Invalid Header File Tinker cad
This is my first tinkercad arduino uno program and I am trying to build a piece of code that will teach children maths. I ran the following program and it gives errors saying, "invalid header file" .
Can anyone help me solve it? Many Thanks.
#include <Wire.h>
// Define LCDs with their I2C addresses
LiquidCrystal_I2C lcdQuestion(0x27, 16, 2); // Question display
LiquidCrystal_I2C lcdAnswer1(0x26, 16, 2);  // Answer 1 display
LiquidCrystal_I2C lcdAnswer2(0x25, 16, 2);  // Answer 2 display
LiquidCrystal_I2C lcdAnswer3(0x24, 16, 2);  // Answer 3 display
LiquidCrystal_I2C lcdAnswer4(0x23, 16, 2);  // Answer 4 display
// Button pins
const int button1 = 2; // Answer 1
const int button2 = 3; // Answer 2
const int button3 = 4; // Answer 3
const int button4 = 5; // Answer 4
const int buttonReset = 6; // Reset and difficulty level
// Game variables
int level = 1;             // Difficulty level
int score = 0;             // Player's score
int correctAnswer = 0;     // Correct answer index
unsigned long lastPress = 0;
bool waitingForAnswer = true;
// Function to generate a math question
void generateQuestion() {
  int num1, num2, answer, wrong1, wrong2, wrong3;
  char operatorSymbol;
  // Generate random numbers and operator based on level
  if (level == 1) {
    num1 = random(1, 11);
    num2 = random(1, 11);
    if (random(0, 2) == 0) {
      operatorSymbol = '+';
      answer = num1 + num2;
      operatorSymbol = '-';
      answer = num1 - num2;
  } else if (level >= 2) {
    num1 = random(1, 21);
    num2 = random(1, 21);
    int operatorChoice = random(0, 4);
    if (operatorChoice == 0) {
    } else if (operatorChoice == 1) {
    } else if (operatorChoice == 2) {
      operatorSymbol = '*';
      answer = num1 * num2;
      operatorSymbol = '/';
      num2 = random(1, 11); // Prevent division by zero and large results
      num1 = num2 * random(1, 11); // Ensure clean division
      answer = num1 / num2;
  // Display the question
  lcdQuestion.clear();
  lcdQuestion.print("Q: ");
  lcdQuestion.print(num1);
  lcdQuestion.print(" ");
  lcdQuestion.print(operatorSymbol);
  lcdQuestion.print(num2);
  // Generate answers
  correctAnswer = random(1, 5);
  wrong1 = answer + random(-5, 6);
  wrong2 = answer + random(-5, 6);
  wrong3 = answer + random(-5, 6);
  // Assign answers to displays
  lcdAnswer1.clear();
  lcdAnswer2.clear();
  lcdAnswer3.clear();
  lcdAnswer4.clear();
  if (correctAnswer == 1) lcdAnswer1.print(answer); else lcdAnswer1.print(wrong1);
  if (correctAnswer == 2) lcdAnswer2.print(answer); else lcdAnswer2.print(wrong2);
  if (correctAnswer == 3) lcdAnswer3.print(answer); else lcdAnswer3.print(wrong3);
  if (correctAnswer == 4) lcdAnswer4.print(answer); else lcdAnswer4.print(wrong1 + 1);
// Function to handle button presses
void handleButtonPress(int button) {
  if (!waitingForAnswer) return;
  if (button == correctAnswer) {
    score++;
    lcdQuestion.print("Correct!");
    lcdQuestion.print("Wrong!");
  waitingForAnswer = false;
  delay(2000);
  generateQuestion();
// Function to reset the game
void resetGame() {
  score = 0;
  level = 1;
  lcdQuestion.print("Level 1");
  delay(2000);
  generateQuestion();
// Function to increase difficulty
void increaseDifficulty() {
  level++;
  if (level > 3) level = 1;
  lcdQuestion.print("Level ");
  lcdQuestion.print(level);
  delay(2000);
  generateQuestion();
  // Initialize LCDs
  lcdQuestion.begin();
  lcdAnswer1.begin();
  lcdAnswer2.begin();
  lcdAnswer3.begin();
  lcdAnswer4.begin();
  lcdQuestion.backlight();
  lcdAnswer1.backlight();
  lcdAnswer2.backlight();
  lcdAnswer3.backlight();
  lcdAnswer4.backlight();
  // Initialize buttons
  pinMode(button1, INPUT_PULLUP);
  pinMode(button2, INPUT_PULLUP);
  pinMode(button3, INPUT_PULLUP);
  pinMode(button4, INPUT_PULLUP);
  pinMode(buttonReset, INPUT_PULLUP);
  // Start game
  generateQuestion();
  if (digitalRead(button1) == LOW) handleButtonPress(1);
  if (digitalRead(button2) == LOW) handleButtonPress(2);
  if (digitalRead(button3) == LOW) handleButtonPress(3);
  if (digitalRead(button4) == LOW) handleButtonPress(4);
  // Reset or increase difficulty
  if (digitalRead(buttonReset) == LOW) {
    unsigned long currentPress = millis();
    if (currentPress - lastPress < 500) {
      increaseDifficulty(); // Double click detected
      resetGame(); // Single click detected
    lastPress = currentPress;
Please, post the complete error in a code block (just like you posted the code). Thank you.
All I know about Tinkercad is that it's a simulator that seems to have a tendency to produce a maddeningly vague and utterly useless error message when the sketch calls don't match the library.
A couple of things to try:
  lcdQuestion.begin(16,2);
  lcdAnswer1.begin(16,2);
  lcdAnswer2.begin(16,2);
  lcdAnswer3.begin(16,2);
  lcdAnswer4.begin(16,2);
and if that doesn't do it:
  lcdQuestion.init();
  lcdAnswer1.init();
  lcdAnswer2.init();
  lcdAnswer3.init();
  lcdAnswer4.init();
I don't know if it even lets you look at the source of the libraries you're including, but if it does, that would be a good thing to check.
The error is: An error occurred...
That is not an IDE verbose error log.
Tinkercad.
This is an Arduino forum.
Sometimes. : )
It's maddeningly vague, and utterly useless, but it is concise. Terse, even. So it's got that going for it. Who really needs error explanations or file names or line and column numbers, right?
You must do
as @van_der_decken says.
With that modification the compilation in Wokwi does not indicate other errors.
It should be the same in TinkerCad.
