//Libraries
#include <Wire.h>
#include "RTClib.h"
#include <LiquidCrystal.h>
#include <EEPROM.h>
#include <dht_nonblocking.h>
//Connections and constants
#define DHT_SENSOR_TYPE DHT_TYPE_11
LiquidCrystal lcd(24,4,22,3,2,23);
int tempC;
double tempK;
int tempReading;
unsigned long starttime;
float temperature;
float humidity;
byte clocksymbol[8] = {
0b00000,
0b00100,
0b01110,
0b01110,
0b11111,
0b00000,
0b00100,
0b00000,
byte temp[8] = {
0b10000,
0b00111,
0b01000,
0b01000,
0b01000,
0b01000,
0b00111,
0b00000,
static const int DHT_SENSOR_PIN = 5;
const int buzzer = 6;
const int isbacklight = 25;
DHT_nonblocking dht_sensor( DHT_SENSOR_PIN, DHT_SENSOR_TYPE );
RTC_DS1307 rtc; //DS1307 i2c
char daysOfTheWeek[7][12] = {"Sunday","Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
const int btSet = A5;
const int btAdj = A4;
const int btAlarm = A3;
const int shakeSensor = A3;
long interval = 300;
int melody[] = { 600, 800, 1000,1200 };
//Variables
int DD,MM,YY,H,M,S,set_state, adjust_state, alarm_state,AH,AM, shake_state;
int shakeTimes=0;
int i =0;
int btnCount = 0;
String sDD;
String sMM;
String sYY;
String sH;
String sM;
String sS;
String aH="12";
String aM="00";
String alarm = " ";
long previousMillis = 0;
//Boolean flags
boolean setupScreen = false;
boolean alarmON=false;
boolean turnItOn = false;
boolean backlightON=true;
//Init RTC and LCD library items
rtc.begin();
lcd.begin(16,2);
//Set outputs/inputs
pinMode(btSet,INPUT_PULLUP);
pinMode(btAdj,INPUT_PULLUP);
pinMode(btAlarm, INPUT_PULLUP);
pinMode(buzzer, OUTPUT);
lcd.createChar(1, clocksymbol);
lcd.createChar(2, temp);
digitalWrite(isbacklight,HIGH);
//Check if RTC has a valid time/date, if not set it to 00:00:00 01/01/2018.
//This will run only at first time or if the coin battery is low.
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running!");
// This line sets the RTC with an explicit date & time, for example to set
// January 1, 2018 at 00:00am you would call:
rtc.adjust(DateTime(2022, 02, 07, 11, 03, 0));
delay(100);
//Read alarm time from EEPROM memmory
AH=EEPROM.read(0);
AM=EEPROM.read(1);
//Check if the numbers that you read are valid. (Hours:0-23 and Minutes: 0-59)
if (AH>23){
AH=0;
if (AM>59){
AM=0;
//starttime=millis();
readBtns();
getTimeDate(); //Read time and date from RTC
if (!setupScreen){
lcdPrint(); //Normanlly print the current time/date/alarm to the LCD
if (alarmON){
callAlarm(); // and check the alarm if set on
else{
lcd.setCursor(10, 0);
lcd.write(" ");
else{
timeSetup(); //If button set is pressed then call the time setup function
if( measure_environment( &temperature, &humidity ) == true )
tempC =temperature;
static bool measure_environment( float *temperature, float *humidity )
static unsigned long measurement_timestamp = millis( );
/* Measure once every four seconds. */
if( millis( ) - measurement_timestamp > 3000ul )
if( dht_sensor.measure( temperature, humidity ) == true )
return( true );
return( false );
/*************** Functions ****************/
//Read buttons state
void readBtns(){
set_state = digitalRead(btSet);
adjust_state = digitalRead(btAdj);
alarm_state = digitalRead(btAlarm);
if(!setupScreen){
if (alarm_state==LOW){
if (alarmON){
alarm=" ";
alarmON=false;
else{
alarmON=true;
if (adjust_state==LOW){
if (backlightON==true){
backlightON=false;
digitalWrite(isbacklight,LOW);
else{
backlightON=true;
if (set_state==LOW){
if(btnCount<7){
btnCount++;
setupScreen = true;
if(btnCount==1){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("------SET------");
lcd.setCursor(0,1);
lcd.print("-TIME and DATE-");
delay(2000);
lcd.clear();
else{
lcd.clear();
rtc.adjust(DateTime(YY, MM, DD, H, M, 0)); //Save time and date to RTC IC
EEPROM.write(0, AH); //Save the alarm hours to EEPROM 0
EEPROM.write(1, AM); //Save the alarm minuted to EEPROM 1
lcd.print("Saving....");
delay(2000);
lcd.clear();
btnCount=0;
//Read time and date from rtc ic
void getTimeDate(){
if (!setupScreen){
DateTime now = rtc.now();
DD = now.day();
MM = now.month();
YY = now.year();
H = now.hour();
M = now.minute();
S = now.second();
//Make some fixes...
if (DD<10){ sDD = '0' + String(DD); } else { sDD = DD; }
if (MM<10){ sMM = '0' + String(MM); } else { sMM = MM; }
sYY=YY-2000;
if (H<10){ sH = '0' + String(H); } else { sH = H; }
if (M<10){ sM = '0' + String(M); } else { sM = M; }
if (S<10){ sS = '0' + String(S); } else { sS = S; }
if (AH<10){ aH = '0' + String(AH); } else { aH = AH; }
if (AM<10){ aM = '0' + String(AM); } else { aM = AM; }
//Print values to the display
void lcdPrint(){
String line1 = sH+":"+sM+":"+sS+" |";
lcd.setCursor(0,0); //First row
lcd.print(line1);
if (alarmON){
lcd.write(1);
String line2 = aH+":"+aM;
lcd.setCursor(11, 0);
lcd.print(line2);
String line3 = sDD+"-"+sMM+"-"+sYY +" | " +tempC ;
lcd.setCursor(0,1); //Second row
lcd.print(line3);
if (setupScreen){
lcd.setCursor(13, 1);
lcd.print("");
else{
lcd.write(2);
//Setup screen
void timeSetup(){
int up_state = adjust_state;
int down_state = alarm_state;
if(btnCount<=5){
if (btnCount==1){ //Set Hour
lcd.setCursor(4,0);
lcd.print(">");
if (up_state == LOW){ //Up button +
if (H<23){
H++;
else {
H=0;
delay(350);
if (down_state == LOW){ //Down button -
if (H>0){
H--;
else {
H=23;
delay(350);
else if (btnCount==2){ //Set Minutes
lcd.setCursor(4,0);
lcd.print(" ");
lcd.setCursor(9,0);
lcd.print(">");
if (M<59){
M++;
else {
M=0;
delay(350);
if (M>0){
M--;
else {
M=59;
delay(350);
else if (btnCount==3){ //Set Day
lcd.setCursor(9,0);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(">");
if (DD<31){
DD++;
else {
DD=1;
delay(350);
if (DD>1){
DD--;
else {
DD=31;
delay(350);
else if (btnCount==4){ //Set Month
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(5,1);
lcd.print(">");
if (MM<12){
MM++;
else {
MM=1;
delay(350);
if (MM>1){
MM--;
else {
MM=12;
delay(350);
else if (btnCount==5){ //Set Year
lcd.setCursor(5,1);
lcd.print(" ");
lcd.setCursor(10,1);
lcd.print(">");
if (YY<2999){
YY++;
else {
YY=2000;
delay(350);
if (YY>2018){
YY--;
else {
YY=2999;
delay(350);
lcd.setCursor(5,0);
lcd.print(sH);
lcd.setCursor(8,0);
lcd.print(":");
lcd.setCursor(10,0);
lcd.print(sM);
lcd.setCursor(1,1);
lcd.print(sDD);
lcd.setCursor(4,1);
lcd.print("-");
lcd.setCursor(6,1);
lcd.print(sMM);
lcd.setCursor(9,1);
lcd.print("-");
lcd.setCursor(11,1);
lcd.print(sYY);
else{
setAlarmTime();
//Set alarm time
void setAlarmTime(){
String line2;
lcd.setCursor(0,0);
lcd.print("SET ALARM TIME");
if (btnCount==6){ //Set alarm Hour
if (AH<23){
AH++;
else {
AH=0;
delay(350);
if (AH>0){
AH--;
else {
AH=23;
delay(350);
line2 = " >"+aH+" : "+aM+" ";
else if (btnCount==7){ //Set alarm Minutes
if (AM<59){
AM++;
else {
AM=0;
delay(350);
if (AM>0){
AM--;
else {
AM=59;
delay(350);
line2 = " "+aH+" :>"+aM+" ";
lcd.setCursor(0,1);
lcd.print(line2);
void callAlarm(){
if (aM==sM && aH==sH && S>=0 && S<=10){
turnItOn = true;
else if(alarm_state==LOW ||(S>=59)){ //||(M==(AM+1))
turnItOn = false;
alarmON=true;
delay(50);
/*if(analogRead(shakeSensor)>1000){
shakeTimes++;
Serial.print(shakeTimes);
delay(50);
if (turnItOn){
if(currentMillis - previousMillis > interval) {
tone(buzzer,melody[i],100);
i++;
if(i>3){i=0; };
Serial.println("00000");
else{
noTone(buzzer);
