Hi there!
I know this subject has been treated many times, but every time I looked into others problem, their situation were different from mine.
My code :
This sketch compiles and uploads Grbl to your 328p-based Arduino!
To use:
- First make sure you have imported Grbl source code into your Arduino
IDE. There are details on our Github website on how to do this.
- Select your Arduino Board and Serial Port in the Tools drop-down menu.
NOTE: Grbl only officially supports 328p-based Arduinos, like the Uno.
Using other boards will likely not work!
- Then just click 'Upload'. That's it!
For advanced users:
If you'd like to see what else Grbl can do, there are some additional
options for customization and features you can enable or disable.
Navigate your file system to where the Arduino IDE has stored the Grbl
source code files, open the 'config.h' file in your favorite text
editor. Inside are dozens of feature descriptions and #defines. Simply
comment or uncomment the #defines or alter their assigned values, save
your changes, and then click 'Upload' here.
Copyright (c) 2015 Sungeun K. Jeon
Released under the MIT-license. See license.txt for details.
#include <grbl.h>
// Do not alter this file!
As you can see, it is the grbl library I downloaded from here.
Error I obtain every time I try to download in arduino UNO :
Arduino : 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Carte : "Arduino/Genuino Uno"
C:\Users\arnau\OneDrive\Documents\Arduino\libraries\grbl\report.c: In function 'report_util_float_setting':
C:\Users\arnau\OneDrive\Documents\Arduino\libraries\grbl\report.c:103:1: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
compilation terminated.
c:/program files/windowsapps/arduinollc.arduinoide_1.8.21.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Uno
Ce rapport pourrait être plus détaillé ave c
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
I tried to change port, nothing, I tried to uninstall and reinstall arduino, nothing, I tried to reboot windows (I don't even know what I did that tho), nothing.
Please help me
