Error occurred when uploading the sketch
Hi, I have a problem with my Arduino. It takes too long to upload and then, it states that there is an error in uploading the sketch.
This is my error message:
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\LENOVO\AppData\Local\Temp\arduino_build_104440/sketch_sep10b.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port : COM3
         Using Programmer : arduino
         Overriding Baud Rate : 115200
An error occurred while uploading the sketch
option enabled in File -> Preferences.
You have to enable verbose output options both for compile and upload.
@b707, curious why both?
Verbose output during upload is already enabled by the looks of the output.
As far as i understood the author only activated the output option during compilation and is having problems during upload - so I asked him to activate both options.
Sorry, I should have said that verbose output during upload is already active. Corrected previous post.
Thank you so much, I will try and let you know.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\LENOVO\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\LENOVO\AppData\Local\Temp\arduino_build_881590 -warnings=none -build-cache C:\Users\LENOVO\AppData\Local\Temp\arduino_cache_503720 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\LENOVO\Documents\Arduino\sketch_sep10b\sketch_sep10b.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\LENOVO\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\LENOVO\AppData\Local\Temp\arduino_build_881590 -warnings=none -build-cache C:\Users\LENOVO\AppData\Local\Temp\arduino_cache_503720 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\LENOVO\Documents\Arduino\sketch_sep10b\sketch_sep10b.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590\\sketch\\sketch_sep10b.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590\\sketch\\sketch_sep10b.ino.cpp" -o "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590\\sketch\\sketch_sep10b.ino.cpp" -o "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590\\sketch\\sketch_sep10b.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\LENOVO\AppData\Local\Temp\arduino_cache_503720\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590/sketch_sep10b.ino.elf" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590\\sketch\\sketch_sep10b.ino.cpp.o" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590/..\\arduino_cache_503720\\core\\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590/sketch_sep10b.ino.elf" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590/sketch_sep10b.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590/sketch_sep10b.ino.elf" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590/sketch_sep10b.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_881590/sketch_sep10b.ino.elf"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\LENOVO\AppData\Local\Temp\arduino_build_881590/sketch_sep10b.ino.hex:i
         Using Port                    : COM3
I tried what you said but it is showing this long error message. Pls help
  1. Does COM3 disappear from the IDE (and Windows device manager) when you disconnect the board?
  2. Anything in Windows device manager that might indicate a problem?
  3. What is the serial-to-usb converter on the board? It's the chip closest to the USB connector. Some possibilities are 16U2, CH34x, CP21xx, FT232x. If there is no print on it, let us know; in that case you will have to follow the below steps.
    You can also take the following steps in Windows device manager
    • Right click on the port.
    • Click properties.
    • Click the details tab.
    • In the Property drop down, select Hardware Ids.
    • You can look those up in e.g. https://devicehunt.com/.
    • Below for an official Arduino Mega; the numbers are 2341 (official Arduino) and 0042 (identifies Mega).
  4. Is this a new board? If not, what is the history?
    • Did it work in the past?
    • What was the last project that you worked on where upload succeeded?
Note
To be able to identify the converter visually, it is the easiest to use a camera so you can enlarge. You might have to tilt the board for the best light.
Ok :+1: will try and update.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\LENOVO\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\LENOVO\AppData\Local\Temp\arduino_build_525555 -warnings=none -build-cache C:\Users\LENOVO\AppData\Local\Temp\arduino_cache_831229 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\LENOVO\Documents\Arduino\scanner_check\scanner_check.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\LENOVO\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\LENOVO\AppData\Local\Temp\arduino_build_525555 -warnings=none -build-cache C:\Users\LENOVO\AppData\Local\Temp\arduino_cache_831229 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\LENOVO\Documents\Arduino\scanner_check\scanner_check.ino
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555\\sketch\\scanner_check.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555\\sketch\\scanner_check.ino.cpp" -o nul
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555\\sketch\\scanner_check.ino.cpp" -o "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555\\sketch\\scanner_check.ino.cpp" -o "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555\\sketch\\scanner_check.ino.cpp.o"
Compiling library "Wire"
Using previously compiled file: C:\Users\LENOVO\AppData\Local\Temp\arduino_build_525555\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\LENOVO\AppData\Local\Temp\arduino_build_525555\libraries\Wire\utility\twi.c.o
Compiling core...
Using precompiled core: C:\Users\LENOVO\AppData\Local\Temp\arduino_cache_831229\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555/scanner_check.ino.elf" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555\\sketch\\scanner_check.ino.cpp.o" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555/..\\arduino_cache_831229\\core\\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555/scanner_check.ino.elf" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555/scanner_check.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555/scanner_check.ino.elf" "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555/scanner_check.ino.hex"
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\LENOVO\\AppData\\Local\\Temp\\arduino_build_525555/scanner_check.ino.elf"
Sketch uses 3990 bytes (12%) of program storage space. Maximum is 32256 bytes.
Global variables use 498 bytes (24%) of dynamic memory, leaving 1550 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\LENOVO\AppData\Local\Temp\arduino_build_525555/scanner_check.ino.hex:i
         Using Port                    : COM3
An error is occuring. pls help
The website is not showing.
Site works here. Else try this google: vid 2341 pid 0042 - Google Search (adjust the numbers)
I have the same Arduino but I do not understand why it is not working
Can you answer all questions in post #9 please.
