error: 'lcd' was not declared in this scope
Hello. Can somebody help me???
Code:
// include the library code #include
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// initialize our variables
int sensorPin = 0;
int tempC, tempF;
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
tempC = get_temperature(sensorPin);
tempF = celsius_to_fahrenheit(tempC);
lcd.setCursor(0,0);
lcd.print(tempF); lcd.print(" "); lcd.print((char)223); lcd.print("F");
delay(200);
int get_temperature(int pin) {
// We need to tell the function which pin the sensor is hooked up to. We're using
// the variable pin for that above
// Read the value on that pin
int temperature = analogRead(pin);
// Calculate the temperature based on the reading and send that value back
float voltage = temperature * 5.0;
voltage = voltage / 1024.0;
return ((voltage - 0.5) * 100);
int celsius_to_fahrenheit(int temp) {
return (temp * 9 / 5) + 32;
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //Digital pins to which you connect the LCD
const int inPin = 0;                   // A0 is where you connect the sensor
 lcd.begin(16,2);
 int value = analogRead(inPin); // read the value from the sensor
 lcd.setCursor(0,1);
 float millivolts = (value / 1024.0) * 5000;
 float celsius = millivolts / 10;
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print(celsius);
 lcd.print("C");
 lcd.setCursor(0,1);
 lcd.print((celsius * 9)/5 + 32); //turning the celsius into fahrehait
 lcd.print("F");
My problem:
Arduino: 1.8.10 Hourly Build 2019/05/07 05:33 (Windows 10), Board: "Arduino/Genuino Uno"
sketch_may15a:3:1: error: 'LiquidCrystal' does not name a type
C:\Users\Ričardas\Desktop\sketch_may15a\sketch_may15a.ino: In function 'void setup()':
sketch_may15a:9:1: error: 'lcd' was not declared in this scope
C:\Users\Ričardas\Desktop\sketch_may15a\sketch_may15a.ino: In function 'void loop()':
sketch_may15a:14:1: error: 'lcd' was not declared in this scope
sketch_may15a:35:6: error: redefinition of 'void setup()'
C:\Users\Ričardas\Desktop\sketch_may15a\sketch_may15a.ino:7:6: note: 'void setup()' previously defined here
sketch_may15a:39:6: error: redefinition of 'void loop()'
C:\Users\Ričardas\Desktop\sketch_may15a\sketch_may15a.ino:11:6: note: 'void loop()' previously defined here
exit status 1
option enabled in File -> Preferences.
Your code is missing a #include of an appropriate LCD library
Also missing code tags.
Just write of the begging of the code: #include <LiquidCrystal.h> ?
What do you mean by code tags?
How to use this forum-please read. See #7.
groundFungus:
Thanks :slight_smile:
You have two separate sketches, one after the other in your code. You can't do that. You can only have one setup() and one loop(). You need to remove one of the sketches.
tigras13577:
The first sketch is missing the #include directive for the library, so yes you do need to do that. The second sketch does have the necessary #include directive already.
