int watch_get_date(uint8_t* year, uint8_t* month, uint8_t* day_of_month)
uint8_t date_bits_low, date_bits_high;
if (year == NULL || month == NULL || day_of_month == NULL)
return -1;
if (watch_i2c_read_byte(ADDRESS_DATE_LOW, &date_bits_low) != 0)
return -1;
if (watch_i2c_read_byte(ADDRESS_DATE_HIGH, &date_bits_high) != 0)
return -1;
watch_registers_get_date(
date_bits_low, date_bits_low, year, month, day_of_month);
return 0;
.h file
void watch_registers_get_date(
uint8_t date_bits_low, uint8_t date_bits_high, uint8_t* year,
uint8_t* month, uint8_t* day_of_month);
*year = date_bits_low & 0b01111111 ;
*month = ((date_bits_high & 0b00000111)<<1) + (date_bits_low <<7);
*day_of_month = ((date_bits_high & 0b11111000 >>3));
I keep getting an error with get date of month while making a test case can someone see what it is
watch_registers_get_date *month somehowe i didnt shift the bits good
i was thinking of this
*month = ((date_bits_high & 0b00000111)<<1) + ((date_bits_low & 0b00000001)<<7);
but got this instead
Seems fishy, there are months above 128, but never odd ones. Maybe you want
*month = ((date_bits_high & 0b00000111) << 1 ) + (date_bits_low >> 7);
That doesn't look right. Should there be a date_bits_high in there?
its a project i learn for school i am new to this.
i see 2 times date_bits_low
date_bits_low we have m[0]
date_bits_high we have m[3] m[2] m[1]
6v6gt
8
You can probably do it without an explicit shift (but I guess the compiler would do it in the back ground anyway). Something like:
*month = (date_bits_high % 8 ) * 2 + date_bits_low / 128 ;
i understand what you mean this i cant put in the code . after i create a testcase its an error because mine shifting is not good og *get month
Since the month field crosses the byte boundary I would glue the two bytes together into a 16-bit word and do the shifting and masking on the word.
uint16_t fullDate = word(date_bits_high, date_bits_low);
*year = fullDate & 0b01111111;
*month = (fullDate >> 7) & 0b00001111;
*day_of_month = (fullDate >> 11) & 0b00011111;
system
Closed
11
