Error in esp32 voice assistant with chatgpt Personal AI companion
i am doing "esp32 voice assistant with chatgpt " project in this project there are two part one is speech to text in this part the through i2s mic our question is recorded and it converted into text using google speech to text API , then this text give to chat gpt through chatgpt API integration for this part I am using 1 ESP 32, the next part is text to speech conversion the answer from the chatgpt is converted to text using google cloud TTS through I2s amplifier and speaker the response will be heard , there is major issue in this project
This is the program for speech to text
//////Running code with board maneger verstion 1.0.6
 #define led_1 15
#define led_2 2
#define button 23 //IR Sensor
#define led_3 4
#define RXp2 16
#define TXp2 17
#include "Audio.h"
#include "CloudSpeechClient.h"
int i=0;
pinMode(button, INPUT);
pinMode(led_1,OUTPUT);
pinMode(led_2,OUTPUT);
 pinMode(led_3,OUTPUT);
 Serial2.begin(115200, SERIAL_8N1, RXp2,TXp2);
   Serial2.println("Intialising");
//  Serial.println(My_Data);
     digitalWrite(led_1, 0);
     digitalWrite(led_2, 0);
      digitalWrite(led_3, 0);
   if(i==0){
   Serial.println("Press button");
   i=1;
 //  if(i==1){delay(1);}
   if(digitalRead(button)==0){
     Serial2.println("\r\nPlease Ask!\r\n");
     digitalWrite(led_1, 1);
     delay(2100);
  Serial.println("\r\nRecord start!\r\n");
  //Serial2.println("\r\nRecord start!\r\n");
  Audio* audio = new Audio(ADMP441);
 //Audio* audio = new Audio(M5STACKFIRE);
  audio->Record();
  Serial.println("Recoding Complited Processing");
  digitalWrite(led_1,0);
  digitalWrite(led_3,0);
  digitalWrite(led_2,1);
  CloudSpeechClient* cloudSpeechClient = new CloudSpeechClient(USE_APIKEY);
  cloudSpeechClient->Transcribe(audio);
  delete cloudSpeechClient;
  delete audio;
  i=0;
  if(digitalRead(button)==1){
    delay(1);
Audio.cpp
#include "Audio.h"
Audio::Audio(MicType micType) {
  wavData = new char*[wavDataSize/dividedWavDataSize];
  for (int i = 0; i < wavDataSize/dividedWavDataSize; ++i) wavData[i] = new char[dividedWavDataSize];
  i2s = new I2S(micType);
Audio::~Audio() {
  for (int i = 0; i < wavDataSize/dividedWavDataSize; ++i) delete[] wavData[i];
  delete[] wavData;
  delete i2s;
void Audio::CreateWavHeader(byte* header, int waveDataSize){
  header[0] = 'R';
  header[1] = 'I';
  header[2] = 'F';
  header[3] = 'F';
  unsigned int fileSizeMinus8 = waveDataSize + 44 - 8;
  header[4] = (byte)(fileSizeMinus8 & 0xFF);
  header[5] = (byte)((fileSizeMinus8 >> 8) & 0xFF);
  header[6] = (byte)((fileSizeMinus8 >> 16) & 0xFF);
  header[7] = (byte)((fileSizeMinus8 >> 24) & 0xFF);
  header[8] = 'W';
  header[9] = 'A';
  header[10] = 'V';
  header[11] = 'E';
  header[12] = 'f';
  header[13] = 'm';
  header[14] = 't';
  header[15] = ' ';
  header[16] = 0x10;  // linear PCM
  header[17] = 0x00;
  header[18] = 0x00;
  header[19] = 0x00;
  header[20] = 0x01;  // linear PCM
  header[21] = 0x00;
  header[22] = 0x01;  // monoral
  header[23] = 0x00;
  header[24] = 0x80;  // sampling rate 16000
  header[25] = 0x3E;
  header[26] = 0x00;
  header[27] = 0x00;
  header[28] = 0x00;  // Byte/sec = 16000x2x1 = 32000
  header[29] = 0x7D;
  header[30] = 0x00;
  header[31] = 0x00;
  header[32] = 0x02;  // 16bit monoral
  header[33] = 0x00;
  header[34] = 0x10;  // 16bit
  header[35] = 0x00;
  header[36] = 'd';
  header[37] = 'a';
  header[38] = 't';
  header[39] = 'a';
  header[40] = (byte)(waveDataSize & 0xFF);
  header[41] = (byte)((waveDataSize >> 8) & 0xFF);
  header[42] = (byte)((waveDataSize >> 16) & 0xFF);
  header[43] = (byte)((waveDataSize >> 24) & 0xFF);
void Audio::Record() {
  CreateWavHeader(paddedHeader, wavDataSize);
  int bitBitPerSample = i2s->GetBitPerSample();
  if (bitBitPerSample == 16) {
    for (int j = 0; j < wavDataSize/dividedWavDataSize; ++j) {
      i2s->Read(i2sBuffer, i2sBufferSize/2);
      for (int i = 0; i < i2sBufferSize/8; ++i) {
        wavData[j][2*i] = i2sBuffer[4*i + 2];
        wavData[j][2*i + 1] = i2sBuffer[4*i + 3];
  else if (bitBitPerSample == 32) {
      i2s->Read(i2sBuffer, i2sBufferSize);
        wavData[j][2*i] = i2sBuffer[8*i + 2];
        wavData[j][2*i + 1] = i2sBuffer[8*i + 3];
Audio.h
#ifndef _AUDIO_H
#define _AUDIO_H
#include <Arduino.h>
#include "I2S.h"
// 16bit, monoral, 16000Hz,  linear PCM
class Audio {
  I2S* i2s;
  static const int headerSize = 44;
  static const int i2sBufferSize = 12000;
  char i2sBuffer[i2sBufferSize];
  void CreateWavHeader(byte* header, int waveDataSize);
public:
  static const int wavDataSize = 90000;                   // It must be multiple of dividedWavDataSize. Recording time is about 1.9 second.
  static const int dividedWavDataSize = i2sBufferSize/4;
  char** wavData;                                         // It's divided. Because large continuous memory area can't be allocated in esp32.
  byte paddedHeader[headerSize + 4] = {0};                // The size must be multiple of 3 for Base64 encoding. Additional byte size must be even because wave data is 16bit.
  Audio(MicType micType);
  ~Audio();
  void Record();
#endif // _AUDIO_H
CloudSpeechClient.cpp
#include "network_param.h"
#include <base64.h>
#include <ArduinoJson.h>
#define USE_SERIAL Serial
#include <HTTPClient.h>
//#define uart_en 15
 #define led_3 4
 #define led_1 15
#define led_2 2
//#include <SoftwareSerial.h>
////SoftwareSerial (D4, D2);
const char* chatgpt_token = "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";
CloudSpeechClient::CloudSpeechClient(Authentication authentication) {
  this->authentication = authentication;
  WiFi.begin(ssid, password);
 //  while (WiFi.status() == WL_CONNECTED){ digitalWrite(led_3,1);}
  while (WiFi.status() != WL_CONNECTED) delay(1000);
  client.setCACert(root_ca);
  if (!client.connect(server, 443)) Serial.println("Connection failed!"); digitalWrite(led_3,1);digitalWrite(led_1,0);digitalWrite(led_2,0);
String ans;
CloudSpeechClient::~CloudSpeechClient() {
  client.stop();
  WiFi.disconnect();
void CloudSpeechClient::PrintHttpBody2(Audio* audio)
  String enc = base64::encode(audio->paddedHeader, sizeof(audio->paddedHeader));
  enc.replace("\n", "");  // delete last "\n"
  client.print(enc);      // HttpBody2
  char** wavData = audio->wavData;
  for (int j = 0; j < audio->wavDataSize / audio->dividedWavDataSize; ++j) {
    enc = base64::encode((byte*)wavData[j], audio->dividedWavDataSize);
    enc.replace("\n", "");// delete last "\n"
void CloudSpeechClient::Transcribe(Audio* audio) {
  String HttpBody1 = "{\"config\":{\"encoding\":\"LINEAR16\",\"sampleRateHertz\":16000,\"languageCode\":\"en-IN\"},\"audio\":{\"content\":\"";
  String HttpBody3 = "\"}}\r\n\r\n";
  int httpBody2Length = (audio->wavDataSize + sizeof(audio->paddedHeader)) * 4 / 3; // 4/3 is from base64 encoding
  String ContentLength = String(HttpBody1.length() + httpBody2Length + HttpBody3.length());
  String HttpHeader;
  // if (authentication == USE_APIKEY)
  HttpHeader = String("POST /v1/speech:recognize?key=") + ApiKey
               + String(" HTTP/1.1\r\nHost: speech.googleapis.com\r\nContent-Type: application/json\r\nContent-Length: ") + ContentLength + String("\r\n\r\n");
  //  else if (authentication == USE_ACCESSTOKEN)
  //    HttpHeader = String("POST /v1beta1/speech:syncrecognize HTTP/1.1\r\nHost: speech.googleapis.com\r\nContent-Type: application/json\r\nAuthorization: Bearer ")
  //   + AccessToken + String("\r\nContent-Length: ") + ContentLength + String("\r\n\r\n");
  client.print(HttpHeader);
  client.print(HttpBody1);
  PrintHttpBody2(audio);
  client.print(HttpBody3);
  String My_Answer="";
  while (!client.available());
  while (client.available())
    char temp = client.read();
    My_Answer = My_Answer + temp;
   // Serial.write(client.read());
 // Serial.print("My Answer - ");Serial.println(My_Answer);
  int postion = My_Answer.indexOf('{');
 // Serial.println(postion);
  ans = My_Answer.substring(postion);
  Serial.print("Json daata--");
  //Serial.print(ans);
 DynamicJsonDocument doc(384);
//StaticJsonDocument<384> doc;
DeserializationError error = deserializeJson(doc, ans);
if (error) {
  Serial.print("deserializeJson() failed: ");
  Serial.println(error.c_str());
  return;
JsonObject results_0 = doc["results"][0];
//const char*
const char* chatgpt_Q = results_0["alternatives"][0]["transcript"];
const char* a= "light on";
const char* b= "light off";
//String chatgpt_Q = a+ans+b;
//Serial.println(ans);
Serial.print(chatgpt_Q);Serial.println("-");
if(strstr(chatgpt_Q, "light on")){
  Serial.println("Light's On");
  digitalWrite(15, LOW);
delay(1);
Serial2.println("Turning Light on");
digitalWrite(led_1,1);
//digitalWrite(uart_en,HIGH);
  Serial.print("To ask again");
if(strstr(chatgpt_Q, "light off")){
  Serial.println("Light's Off");
delay(1);
Serial2.println("Turning Light off");
 if(strstr(chatgpt_Q, "blink on")){
  HTTPClient http;
        USE_SERIAL.print("[HTTP] begin...\n");
        // configure traged server and url
        //http.begin("https://www.howsmyssl.com/a/check", ca); //HTTPS
        http.begin("http://example.com/index.html"); //HTTP
        USE_SERIAL.print("[HTTP] GET...\n");
        // start connection and send HTTP header
        int httpCode = http.GET();
        // httpCode will be negative on error
        if(httpCode > 0) {
            // HTTP header has been send and Server response header has been handled
            USE_SERIAL.printf("[HTTP] GET... code: %d\n", httpCode);
            // file found at server
            if(httpCode == HTTP_CODE_OK) {
                String payload = http.getString();
                USE_SERIAL.println(payload);
            USE_SERIAL.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
        http.end();
 else if(strstr(chatgpt_Q, "light on")==0 && strstr(chatgpt_Q, "light off") == 0 && strstr(chatgpt_Q, "blink on") ==0 ){
  Serial.println("Asking Chat GPT");
  HTTPClient https;
    Serial.print("[HTTPS] begin...\n");
    if (https.begin("https://api.openai.com/v1/completions")) {  // HTTPS
      https.addHeader("Content-Type", "application/json");
      String token_key = String("Bearer ") + chatgpt_token;
      https.addHeader("Authorization", token_key);
      String payload = String("{\"model\": \"text-davinci-003\", \"prompt\": ") +"\""+ chatgpt_Q +"\"" + String(", \"temperature\": 0.2, \"max_tokens\": 40}"); //Instead of TEXT as Payload, can be JSON as Paylaod
      Serial.print("[HTTPS] GET...\n");
      int httpCode = https.POST(payload);
      if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY) {
        String payload = https.getString();
        Serial.println(payload);
       // Serial2.println(payload);
        StaticJsonDocument<2000> doc2;
DeserializationError error = deserializeJson(doc2, payload);
if (error) {
  return;
JsonObject choices_0 = doc2["choices"][0];
const char* only_ans = choices_0["text"];
Serial.println("Only ans:-");Serial.print(only_ans);
Serial2.print(only_ans);
//digitalWrite(uart_en, LOW);
delay(1);
      else {
        Serial.printf("[HTTPS] GET... failed, error: %s\n", https.errorToString(httpCode).c_str());
      https.end();
    else {
      Serial.printf("[HTTPS] Unable to connect\n");
  //delay(10000);
CloudSpeechClient.h
#ifndef _CLOUDSPEECHCLIENT_H
#define _CLOUDSPEECHCLIENT_H
#include <WiFiClientSecure.h>
#include "Audio.h"
enum Authentication {
  USE_ACCESSTOKEN,
  USE_APIKEY
class CloudSpeechClient {
  WiFiClientSecure client;
  void PrintHttpBody2(Audio* audio);
  Authentication authentication;
public:
  CloudSpeechClient(Authentication authentication);
  ~CloudSpeechClient();
  void Transcribe(Audio* audio);
#endif // _CLOUDSPEECHCLIENT_H
I2S.cpp
#include "I2S.h"
#define SAMPLE_RATE (16000)
#define PIN_I2S_BCLK 26
#define PIN_I2S_LRC 22
#define PIN_I2S_DIN 34
#define PIN_I2S_DOUT 25
// This I2S specification :
//  -   LRC high is channel 2 (right).
//  -   LRC signal transitions once each word.
//  -   DATA is valid on the CLOCK rising edge.
//  -   Data bits are MSB first.
//  -   DATA bits are left-aligned with respect to LRC edge.
//  -   DATA bits are right-shifted by one with respect to LRC edges.
I2S::I2S(MicType micType) {
  if (micType == M5GO || micType == M5STACKFIRE ) {
    BITS_PER_SAMPLE = I2S_BITS_PER_SAMPLE_16BIT;
    i2s_config_t i2s_config = {
      .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_TX | I2S_MODE_DAC_BUILT_IN | I2S_MODE_ADC_BUILT_IN),
      .sample_rate = SAMPLE_RATE,
      .bits_per_sample = BITS_PER_SAMPLE,
      .channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
      .communication_format = (i2s_comm_format_t)(I2S_COMM_FORMAT_I2S_MSB),
      .intr_alloc_flags = 0,
      .dma_buf_count = 2,
      .dma_buf_len = 1024
    i2s_driver_install(I2S_NUM_0, &i2s_config, 0, NULL);
    i2s_set_adc_mode(ADC_UNIT_1, ADC1_CHANNEL_6);
    i2s_set_clk(I2S_NUM_0, SAMPLE_RATE, BITS_PER_SAMPLE, I2S_CHANNEL_STEREO);
    i2s_adc_enable(I2S_NUM_0);
  else if (micType == ADMP441 || micType == ICS43434 ) {
    BITS_PER_SAMPLE = I2S_BITS_PER_SAMPLE_32BIT;
      .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX),
      .communication_format = (i2s_comm_format_t)(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
      .dma_buf_count = 16,
      .dma_buf_len = 60
    i2s_pin_config_t pin_config;
    pin_config.bck_io_num = PIN_I2S_BCLK;
    pin_config.ws_io_num = PIN_I2S_LRC;
    pin_config.data_out_num = I2S_PIN_NO_CHANGE;
    pin_config.data_in_num = PIN_I2S_DIN;
    i2s_set_pin(I2S_NUM_0, &pin_config);
int I2S::Read(char* data, int numData) {
  return i2s_read_bytes(I2S_NUM_0, (char *)data, numData, portMAX_DELAY);
int I2S::GetBitPerSample() {
  return (int)BITS_PER_SAMPLE;
I2S.h
#include "I2S.h"
      .dma_buf_count = 2,
      .dma_buf_len = 1024
      .dma_buf_len = 60
network_param.h
#ifndef _NETWORK_PARAM_H
#define _NETWORK_PARAM_H
const char *ssid = "****";
const char *password = "*****";
const char*  server = "speech.googleapis.com";
// To get the certificate for your region run:
// openssl s_client -showcerts -connect speech.googleapis.com:443
// Copy the certificate (all lines between and including ---BEGIN CERTIFICATE---
// and --END CERTIFICATE--) to root.cert and put here on the root_cert variable.
const char* root_ca=
"-----BEGIN CERTIFICATE-----\n"
"MIIFljCCA36gAwIBAgINAgO8U1lrNMcY9QFQZjANBgkqhkiG9w0BAQsFADBHMQsw\n"
"CQYDVQQGEwJVUzEiMCAGA1UEChMZR29vZ2xlIFRydXN0IFNlcnZpY2VzIExMQzEU\n"
"MBIGA1UEAxMLR1RTIFJvb3QgUjEwHhcNMjAwODEzMDAwMDQyWhcNMjcwOTMwMDAw\n"
"MDQyWjBGMQswCQYDVQQGEwJVUzEiMCAGA1UEChMZR29vZ2xlIFRydXN0IFNlcnZp\n"
"Y2VzIExMQzETMBEGA1UEAxMKR1RTIENBIDFDMzCCASIwDQYJKoZIhvcNAQEBBQAD\n"
"ggEPADCCAQoCggEBAPWI3+dijB43+DdCkH9sh9D7ZYIl/ejLa6T/belaI+KZ9hzp\n"
"kgOZE3wJCor6QtZeViSqejOEH9Hpabu5dOxXTGZok3c3VVP+ORBNtzS7XyV3NzsX\n"
"lOo85Z3VvMO0Q+sup0fvsEQRY9i0QYXdQTBIkxu/t/bgRQIh4JZCF8/ZK2VWNAcm\n"
"BA2o/X3KLu/qSHw3TT8An4Pf73WELnlXXPxXbhqW//yMmqaZviXZf5YsBvcRKgKA\n"
"gOtjGDxQSYflispfGStZloEAoPtR28p3CwvJlk/vcEnHXG0g/Zm0tOLKLnf9LdwL\n"
"tmsTDIwZKxeWmLnwi/agJ7u2441Rj72ux5uxiZ0CAwEAAaOCAYAwggF8MA4GA1Ud\n"
"DwEB/wQEAwIBhjAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIwEgYDVR0T\n"
"AQH/BAgwBgEB/wIBADAdBgNVHQ4EFgQUinR/r4XN7pXNPZzQ4kYU83E1HScwHwYD\n"
"VR0jBBgwFoAU5K8rJnEaK0gnhS9SZizv8IkTcT4waAYIKwYBBQUHAQEEXDBaMCYG\n"
"CCsGAQUFBzABhhpodHRwOi8vb2NzcC5wa2kuZ29vZy9ndHNyMTAwBggrBgEFBQcw\n"
"AoYkaHR0cDovL3BraS5nb29nL3JlcG8vY2VydHMvZ3RzcjEuZGVyMDQGA1UdHwQt\n"
"MCswKaAnoCWGI2h0dHA6Ly9jcmwucGtpLmdvb2cvZ3RzcjEvZ3RzcjEuY3JsMFcG\n"
"A1UdIARQME4wOAYKKwYBBAHWeQIFAzAqMCgGCCsGAQUFBwIBFhxodHRwczovL3Br\n"
"aS5nb29nL3JlcG9zaXRvcnkvMAgGBmeBDAECATAIBgZngQwBAgIwDQYJKoZIhvcN\n"
"AQELBQADggIBAIl9rCBcDDy+mqhXlRu0rvqrpXJxtDaV/d9AEQNMwkYUuxQkq/BQ\n"
"cSLbrcRuf8/xam/IgxvYzolfh2yHuKkMo5uhYpSTld9brmYZCwKWnvy15xBpPnrL\n"
"RklfRuFBsdeYTWU0AIAaP0+fbH9JAIFTQaSSIYKCGvGjRFsqUBITTcFTNvNCCK9U\n"
"+o53UxtkOCcXCb1YyRt8OS1b887U7ZfbFAO/CVMkH8IMBHmYJvJh8VNS/UKMG2Yr\n"
"PxWhu//2m+OBmgEGcYk1KCTd4b3rGS3hSMs9WYNRtHTGnXzGsYZbr8w0xNPM1IER\n"
"lQCh9BIiAfq0g3GvjLeMcySsN1PCAJA/Ef5c7TaUEDu9Ka7ixzpiO2xj2YC/WXGs\n"
"Yye5TBeg2vZzFb8q3o/zpWwygTMD0IZRcZk0upONXbVRWPeyk+gB9lm+cZv9TSjO\n"
"z23HFtz30dZGm6fKa+l3D/2gthsjgx0QGtkJAITgRNOidSOzNIb2ILCkXhAd4FJG\n"
"AJ2xDx8hcFH1mt0G/FX0Kw4zd8NLQsLxdxP8c4CU6x+7Nz/OAipmsHMdMqUybDKw\n"
"juDEI/9bfU1lcKwrmz3O2+BtjjKAvpafkmO8l7tdufThcV4q5O8DIrGKZTqPwJNl\n"
"1IXNDw9bg1kWRxYtnCQ6yICmJhSFm/Y3m6xv+cXDBlHz4n/FsRC6UfTd\n"
"-----END CERTIFICATE-----\n";
// Getting Access Token :
// At first, you should get service account key (JSON file).
// Type below command in Google Cloud Shell to get AccessToken:
// $ gcloud auth activate-service-account --key-file=KEY_FILE   (KEY_FILE is your service account key file)
// $ gcloud auth print-access-token
// The Access Token is expired in an hour.
// Google recommends to use Access Token.
//const String AccessToken = "";
// It is also possible to use "API Key" instead of "Access Token". It doesn't have time limit.
const String ApiKey = "********";
// see https://cloud.google.com/docs/authentication?hl=ja#getting_credentials_for_server-centric_flow
// see https://qiita.com/basi/items/3623a576b754f738138e (Japanese)
#endif  // _NETWORK_PARAM_H
this is the program for text to speech
#include "Arduino.h"
#include "WiFi.h"
#include "Audio.h"
#define uart_en 15
#define RXp2 16
#define TXp2 17
#define I2S_DOUT      25
#define I2S_BCLK      27
#define I2S_LRC       26
Audio audio;
  WiFi.disconnect();
  WiFi.mode(WIFI_STA);
  WiFi.begin( "****", "*****");
    delay(1500);
  audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
  audio.setVolume(100);
  audio.connecttospeech("Starting ", "en"); // Google TTS
if (Serial2.available()){
  String Answer = Serial2.readString();
  Serial.println(Answer);
 audio.connecttospeech(Answer.c_str(), "en");
  audio.loop();
void audio_info(const char *info) {
  Serial.print("audio_info: "); Serial.println(info);}
this is my circuit connection except battery, I am directly giving power to ESP's through USB cable
The problem is while I run the project after speak now word from the speaker when I speak , the mic is not initializing , I have checked mic speartely using i2s mic testing program , when connected in this circuit the mic is not responding , I have checked serial plotter in the Arduino IDE there is no frequency is showing , how to rectify this problem ?
You may mant to ask ChatGPT for the correct answer.
If you got it from ChatGPT it has to be flawless in performance. While you are at it post the schematic ChatGPT gave you you might have miswired something.
