hi all of masters
when i'm using SoftwareSerial when i want to compile the sketch at the end of compiling it shows
exit status 1
Error compiling for board Arduino Due (Programming Port).
what should i do for it??
every suggestion would be great
yours truly
hi hatam_mn
SofwtwareSerial is not compatible with DUE, this library emulet a serial port and works with avr boards.
DUE is a SAM board, you must use the hardware Serial ports, it has 4 hardware
Serial port, Serial0 is the primary port and is the one that we use to download the programs, You can use Serial1
(pin 18,19), Serial2(pin 17,16), Serial3(pin 14,15), Normally I use Serial3 and its work perfect.
Hope this information helps you
Greetings
