Hello,
I have a problem with initializing connection with IMU while using MPU-9250. I am suspecting the possibility of the module being damaged/flawed in some way. I am using an example code given by the IvenSense MPU9250 library, and no matter what, I am getting an error message on the serial monitor Error initializing communication with IMU
. Sometimes the error cuts out a ouple of letters which looks like: Error initializing coation with IMU
or Error initializing comtion with IMU
, however I don't know if it makes all the difference. i will provide you the code and wiring below. I am also using a logic level converter for I have been advised to use that whilst connecting the MPU-9250 to the Arduino UNO. Wiring and code is below.
Code:
* Brian R Taylor
* brian.taylor@bolderflight.com
* Copyright (c) 2021 Bolder Flight Systems Inc
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the “Software”), to
* deal in the Software without restriction, including without limitation the
* rights to use, copy, modify, merge, publish, distribute, sublicense, and/or
* sell copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS
* IN THE SOFTWARE.
#include "mpu9250.h"
/* Mpu9250 object */
bfs::Mpu9250 imu;
/* Serial to display data */
while(!Serial) {}
/* Start the I2C bus */
Wire.begin();
Wire.setClock(400000);
/* I2C bus, 0x68 address */
imu.Config(&Wire, bfs::Mpu9250::I2C_ADDR_PRIM);
/* Initialize and configure IMU */
if (!imu.Begin()) {
Serial.println("Error initializing communication with IMU");
while(1) {}
/* Set the sample rate divider */
if (!imu.ConfigSrd(19)) {
Serial.println("Error configured SRD");
while(1) {}
/* Check if data read */
if (imu.Read()) {
Serial.print(imu.new_imu_data());
Serial.print("\t");
Serial.print(imu.new_mag_data());
Serial.print("\t");
Serial.print(imu.accel_x_mps2());
Serial.print("\t");
Serial.print(imu.accel_y_mps2());
Serial.print("\t");
Serial.print(imu.accel_z_mps2());
Serial.print("\t");
Serial.print(imu.gyro_x_radps());
Serial.print("\t");
Serial.print(imu.gyro_y_radps());
Serial.print("\t");
Serial.print(imu.gyro_z_radps());
Serial.print("\t");
Serial.print(imu.mag_x_ut());
Serial.print("\t");
Serial.print(imu.mag_y_ut());
Serial.print("\t");
Serial.print(imu.mag_z_ut());
Serial.print("\t");
Serial.print(imu.die_temp_c());
Serial.print("\n");
Wiring:
Any and all help will be highly appreciated and I wish you a good day/night
