Hello, I have just had the " 'lcd' was not declared in this scope " error message. Can anyone help?
`int HeaterPIN = 11;// Relay for heater
int HumidityPIN = 9; // Humidity PIN
#include <Wire.h>
#include <HDC2080.h>
#include <LiquidCrystal.h>
#define ADDR 0x40
HDC2080 sensor(ADDR);
// For Heater
pinMode(9, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
sensor.begin();
sensor.reset();
sensor.setMeasurementMode(TEMP_AND_HUMID); // Set measurements to temperature and humidity
sensor.setRate(ONE_HZ); // Set measurement frequency to 1 Hz
sensor.setTempRes(FOURTEEN_BIT);
sensor.setHumidRes(FOURTEEN_BIT);
sensor.triggerMeasurement();
delay(100); // delay in between reads for stability
if (sensor.readTemp() < 37.6666) { //37.6666
digitalWrite(HeaterPIN, LOW);
}else if (sensor.readTemp() > 20) { //20
digitalWrite(HeaterPIN, HIGH);
if (sensor.readHumidity() < 51) { //51
digitalWrite(HumidityPIN, HIGH);
}else if (sensor.readHumidity() > 35) { //35
digitalWrite(HumidityPIN, LOW);
// LCD module connections (RS, E, D4, D5, D6, D7)
LiquidCrystal lcd(7, 6, 10, 8, 3, 2);
char temperature[] = "Temp = 00.0 C";
char humidity[] = "Humidity = 00.0 %";
// set up the LCD's number of columns and rows
lcd.begin(16, 2);
byte Temp = ("Temperature(C): ");
byte (sensor.readTemp());
byte Humid = ("Humidity(%): ");
byte (sensor.readHumidity());
/* temperature[7] = Temp / 10 + 48;
temperature[8] = Temp % 10 + 48;
temperature[11] = 223;
humidity[7] = Humidity / 10 + 48;
humidity[8] = Humidity % 10 + 48;
lcd.setCursor(0, 0);
lcd.print("Temp = ");
lcd.setCursor(8, 0);
lcd.print(sensor.readTemp());
lcd.setCursor(14, 0);
lcd.print("C");
lcd.setCursor(0, 1);
lcd.print("Hum = ");
lcd.setCursor(8, 1);
lcd.print(sensor.readHumidity());
lcd.setCursor(14, 1);
lcd.print("%");
Thank you
