error: invalid operands of types ‘double’ and ‘int’ to binary ‘operator%’
I'm trying to use the modulus operator in my coding, and every time I compile it the message "error: invalid operands of types ‘double’ and ‘int’ to binary ‘operator%’ " comes up.
This is my code:
#include
#include
using namespace std;
int main()
double seconds, re_seconds, minutes, re_minutes, hours, re_hours, days, re_days, weeks;
cout<<"Hello this program calculates time from seconds."<<endl;
cout<<endl;
cout<< "Enter a number of seconds."<<endl;
cin>>seconds;
// Calculate the minutes, hours, days, weeks
re_seconds=seconds% 60;
minutes=seconds/60;
re_minutes=seconds% 3600;
hours=seconds/3600;
re_hours=seconds% 86400;
days=seconds/86400;
re_days=seconds% 604800;
weeks=seconds/604800;
// Convert from seconds to minutes, hours, and days
if(seconds>0 && seconds<60)
cout<<seconds<<" seconds = "<<seconds<<" seconds"<<endl;
else if(seconds>=60 && seconds<3600)
minutes=seconds/60;
cout<<seconds<<" seconds = "<<minutes<<" minute(s), "<<re_seconds<<" seconds"<<endl;
else if(seconds>=3600 && seconds<86400)
hours=seconds/3600;
cout<<seconds<<" seconds = "<<hours<<" hour(s), "<<re_minutes<<" minutes"<<endl;
else if(seconds>=86400 && seconds<604800)
days=seconds/86400;
cout<<seconds<<" seconds = "<<days<<" day(s)"<<endl;
else if(seconds>=604800)
cout<<seconds<<" seconds = "<<weeks<<" week(s)"<<endl;
else if(seconds<=0)
cout<<"Input is invalid. Put in a different value in the next run."<<endl;
return 0;
Is there any way it can be fixed?
Hw2_q3_code.cpp (1.54 KB)
antione96:
This is the part of my code where the error comes up:
re_seconds=seconds%60;
re_minutes=seconds%3600;
Yes, but show your entire code (or a compilable subset that demonstrates the error.) Please put your code in [ code ] tags so we can see it undisturbed.
you might try to cast numbers to a variable, something like this
double Sixty = 60;
re_seconds = seconds % Sixty;
ZBay:
double Sixty = 60;
I tried that and it still does not work.
what compiler are you using?
Linux
alright here is what I figured the cmath uses fmod(numerator, denominator) to calculate the remainder. I initialized the variables a different way not sure if that is needed but as it's written below the code compiles on g++
#include <iostream>
#include <cmath>
int main()
   double seconds = 0;
   double re_seconds = 0;
   double minutes = 0;
   double re_minutes = 0;
   double hours = 0;
   double re_hours = 0;
   double days = 0;
   double re_days = 0;
   double weeks = 0;
   double Sixty = 60;
   cout <<"Hello this program calculates time from seconds." <<endl;
   cout << endl;
   cout << "Enter a number of seconds." <<endl;
          cin >> seconds;
   re_seconds = fmod (seconds, Sixty);
   minutes=seconds/Sixty;
   re_minutes=fmod(seconds,3600);
   hours=seconds/3600;
   re_hours=fmod(seconds,86400);
   days=seconds/86400;
   re_days=fmod(seconds, 604800);
      re_seconds=fmod(seconds, 60);
      minutes=seconds/60;
      re_minutes=fmod(seconds, 3600);
      hours=seconds/3600;
      days=seconds/86400;
   else if(seconds<=0)
        return 0;
% is an int operator. It does not work with float.
Regards,
Ray L.
