Error message saying: "invalid header file" in Tinkercad
I know there are already many forums about this same problem but I couldn't find the solution in them.
When I start running the program, an error message is displayed and it says: "invalid header file". I know however that all of the libraries I am using are available in Tinkercad. I haven't tried this in real life yet so I don't know if this is a Tinkercad error or my code's.
My project is a small game between 2 players in which I need to connect 3 arduino uno cards together. In order to do that I am using the I2C communication method. Here is the 3 codes for the 3 arduino cards and a picture of the setup:
Good luck to the best out there. This will be a nice challenge for you!
Code of the master arduino:
#include <Wire.h>
#include <LiquidCrystal.h>
// Configuration LCD du joueur 1 (pins: RS = 2, E = 3, DB4 = 4, DB5 = 5, DB6 = 6, DB7 = 7)
LiquidCrystal lcd1(2, 3, 4, 5, 6, 7);
// Configuration LCD du joueur 2 (pins: RS = 8, E = 9, DB4 = 10, DB5 = 11, DB6 = 12, DB7 = 13)
LiquidCrystal lcd2(8, 9, 10, 11, 12, 13);
// Adresses I2C des esclaves
const byte slave1Address = 8;  // Joueur 1
const byte slave2Address = 9;  // Joueur 2
// Durée du jeu en millisecondes (2 minutes)
const unsigned long gameDuration = 120000;
unsigned long startTime;
bool gameOver = false;
int score1 = 0;
int score2 = 0;
  Wire.begin();
  lcd1.begin(16, 2);
  lcd2.begin(16, 2);
  startTime = millis();
  unsigned long elapsed = millis() - startTime;
  int timeRemaining = 0;
  if (elapsed < gameDuration) {
    timeRemaining = (gameDuration - elapsed) / 1000;
    timeRemaining = 0;
    gameOver = true;
  // Envoi du temps restant aux deux esclaves
  sendTimeToSlave(slave1Address, timeRemaining);
  sendTimeToSlave(slave2Address, timeRemaining);
  // Récupération des scores des esclaves
  score1 = requestScoreFromSlave(slave1Address);
  score2 = requestScoreFromSlave(slave2Address);
  // Mise à jour de l'écran du joueur 1
  lcd1.clear();
  lcd1.setCursor(0, 0);
  lcd1.print("P1: ");
  lcd1.print(score1);
  lcd1.setCursor(10, 0);
  lcd1.print("P2: ");
  lcd1.print(score2);
  lcd1.setCursor(4, 1);
  if (!gameOver) {
    lcd1.print("Time: ");
    lcd1.print("GAME OVER");
  lcd1.setCursor(10, 1);
  lcd1.print(timeRemaining);
  // Mise à jour de l'écran du joueur 2
  lcd2.clear();
  lcd2.setCursor(0, 0);
  lcd2.print("P2: ");
  lcd2.print(score2);
  lcd2.setCursor(10, 0);
  lcd2.print("P1: ");
  lcd2.print(score1);
  lcd2.setCursor(4, 1);
  if (!gameOver) {
    lcd2.print("Time: ");
    lcd2.print("GAME OVER");
  lcd2.setCursor(10, 1);
  lcd2.print(timeRemaining);
  delay(200);
void sendTimeToSlave(byte slaveAddress, int timeRemaining) {
  Wire.beginTransmission(slaveAddress);
  Wire.write(highByte(timeRemaining));
  Wire.write(lowByte(timeRemaining));
  Wire.endTransmission();
int requestScoreFromSlave(byte slaveAddress) {
  int score = 0;
  // Correction : cast du second argument en uint8_t pour correspondre à la bonne surcharge
  Wire.requestFrom((uint8_t)slaveAddress, (uint8_t)2);
  if (Wire.available() >= 2) {
    byte high = Wire.read();
    byte low = Wire.read();
    score = (high << 8) | low;
  return score;
Code of the slave arduino cards (The code for the 2 other cards are the same. Only the adress changes from 8 to 9.)
#include <Wire.h>
#define SLAVE_ADDRESS 8  // Adresse pour le joueur 1
// Pins pour boutons dynamiques et leurs LEDs NeoPixel
const int dynButton1Pin = 7;  // Bouton dynamique 1
const int dynLEDPin1   = 3;   // LED NeoPixel associée
const int dynButton2Pin = 4;  // Bouton dynamique 2
const int dynLEDPin2   = 2;   // LED NeoPixel associée
// Boutons pour malus et bingo
const int malusButtonPin = 6;  // Bouton malus (-2 points)
const int bingoButtonPin = 5;  // Bouton bingo (+8 points)
// Initialisation des NeoPixels (1 pixel chacun)
Adafruit_NeoPixel dynLED1 = Adafruit_NeoPixel(1, dynLEDPin1, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel dynLED2 = Adafruit_NeoPixel(1, dynLEDPin2, NEO_GRB + NEO_KHZ800);
// Variables de score et de valeur initiale des boutons dynamiques
int score = 0;
int dynValue1 = 5;  // Valeur initiale = 5 (puis passe à 2, puis à 1)
int dynValue2 = 5;
// Temps restant reçu du maître (en secondes)
volatile int timeRemaining = 120;
// Variables pour le debounce
unsigned long lastDebounce1 = 0;
unsigned long lastDebounce2 = 0;
unsigned long lastDebounceMalus = 0;
unsigned long lastDebounceBingo = 0;
const unsigned long debounceDelay = 50;
  Wire.begin(SLAVE_ADDRESS);
  Wire.onReceive(receiveEvent);
  Wire.onRequest(requestEvent);
  // Configuration des boutons en INPUT_PULLUP
  pinMode(dynButton1Pin, INPUT_PULLUP);
  pinMode(dynButton2Pin, INPUT_PULLUP);
  pinMode(malusButtonPin, INPUT_PULLUP);
  pinMode(bingoButtonPin, INPUT_PULLUP);
  // Les LEDs malus et bingo sont câblées directement sur le 5V/GND, pas besoin de les configurer ici.
  dynLED1.begin();
  dynLED1.show();
  dynLED2.begin();
  dynLED2.show();
  // Initialisation de la couleur des LEDs dynamiques (valeur 5 = vert)
  setDynLEDColor(dynLED1, dynValue1);
  setDynLEDColor(dynLED2, dynValue2);
  if (timeRemaining > 0) {
    // Vérification des boutons dynamiques
    checkDynamicButton(dynButton1Pin, dynLED1, &dynValue1);
    checkDynamicButton(dynButton2Pin, dynLED2, &dynValue2);
    // Vérification des boutons simples (malus et bingo)
    checkSimpleButton(malusButtonPin, -2);
    checkSimpleButton(bingoButtonPin, 8);
void checkDynamicButton(int buttonPin, Adafruit_NeoPixel &led, int *dynValue) {
  int reading = digitalRead(buttonPin);
  // Si le bouton est pressé (LOW) et que le debounce est passé
  if (reading == LOW && (currentMillis - (buttonPin == dynButton1Pin ? lastDebounce1 : lastDebounce2) > debounceDelay)) {
    score += *dynValue;  // Ajout de la valeur actuelle au score
    // Réduire la valeur : 5 -> 2, 2 -> 1 (1 reste 1)
    if (*dynValue == 5) {
      *dynValue = 2;
    } else if (*dynValue == 2) {
      *dynValue = 1;
    setDynLEDColor(led, *dynValue);
    if (buttonPin == dynButton1Pin) {
      lastDebounce1 = currentMillis;
      lastDebounce2 = currentMillis;
    delay(200);
void checkSimpleButton(int buttonPin, int points) {
  if (buttonPin == malusButtonPin) {
    if (reading == LOW && (currentMillis - lastDebounceMalus > debounceDelay)) {
      score += points;  // -2 points pour malus
      lastDebounceMalus = currentMillis;
      delay(200);
  } else if (buttonPin == bingoButtonPin) {
    if (reading == LOW && (currentMillis - lastDebounceBingo > debounceDelay)) {
      score += points;  // +8 points pour bingo
      lastDebounceBingo = currentMillis;
      delay(200);
void setDynLEDColor(Adafruit_NeoPixel &led, int value) {
  uint32_t color;
  if (value == 5) {
    color = led.Color(0, 255, 0);    // Vert
  } else if (value == 2) {
    color = led.Color(255, 255, 0);  // Jaune
    color = led.Color(0, 0, 0);      // Éteint
  led.setPixelColor(0, color);
  led.show();
void receiveEvent(int howMany) {
  if (howMany >= 2) {
    timeRemaining = (high << 8) | low;
void requestEvent() {
  Wire.write(highByte(score));
  Wire.write(lowByte(score));
Thank you for your time!
is this really available in tinkercad?
(I don't know, I don't use tinkercad - so just a question)
Yes. I have already used it on other projects in the past and it worked.
You could have pinned down your problem simply by trying to compile (not upload, just compile, so no physical hardware is needed) your two sketches in the Arduino IDE.
Then you wouldn't have to wonder if you had a Tinkercad error, or an error in your code.
Good luck to you. This will be a nice challenge for you... muting and ignoring.
I don't know for sure, but can Tinkercad work with more than one arduino board? How do you tell the system which board to load which code into?
Couldn’t only one Arduino handle everything ?
The solution on another thread was the "wrong Liquid_Crystal" library... i do not know how the "good" library was installed on TinkerCad.
