28: error: 'vPtrToFunPtrExec' was not declared in this scope
return vPtrToFunPtrExec<R, P...>;
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:290:46: error: expected primary-expression before ',' token
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:290:49: error: expected primary-expression before '...' token
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:290:49: error: expected ';' before '...' token
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h: At global scope:
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:710:28: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:710:62: error: ISO C++ forbids declaration of 'operator=' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:721:13: error: 'IRAM_ATTR' does not name a type
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:780:15: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:780:15: error: redeclaration of 'R delegate::detail::DelegatePImpl<void, R, P ...>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:710:28: note: previous declaration 'delegate::detail::DelegatePImpl<void, R, P ...>& delegate::detail::DelegatePImpl<void, R, P ...>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:780:47: error: ISO C++ forbids declaration of 'operator()' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h: In member function 'delegate::detail::DelegatePImpl<void, R, P ...>::operator delegate::detail::DelegatePImpl<void, R, P ...>::FunVPPtr() const':
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:737:28: error: 'vPtrToFunPtrExec' was not declared in this scope
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:737:46: error: expected primary-expression before ',' token
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:737:49: error: expected primary-expression before '...' token
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:737:49: error: expected ';' before '...' token
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1085:27: error: expected ';' at end of member declaration
DelegateImpl& IRAM_ATTR operator=(std::nullptr_t)
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1085:61: error: ISO C++ forbids declaration of 'operator=' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1100:13: error: 'IRAM_ATTR' does not name a type
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1116:29: error: 'IRAM_ATTR' declared as an 'inline' field
static inline R IRAM_ATTR vPtrToFunAPtrExec(void* self) ALWAYS_INLINE_ATTR
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1116:29: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1116:29: error: 'R delegate::detail::DelegateImpl<A, R>::IRAM_ATTR' conflicts with a previous declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1085:27: note: previous declaration 'delegate::detail::DelegateImpl<A, R>& delegate::detail::DelegateImpl<A, R>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1116:69: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1177:15: error: expected ';' at end of member declaration
R IRAM_ATTR operator()() const
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1177:15: error: redeclaration of 'R delegate::detail::DelegateImpl<A, R>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1177:38: error: ISO C++ forbids declaration of 'operator()' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1545:27: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1545:61: error: ISO C++ forbids declaration of 'operator=' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1556:13: error: 'IRAM_ATTR' does not name a type
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1615:15: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1615:15: error: redeclaration of 'R delegate::detail::DelegateImpl<void, R>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1545:27: note: previous declaration 'delegate::detail::DelegateImpl<void, R>& delegate::detail::DelegateImpl<void, R>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1615:38: error: ISO C++ forbids declaration of 'operator()' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1789:30: error: 'IRAM_ATTR' declared as an 'inline' field
inline Delegate& IRAM_ATTR operator=(std::nullptr_t) ALWAYS_INLINE_ATTR {
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1789:30: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:33:57: error: ISO C++ forbids declaration of 'operator=' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1789:66: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1868:30: error: 'IRAM_ATTR' declared as an 'inline' field
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1868:30: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1868:66: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1924:30: error: 'IRAM_ATTR' declared as an 'inline' field
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1924:30: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1924:66: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1985:30: error: 'IRAM_ATTR' declared as an 'inline' field
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1985:30: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1985:66: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2064:30: error: 'IRAM_ATTR' declared as an 'inline' field
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2064:30: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2064:66: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2120:30: error: 'IRAM_ATTR' declared as an 'inline' field
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2120:30: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2120:66: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2165:22: error: 'IRAM_ATTR' declared as an 'inline' field
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2165:22: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2165:58: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2203:22: error: 'IRAM_ATTR' declared as an 'inline' field
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2203:22: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2203:58: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
In file included from /home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:25:0,
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:118:12: error: expected ';' at end of member declaration
size_t IRAM_ATTR available() const
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:118:34: error: ISO C++ forbids declaration of 'available' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:128:12: error: expected ';' at end of member declaration
size_t IRAM_ATTR available_for_push() const
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:128:12: error: redeclaration of 'size_t circular_queue<T, ForEachArg>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:118:12: note: previous declaration 'size_t circular_queue<T, ForEachArg>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:128:43: error: ISO C++ forbids declaration of 'available_for_push' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:151:8: error: expected ';' at end of member declaration
T& IRAM_ATTR pushpeek()
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:151:8: error: redeclaration of 'T& circular_queue<T, ForEachArg>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:151:27: error: ISO C++ forbids declaration of 'pushpeek' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:163:10: error: expected ';' at end of member declaration
bool IRAM_ATTR push()
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:163:10: error: redeclaration of 'bool circular_queue<T, ForEachArg>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:163:25: error: ISO C++ forbids declaration of 'push' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:180:10: error: expected ';' at end of member declaration
bool IRAM_ATTR push(T&& val)
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:180:10: error: redeclaration of 'bool circular_queue<T, ForEachArg>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:180:32: error: ISO C++ forbids declaration of 'push' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:198:17: error: 'IRAM_ATTR' declared as an 'inline' field
inline bool IRAM_ATTR push(const T& val) ALWAYS_INLINE_ATTR
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:198:17: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:198:17: error: redeclaration of 'bool circular_queue<T, ForEachArg>::IRAM_ATTR'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:43:57: error: ISO C++ forbids declaration of 'push' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:198:46: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
In file included from /tmp/293049219/Electrical_Meter_mar08a/Electrical_Meter_mar08a.ino:26:0:
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h: In static member function 'static constexpr bool EspSoftwareSerial::GpioCapabilities::hasPullUp(int8_t)':
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:102:5: error: body of constexpr function 'static constexpr bool EspSoftwareSerial::GpioCapabilities::hasPullUp(int8_t)' not a return-statement
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h: At global scope:
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:321:28: error: 'IRAM_ATTR' declared as an 'inline' field
static inline uint32_t IRAM_ATTR microsToTicks(uint32_t micros) ALWAYS_INLINE_ATTR {
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:321:28: error: expected ';' at end of member declaration
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/circular_queue.h:43:57: error: ISO C++ forbids declaration of 'microsToTicks' with no type [-fpermissive]
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:321:69: note: in expansion of macro 'ALWAYS_INLINE_ATTR'
In file included from /home/builder/.arduino15/packages/esp8266/hardware/esp8266/2.5.0/cores/esp8266/Arduino.h:29:0,
from /tmp/arduino-build-066A1CF1313387E15C0E432B0DD28B09/sketch/Electrical_Meter_mar08a.ino.cpp:1:
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h: In instantiation of 'class delegate::detail::Delegate<EspSoftwareSerial::UARTBase*, void, unsigned int&&>':
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2129:55: required from 'class Delegate<void(unsigned int&&), EspSoftwareSerial::UARTBase*>'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:369:145: required from here
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1808:64: error: no members matching 'delegate::detail::DelegatePImpl<EspSoftwareSerial::UARTBase*, void, unsigned int&&>::operator bool' in 'class delegate::detail::DelegatePImpl<EspSoftwareSerial::UARTBase*, void, unsigned int&&>'
using detail::DelegatePImpl<A*, R, P...>::operator bool;
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h: In instantiation of 'class delegate::detail::Delegate<void*, void>':
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2129:55: required from 'class Delegate<void(), void*>'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:373:29: required from here
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2004:57: error: no members matching 'delegate::detail::DelegateImpl<void*, void>::operator bool' in 'class delegate::detail::DelegateImpl<void*, void>'
using detail::DelegateImpl<A*, R>::operator bool;
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:199:9: error: 'int EspSoftwareSerial::UARTBase::availableForWrite()' marked override, but does not override
int availableForWrite() override {
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:226:9: error: 'int EspSoftwareSerial::UARTBase::read(uint8_t*, size_t)' marked override, but does not override
int read(uint8_t* buffer, size_t size)
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:442:22: error: template-id 'operator()<>' for 'void delegate::detail::DelegateImpl<void*, void>::operator()() const' does not match any template declaration
extern template void delegate::detail::DelegateImpl<void*, void>::operator()() const;
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:443:24: error: template-id 'available<>' for 'size_t circular_queue<unsigned int, EspSoftwareSerial::UARTBase*>::available() const' does not match any template declaration
extern template size_t circular_queue<uint32_t, EspSoftwareSerial::UARTBase*>::available() const;
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:444:22: error: template-id 'push<>' for 'bool circular_queue<unsigned int, EspSoftwareSerial::UARTBase*>::push(uint32_t&&)' does not match any template declaration
extern template bool circular_queue<uint32_t, EspSoftwareSerial::UARTBase*>::push(uint32_t&&);
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/SoftwareSerial.h:445:22: error: template-id 'push<>' for 'bool circular_queue<unsigned int, EspSoftwareSerial::UARTBase*>::push(const uint32_t&)' does not match any template declaration
extern template bool circular_queue<uint32_t, EspSoftwareSerial::UARTBase*>::push(const uint32_t&);
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h: In instantiation of 'Delegate<R(P ...), A>::Delegate(typename delegate::detail::Delegate<A, R, P ...>::FunAPtr, const A&) [with A = EspSoftwareSerial::UARTBase*; R = void; P = {unsigned int&&}; typename delegate::detail::Delegate<A, R, P ...>::FunAPtr = void (*)(EspSoftwareSerial::UARTBase*, unsigned int&&)]':
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2142:5: error: uninitialized reference member 'Delegate<void(unsigned int&&), EspSoftwareSerial::UARTBase*>::IRAM_ATTR' [-fpermissive]
Delegate(typename delegate::detail::Delegate<A, R, P...>::FunAPtr fnA, const A& obj) : delegate::detail::Delegate<A, R, P...>::Delegate(fnA, obj) {}
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h: In instantiation of 'delegate::detail::Delegate<A*, R, P ...>::Delegate(delegate::detail::Delegate<A*, R, P ...>::FunAPtr, A*) [with A = EspSoftwareSerial::UARTBase; R = void; P = {unsigned int&&}; delegate::detail::Delegate<A*, R, P ...>::FunAPtr = void (*)(EspSoftwareSerial::UARTBase*, unsigned int&&)]':
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:2142:149: required from 'Delegate<R(P ...), A>::Delegate(typename delegate::detail::Delegate<A, R, P ...>::FunAPtr, const A&) [with A = EspSoftwareSerial::UARTBase*; R = void; P = {unsigned int&&}; typename delegate::detail::Delegate<A, R, P ...>::FunAPtr = void (*)(EspSoftwareSerial::UARTBase*, unsigned int&&)]'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1847:13: error: uninitialized reference member 'delegate::detail::Delegate<EspSoftwareSerial::UARTBase*, void, unsigned int&&>::IRAM_ATTR' [-fpermissive]
Delegate(FunAPtr fnA, A* obj) : detail::DelegatePImpl<A*, R, P...>::DelegatePImpl(fnA, obj) {}
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h: In instantiation of 'delegate::detail::DelegatePImpl<A, R, P>::DelegatePImpl(delegate::detail::DelegatePImpl<A, R, P>::FunAPtr, const A&) [with A = EspSoftwareSerial::UARTBase*; R = void; P = {unsigned int&&}; delegate::detail::DelegatePImpl<A, R, P>::FunAPtr = void (*)(EspSoftwareSerial::UARTBase*, unsigned int&&)]':
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:1847:103: required from 'delegate::detail::Delegate<A*, R, P ...>::Delegate(delegate::detail::Delegate<A*, R, P ...>::FunAPtr, A*) [with A = EspSoftwareSerial::UARTBase; R = void; P = {unsigned int&&}; delegate::detail::Delegate<A*, R, P ...>::FunAPtr = void (*)(EspSoftwareSerial::UARTBase*, unsigned int&&)]'
/home/builder/opt/libraries/espsoftwareserial_8_1_0/src/circular_queue/Delegate.h:129:13: error: uninitialized reference member 'delegate::detail::DelegatePImpl<EspSoftwareSerial::UARTBase*, void, unsigned int&&>::IRAM_ATTR' [-fpermissive]
DelegatePImpl(FunAPtr fnA, const A& obj)
Multiple libraries were found for "ModbusRTU.h"
Used: /mnt/create-efs/webide/00/60/00600645187e4d429dda9531df88ce7f:sunilpallikkara/libraries_v2/modbus-esp8266
Not used: /home/builder/opt/libraries/modbus_esp8266_4_1_0
Multiple libraries were found for "SoftwareSerial.h"
Used: /home/builder/opt/libraries/espsoftwareserial_8_1_0
Not used: /home/builder/opt/libraries/printoo_library_1_0_2
Not used: /home/builder/opt/libraries/espsoftwareserial_8_1_0
Not used: /home/builder/opt/libraries/mcci_sofwareserial_3_0_0
Not used: /home/builder/opt/libraries/dabble_1_5_2
Not used: /home/builder/opt/libraries/vega_softwareserial_1_0_0
Not used: /home/builder/.arduino15/packages/esp8266/hardware/esp8266/2.5.0/libraries/SoftwareSerial
Error during build: exit status 1
