Error message while copying code
HI Folks, i was trying to verify this code which I am actually copying and learning at the same time, however it will not verify and keeps on saying that a ":" is missing.
Any advice would be much appreciated. Thanks
The first 4 lines are good and then the error code:
Users\chris\OneDrive\Documents\Arduino\blink_example\blink_example.ino: In function 'void setup()':
blink_example:8:8: error: expected ';' before '{' token
pinMode{myled1, OUTPUT}; //assign pin 4 as output
blink_example:9:8: error: expected ';' before '{' token
pinMode{myled2, OUTPUT}; //assign pin 5 as output
C:\Users\chris\OneDrive\Documents\Arduino\blink_example\blink_example.ino: In function 'void loop()':
blink_example:14:13: error: expected ';' before '{' token
digitalWrite{myled1, HIGH};
exit status 1
option enabled in File -> Preferences.
`int myled1 = 4;       //declare myled1 as the first led`
`int myled2 = 5;       //declare myled2 as the second led`
`int onTime1 = 1000;   //declare ontime as 1 second`
`int offTime = 1500;   //declare offtime as 1.5 seconds`
`void loop() {`
`digitalWrite{myled1, HIGH};`
How are you copying it, and from where?
If you look up the documentation for pinMode, you will not see a "{" mentioned anywhere. :slight_smile:
Oh, wait, I see... you are just reading and typing to copy... and not paying attention... Okay...
Function calls such as the offending pinmode take round brackets, not braces. ( not {.
You can not learn much without reading the documentation and following some tutorials or examples. Guessing won't get you there.
Thanks folks. Yes I could also just copy and paste the code, but need to learn and start somewhere.
thanks for pointing it out - now I have learnt something new.
Cheers
Many thanks
Welcome to the forum.
Does your code now compile?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
yes it does - thanks Tom
