error msg when i add image
when I check the code , msg shows [ done
compiling ] but when I upload to arduino ,error msg show
[ avrdude : vertification error, first mismatch at a byte 0x06bc
0x18 != 0xff
avrdude : vertification error, content mismatc ]
this code to add image :
#include <ITDB02_Graph16.h>
#include <avr/pgmspace.h>
extern uint8_t SmallFont[];
prog_uint16_t FR[0x33BE] PROGMEM ={
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, )
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x2E50 (11856)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x2E60 (11872)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x2E70 (11888)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x2E80 (11904)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,   // 0x2E90 (11920)
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFDE, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x2EA0 (11936)
0x0000, 0x0000, 0xA618, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF,
ITDB02 myGLCD(38,39,40,41);
{ myGLCD.InitLCD(PORTRAIT);
  myGLCD.setFont(SmallFont);
  drawDisplay();
void drawDisplay()
myGLCD.fillScr(255,255,255);
myGLCD.drawBitmap(35, 213, 32, 32, FR);
There is a bug in the bootloader where consecutive 0xFF can cause some of the memory not to be programmed (hence the content mismatch).
I think that applies if a whole "page" is 0xFF because the programmer assumes they have been cleared to 0xFF in advance, when they haven't.
See if you can work out an encoding (compression) scheme such that you don't need all those 0xFFs.
One possible approach could be to simply invert them (so 0xFF becomes 0x00) and then re-invert them for displaying.
You could use my programming sketch here: Gammon Forum : Electronics : Microprocessors : Atmega chip stand-alone programmer to upload .hex files
That doesn't use avrdude, and does clear memory to 0xFF before programming.
