Error on my programme
Hello, when running my program Many errors appear
Could you please help me please
This is my code:
#include <Wire.h>
 #include <Keypad.h>
//#include <LiquidCrystal_I2C.h>
#include <LiquidCrystal.h>
 Arduino Bomb Pro
 The circuit:
 * More info at : http://yin.mainstreamds.com/
 If you need some help mail me to yinbot@gmail.com
 created 4,Sep, 2010
 Modified 11 Nov 2015
 by Ignacio Lillo
//LiquidCrystal_I2C lcd(0x38,16,2);
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3','a'}
  {'4','5','6','b'}
  {'7','8','9','c'}
  {'*','0','#','d'}
byte rowPins[ROWS] = {
  12, 13, A5, A4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {
  A3, A2, A1, A0
}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char codeInput[8];
byte time[4];
boolean refresh=true;//1 refresh one time...
char password[8];
int key=-1;
char lastKey;
char var;
boolean passwordEnable=false;
//Buttons for lcd shield
char BT_RIGHT = '4';
char BT_UP = 'a';
char BT_DOWN = 'b';
char BT_LEFT = '6';
char BT_SEL = 'd';   // Ok key
char BT_CANCEL = 'c';
char BT_DEFUSER = 'x';   // not implemented
//leds
const int REDLED = 11;
const int GREENLED = 10;
//const int BLUELED = 12;
//RELAYPIN
boolean relayEnable = false;
const int RELAYPIN = 9;
//IS VERY IMPORTANT THAT YOU TEST THIS TIME. BY DEFAULT IS IN 1 SEC. THAT IS NOT TOO MUCH. SO TEST IT!
const int RELAY_TIME = 5000;
//TIME INTS
int GAMEHOURS = 0;
int GAMEMINUTES = 45;
int BOMBMINUTES = 4;
int ACTIVATESECONDS = 5;
boolean endGame = false;
boolean sdStatus = false; //search and destroy game enable used in config
boolean saStatus = false; //same but SAbotaghe
boolean doStatus = false; //for DEmolition
boolean start = true;
boolean defusing;
boolean cancelando;
// SOUND TONES
boolean soundEnable = true;
int tonepin = 8; // Pin 13 for the sound
int alarmTone1 = 700;
int alarmTone2 = 2600;
int activeTone = 1330;
int errorTone = 100;
unsigned long iTime;
unsigned long timeCalcVar;
unsigned long redTime;
unsigned long greenTime;
unsigned long iZoneTime;//initial time for zone
byte team=0; // 0 = neutral, 1 = green team, 2 = red team
void setup(){
  lcd.begin(16, 2);
  lcd.setCursor(3,0);
  tone(tonepin,2400,30);
  lcd.print("BLUECORE TECH");// you can add your team name or someting cool
  lcd.setCursor(0,1);
  lcd.print(" AIRSOFT BOMB");// you can add your team name or someting cool
  keypad.setHoldTime(50);
  keypad.setDebounceTime(50);
  keypad.addEventListener(keypadEvent);
  //PinModes
  pinMode(GREENLED, OUTPUT);
  pinMode(REDLED, OUTPUT);
  pinMode(RELAYPIN, OUTPUT);
  // CONFIGURE THE BARS OF PROGRESS BAR
  byte bar1[8] = {
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
  byte bar2[8] = {
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
  byte bar3[8] = {
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
  byte bar4[8] = {
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
  byte bar5[8] = {
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
  byte up[8] = {
    B00000,
    B00100,
    B01110,
    B11111,
    B11111,
    B00000,
    B00000,
  byte down[8] = {
    B00000,
    B00000,
    B11111,
    B11111,
    B01110,
    B00100,
    B00000,
  lcd.createChar(0,bar1);
  lcd.createChar(1,bar2);
  lcd.createChar(2,bar3);
  lcd.createChar(3,bar4);
  lcd.createChar(4,bar5);
  lcd.createChar(5,up);
  lcd.createChar(6,down);
void loop(){
  menuPrincipal();
void keypadEvent(KeypadEvent key){
  switch (keypad.getState()){
    case RELEASED:
      switch (key){
         case 'd': defusing=false;
         case 'c': cancelando=false;
    case HOLD:
      switch (key){
        case 'd': defusing= true;
        case 'c': cancelando=true;
//##################MENUS###############################
void menuPrincipal(){   //MAIN MENU
  digitalWrite(GREENLED, LOW);
  digitalWrite(REDLED, LOW);
  //   if whe start a new game from another we need to restart propertly this variables
  saStatus=false;
  sdStatus=false;
  doStatus=false;
  //Draw menu
  cls();//clear lcd and set cursor to 0,0
  int i=0;
 // HERE YOU CAN ADD MORE ITEMS ON THE MAIN MENU
  lcd.print(menu1[i]);
  lcd.setCursor(15,1);
  checkArrows(i,2);
  while(1){
    var = keypad.waitForKey();
    if(var == BT_UP && i>0){
      i--;
      cls();
      checkArrows(i,2);
      delay(50);
    if(var == BT_DOWN && i<2){
      i++;
      cls();
      checkArrows(i,2);
      delay(50);
    if(var == BT_SEL){
      cls();
      switch (i){
      case 0:
        sdStatus=true;
        configQuickGame();
        startGameCount();
        search();
      case 1:
        saStatus=true;
        configQuickGame();
        startGameCount();
        sabotage();
      case 2:
        doStatus=true;
        configQuickGame();
        startGameCount();
        domination();
      case 3:
        config();
void config(){
  //Draw menu
  lcd.clear();
  lcd.setCursor(0, 0);
  int i=0;
  lcd.print(menu2[i]);
  checkArrows(i,3);
  while(1){
    var=keypad.waitForKey();
      i--;
      lcd.clear();
      checkArrows(i,3);
      delay(50);
    if(var == BT_DOWN && i<3){
      i++;
      lcd.clear();
      checkArrows(i,3);
      delay(50);
    if(var == BT_CANCEL){
      menuPrincipal();
    if(var == BT_SEL){
      lcd.clear();
      switch (i){
      case 0:
        //gameConfigMenu();
      case 1:
        //soundConfigMenu();
      case 2:
        cls();
        lcd.print("RELAYPIN ON!");
        digitalWrite(RELAYPIN, HIGH);   // turn the LED on (HIGH is the voltage level)
        delay(4000);   // wait for 4 second
        cls();
        lcd.print("RELAYPIN OFF!");
        digitalWrite(RELAYPIN, LOW);
        delay(2000);
        config();
void configQuickGame(){
  cls();
  //GAME TIME
  if(sdStatus || doStatus || saStatus){
    menu1:
    cls();
    lcd.print("GAME_TIME");
    delay(100);
    lcd.setCursor(0,1);
    lcd.print("00:00 hh:mm");
    lcd.cursor();
    lcd.blink();
    lcd.setCursor(0,1);
    byte var2=0;
    for(int i=0;i<4;i++){
      while(1){
        if(i==2 && var2==0){
          lcd.print(":");
          var2=1;
        byte varu= getRealNumber();
        if(varu !=11){
          time[i] =  varu;
          Serial.print(varu);
          lcd.print(varu);
    lcd.noCursor();
    lcd.noBlink();
    lcd.setCursor(13,1);
    lcd.print("ok?");
    //zona donde pasamos los items a
    //redibujar
    while(1){
      if(var == 'd') // Accept
        GAMEMINUTES= ((time[0]*600)+(time[1]*60)+(time[2]*10)+(time[3]));
  if(var == 'c') // Cancel or Back Button :')
        goto menu1;
    cls();
  //BOMB TIME
  if(sdStatus || saStatus){
    menu2:
    cls();
    lcd.print("BOMB_TIME");
    delay(100);
    lcd.setCursor(0,1);
    lcd.print("ZERO_MINUTES");
    lcd.cursor();
    lcd.blink();
    lcd.setCursor(0,1);
    for(int i=0;i<2;i++){
      while(1){
        if(varu !=11){
          time[i] =  varu;
          lcd.print(varu);
    lcd.noCursor();
    lcd.noBlink();
    lcd.print("ok?");
    //redibujar
    while(1){
      if(var == 'd') //
        BOMBMINUTES= ((time[0]*10)+(time[1]));
        goto menu2;
    cls();
  cls();
  //ARMING TIME
    menu3:
    cls();
    lcd.print("ARM_TIME");
    delay(100);
    lcd.setCursor(0,1);
    lcd.print("ZERO_SECS");
    lcd.cursor();
    lcd.blink();
    lcd.setCursor(0,1);
      while(1){
        if(varu !=11){
          time[i] =  varu;
          lcd.print(varu);
    lcd.noCursor();
    lcd.noBlink();
    lcd.print("ok?");
    //redibujar
    while(1){
        ACTIVATESECONDS= ((time[0]*10)+(time[1]));
        goto menu3;
    cls();
  //sound??
  if(sdStatus || saStatus || doStatus){
    cls();
    lcd.print("ENABLE_SOUND");
    lcd.setCursor(0,1);
    lcd.print("YES_OR_NOT");
    while(1)
      if(var == 'a' ){
        soundEnable=true;
      if(var == 'b' ){
        soundEnable=false;
  //Activate RELAY at Terrorist game ends??? Boom!
    cls();
    lcd.print("ENABLE_RELAYPIN");
    lcd.setCursor(0,1);
    while(1)
      if(var == 'a' ){
        relayEnable=true;
      if(var == 'b' ){
        relayEnable=false;
  //You Want a password enable-disable game?
    cls();
    lcd.print("ENABLE_CODE");
    lcd.setCursor(0,1);
    lcd.print("YES_OR_NOT);
    while(1)
      if(var == 'a' ){
        setNewPass();
        passwordEnable = true;
      if(var == 'b' ){
        passwordEnable = false;
  //Continue the game :D
void domination(){
  //SETUP INITIAL TIME
  int minutos = GAMEMINUTES-1;
  boolean showGameTime=true;
  unsigned long a;
  unsigned long iTime=millis(); //  initialTime in millisec
  unsigned long aTime;
  team=0;
  iZoneTime=0;
  aTime=0;
  redTime=0;
  greenTime=0;
  int largoTono = 50;
  a=millis();
  //Starting Game Code
  while(1)  // this is the important code, is a little messy but works good.
    if(endGame){
      gameOver();
    keypad.getKey();
    aTime=millis()- iTime;
    //Code for led blinking
    timeCalcVar=(millis()- iTime)%1000;
    if(timeCalcVar >= 0 && timeCalcVar <= 40)
      if(team==1)digitalWrite(GREENLED, HIGH);
      if(team==2)digitalWrite(REDLED, HIGH);
    if(timeCalcVar >= 50 && timeCalcVar <= 100)
      if(team==1)digitalWrite(GREENLED, LOW);
      if(team==2)digitalWrite(REDLED, LOW);
    // Sound!!! same as Destroy
    if(timeCalcVar >= 0 && timeCalcVar <= 40 && soundEnable)tone(tonepin,activeTone,largoTono);
    if(timeCalcVar >= 245 && timeCalcVar <= 255 && minutos-aTime/60000<2 && soundEnable)tone(tonepin,activeTone,largoTono);
    if(timeCalcVar >= 495 && timeCalcVar <= 510 && minutos-aTime/60000<4 && soundEnable)tone(tonepin,activeTone,largoTono);
    if(timeCalcVar >= 745 && timeCalcVar <= 760 && minutos-aTime/60000<2 && soundEnable)tone(tonepin,activeTone,largoTono);
    //Help to count 3 secs
    if(a+2000<millis()){
      a=millis();
      showGameTime=!showGameTime;
      cls();
    //THE NEXT TO METHODS SHOW "GAME TIME" AND "CONTROLED ZONE TIME" IT SHOWS 2 AND 2 SEC EACH
    if(showGameTime){ //THE SECOND IS /2
      lcd.setCursor(3,0);
      lcd.print("GAME TIME");
      lcd.setCursor(3,1);
      printTime(minutos, aTime);
    else if (!showGameTime){
      lcd.setCursor(2,0);
      if(team == 0)lcd.print("NEUTRAL ZONE");
      if(team == 1)lcd.print(" GREEN ZONE");
      if(team == 2)lcd.print("  RED ZONE");
      if(team>0){
        lcd.setCursor(3,1);
        printTimeDom(millis()-iZoneTime,true);
    //###########################CHECKINGS##################
    //Check If Game End
    if(minutos-aTime/60000==0 && 59-((aTime/1000)%60)==0)
      gameOver();
    //Check If IS neutral
    while((defusing || cancelando) && team > 0)
      cls();
      if(team>0)lcd.print("NEUTRALIZING...");
      lcd.setCursor(0,1);
      unsigned int percent=0;
      unsigned long xTime=millis(); //start disabling time
      while(defusing || cancelando)
        //check if game time runs out during the disabling
        aTime= millis()- iTime;
        if((minutos-aTime/60000==0 && 59-((aTime/1000)%60)==0) || minutos-aTime/60000>4000000000){
          endGame = true;
        keypad.getKey();
        timeCalcVar = (millis()- xTime)%1000;
        if( timeCalcVar >= 0 && timeCalcVar <= 20)
          if(soundEnable)tone(tonepin,alarmTone1,200);
        if(timeCalcVar >= 480 && timeCalcVar <= 500)
          if(soundEnable)tone(tonepin,alarmTone2,200);
        unsigned long seconds= millis() - xTime;
        percent = (seconds)/(ACTIVATESECONDS*10);
        drawBar(percent);
        if(percent >= 100)
          if(team==1){
            greenTime+=millis()-iZoneTime;
            iZoneTime=0;
          if(team==2){
            redTime+=millis()-iZoneTime;
            iZoneTime=0;
          team=0;
      cls();
    //Capturing red
    while(defusing && team == 0 )
      cls();
      if(team==0)lcd.print(" CAPTURING ZONE");
      lcd.setCursor(0,1);
      while(defusing)
        keypad.getKey();
          endGame = true;
        drawBar(percent);
        if(percent >= 100)
          team=2;
          iZoneTime=millis();
      cls();
    //getting to green zone
    while(cancelando && team == 0 )
      cls();
      lcd.setCursor(0,1);
      while(cancelando)
        keypad.getKey();
          endGame = true;
        drawBar(percent);
        if(percent >= 100)
          team=1;
          iZoneTime=millis();
      cls();
void gameOver(){
  if(team==1)greenTime+=millis()-iZoneTime;
  if(team==2)redTime+=millis()-iZoneTime;
  while(!defusing){
    keypad.getKey();
    if(defusing){
      keypad.getKey();
    lcd.clear();
    lcd.setCursor(3,0);
    lcd.print("TIME OVER!");
    lcd.setCursor(0,1);
    //check who team win the base
    if(greenTime>redTime){
      //greenteam wins
      lcd.print(" GREEN TEAM WINS");
    else{
      //redteam wins
      lcd.print("  RED TEAM WINS");
    delay(3000);
    keypad.getKey();
    if(defusing){
      keypad.getKey();
    cls();
    lcd.print("Red Time:");
    lcd.setCursor(5,1);
    printTimeDom(redTime,false);
    delay(3000);
    keypad.getKey();
    if(defusing){
    cls();
    lcd.print("Green Time:");
    lcd.setCursor(5,1);
    printTimeDom(greenTime,false);
    delay(3000);
    keypad.getKey();
    if(defusing){
      keypad.getKey();
  cls();
  delay(100);
  lcd.print("Play Again?");
  lcd.setCursor(0,1);
  lcd.print("A : Yes B : No");
  while(1)
    if(var == 'a' ){
      cls();
      domination();
    if(var == 'b' ){
      menuPrincipal();
//This fuction compare codeInput[8] and password[8] variables
boolean comparePassword(){
  for(int i=0;i<8;i++){
    if(codeInput[i]!=password[i])return false;
  return true;
//Set the password variable
void setCode(){
  lcd.setCursor(0, 1);
    while(1){
      var= getNumber();
      if(var !='x'){
        codeInput[i] = var;
        if (i != 0){
          lcd.setCursor(i-1,1);
          lcd.print("*");
          lcd.print(var);
          lcd.print(var);
void setCodeTime(){
  timeCalcVar=millis();
    while(1){
      if(ACTIVATESECONDS*1000+timeCalcVar-millis()<=100){
        codeInput[i]='x';
      lcd.setCursor(11,0);
      printTimeDom(ACTIVATESECONDS*1000+timeCalcVar-millis(),false);
      var= getNumber();
      if(var !='x'){
        codeInput[i] = var;
        if (i != 0){
          lcd.print("*");
          lcd.print(var);
          lcd.print(var);
void setPass(){
    while(1){
      var= getNumber();
      if(var !='x'){
        password[i] =  var;
        if (i != 0){
          lcd.print("*");
          lcd.print(var);
          lcd.print(var);
void setNewPass(){
  while(1){
    lcd.clear();
    lcd.print("Enter New Pass");
    setPass();
    lcd.clear();
    lcd.print("Retype Pass");
    setCode();
    if(comparePassword()){
      lcd.clear();
      lcd.print("Password Set OK!");
      delay(2000);
    else {
      lcd.clear();
      lcd.print("ERROR Dont Match!");
      if(soundEnable)tone(tonepin,errorTone,200);
      delay(2000);
//Whait until a button is pressed is is a number return the number 'char' if not return x
char getNumber(){
  while(1){
    var = keypad.getKey();
    if (var){//
      switch (var) {
      case 'a':
        return 'x';
      case 'b':
        return 'x';
      case 'c':
        return 'x';
      case 'd':
        return 'x';
      case '*':
        return 'x';
      case '#':
        return 'x';
      default:
        return var;
    return 'x';
byte getRealNumber(){
  while(1){
    if (var){//
      switch (var) {
      case '1':
        return 1;
      case '2':
        return 2;
      case '3':
        return 3;
      case '4':
        return 4;
      case '5':
        return 5;
      case '6':
        return 6;
      case '7':
        return 7;
      case '8':
        return 8;
      case '9':
        return 9;
        case '0':
        return 0;
      default:
        return 11;
    return 11;
char* menu1[]={"Search&Destroy","Sabotage","Domination", "Configuration"      };
  char* menu2[]={"Game Config","Sound Config", "Relay Test", "Auto Test"      };
  char* GAME_TIME="Game Time:";
  char* BOMB_TIME="Bomb Time:";
  char* ZERO_MINUTES="00 minutes";
  char* ARM_TIME="Arm Time:";
  char* ZERO_SECS="00 seconds";
  char* ENABLE_SOUND="Enable Sound?";
  char* YES_OR_NOT="A : Yes B : No";
  char* ENABLE_RELAYPIN="Enable Relay?";
  char* ENABLE_CODE="Enable Code Arm?";
  char* GAME_TIME_TOP="GAME TIME";
  char* ARMING_BOMB = "ARMING BOMB";
  char* ENTER_CODE = "Enter Code";
  char* CODE_ERROR = "Code Error!";
  char* BOMB_ARMED = "BOMB ARMED";
  char* DETONATION_IN = "DETONATION IN";
  char* DISARMING = "DISARMING BOMB" ;
  char* DISARM = "DISARMING";
  char* GAME_OVER = " GAME OVER! ";
  char* DEFENDERS_WIN = " DEFENDERS WIN ";
  char* SABOTAGE_FAIL= "SABOTAGE FAIL!";
  //void getConfig(){
////Check first time
//if (EEPROM.read(0)!= 1){
////write default config values
////RELAY_TIME = EEPROM.read(1) * 1000 ;
void sabotage() {
  endGame = false;
  refresh = true;
  cls();
  int minutos = GAMEMINUTES - 1;
  if (start) {
    iTime = millis(); //  initialTime of the game, use this because sabotage mode goes can return to sabotage()
    start = false;
  while (1) { // this is the important code, is a little messy but works good.
    if (endGame) {
      failSplash();
    timeCalcVar = (millis() - iTime) % 1000;
    if (timeCalcVar >= 0 && timeCalcVar <= 50)digitalWrite(GREENLED, HIGH);
    if (timeCalcVar >= 90 && timeCalcVar <= 130)digitalWrite(GREENLED, LOW);
    lcd.setCursor(3, 0);
    lcd.print(GAME_TIME);
    aTime = millis() - iTime;
    lcd.setCursor(3, 1);
    //PRINT TIME ON LCD
    //Check If Game End
    if (minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) {
      failSplash();
    //USED IN PASSWORD GAME
    if ('d' == keypad.getKey() && passwordEnable) {
      lcd.clear();
      lcd.setCursor(2, 0);
      lcd.print(ARMING_BOMB);
      delay(1000);//a little delay to think in the password
      lcd.clear();
      lcd.print(ENTER_CODE);
      setCodeTime();// we need to set the compare variable first
      //then compare :D
      if (comparePassword()) {
        destroySabotage();
      lcd.clear();
      lcd.print(CODE_ERROR);
      if (soundEnable)tone(tonepin, errorTone, 200);
      cls();
    //Check If Is Activating
    while (defusing && !passwordEnable)
      keypad.getKey();
      cls();
      lcd.clear();
      unsigned int percent = 0;
      unsigned long xTime = millis(); //start disabling time
      while (defusing)
        keypad.getKey();
        if ((minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) || minutos - aTime / 60000 > 4000000000)endGame = true;
        timeCalcVar = (millis() - xTime) % 1000;
        if ( timeCalcVar >= 0 && timeCalcVar <= 40)
          if (soundEnable)tone(tonepin, alarmTone1, 200);
        if (timeCalcVar >= 480 && timeCalcVar <= 520)
          if (soundEnable)tone(tonepin, alarmTone2, 200);
        unsigned long seconds = millis() - xTime;
        percent = (seconds) / (ACTIVATESECONDS * 10);
        drawBar(percent);
        if (percent >= 100)
          destroySabotage();// jump to the next gamemode
      cls();
void destroySabotage() {
  endGame = false;
  lcd.clear();
  lcd.print(BOMB_ARMED);
  int minutos = BOMBMINUTES - 1;
  unsigned long iTime = millis();
  int largoTono = 50;
  //MAIN LOOP
  while (1) {
    //If you fail disarm.
    if (endGame) {
      explodeSplash();
    //Led Blink
    if (timeCalcVar >= 0 && timeCalcVar <= 40)
      if (soundEnable)tone(tonepin, activeTone, largoTono);
    if (timeCalcVar >= 180 && timeCalcVar <= 220) {
    //Sound
    if (timeCalcVar >= 245 && timeCalcVar <= 255 && minutos - aTime / 60000 < 2 && soundEnable)tone(tonepin, activeTone, largoTono);
    if (timeCalcVar >= 495 && timeCalcVar <= 510 && minutos - aTime / 60000 < 4 && soundEnable)tone(tonepin, activeTone, largoTono);
    if (timeCalcVar >= 745 && timeCalcVar <= 760 && minutos - aTime / 60000 < 2 && soundEnable)tone(tonepin, activeTone, largoTono);
    if ( minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) < 10)largoTono = 300;
    lcd.setCursor(1, 0);
    lcd.print(DETONATION_IN);
    //Passed Time
    ////////HERE ARE THE TWO OPTIONS THAT ENDS THE GAME///////////
    ////TIME PASED AWAY AND THE BOMB EXPLODES
    if (minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) // Check if game ends
      failSplash();
    //print time
    //// SECOND OPTION: YOU PRESS DISARMING BUTTON
    //IF IS A PASSWORD GAME
      cls();
      lcd.print(DISARMING);
      lcd.clear();
      //then compare :D
        sabotage();
      lcd.clear();
      cls();
    if (defusing && !passwordEnable) // disarming bomb
      lcd.clear();
      lcd.print(DISARM);
      while (defusing)
        keypad.getKey();
        if ((minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) || minutos - aTime / 60000 > 4000000000) {
          endGame = true;
        if (timeCalcVar >= 0 && timeCalcVar <= 20)
        if (timeCalcVar >= 480 && timeCalcVar <= 500)
        unsigned long seconds = (millis() - xTime);
        percent = seconds / (ACTIVATESECONDS * 10);
        drawBar(percent);
        //BOMB DISARMED RETURN TO SABOTAGE
        if (percent >= 100)
          cls();
          lcd.print("Bomb Disarmed");
          sabotage();
      cls();
void search() {
  refresh = true;
  cls();
  unsigned long iTime = millis(); //  initialTime in millisec
  //var='o';
    if (endGame) {
      failSplash();
    lcd.print(GAME_TIME_TOP);
    //PRINT TIME ON LCD
    //Check If Game End
    if (minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0)failSplash();
    //Serial.println(keypad.getKey());
      lcd.clear();
      lcd.clear();
      setCodeTime();// we need to set the comparation variable first it writes on codeInput[]
      //then compare :D
      if (comparePassword()) destroy();
      lcd.clear();
      cls();
      lcd.clear();
      while (defusing)
        keypad.getKey();
                percent = (millis() - xTime) / (ACTIVATESECONDS * 10);
        drawBar(percent);
        Serial.println(millis()-xTime);
          endGame = true;
        if (percent >= 100)
          destroy();// jump to the next gamemode
      cls();
void destroy() {
  lcd.clear();
  int largoTono = 50;
  //MAIN LOOP
  while (1) {
    if (endGame) {
      explodeSplash();
    //Led Blink
    //Sound
    //Passed Time
      explodeSplash();
    //print time
      lcd.clear();
      lcd.clear();
      //then compare :D
        disarmedSplash();
      lcd.clear();
      cls();
      lcd.clear();
      lcd.print(DISARM);
      while (defusing)
        keypad.getKey();
          endGame = true;
        drawBar(percent);
        //BOMB DISARMED GAME OVER
        if (percent >= 100)disarmedSplash();
      cls();
void explodeSplash(){
  cls();
  delay(100);
  endGame = false;
  lcd.setCursor(1,0);
  lcd.print("TERRORISTS WIN");
  lcd.setCursor(4,1);
  lcd.print("GAME OVER");
  for(int i = 200; i>0; i--)// this is the ultra hi definition explosion sound xD
    tone(tonepin,i);
    delay(20);
  noTone(tonepin);
  if(relayEnable){
    activateRelay();
  delay(5000);
  cls();
  //end code
  lcd.setCursor(0,1);
  while(1)
    if(var == 'a' ){
      //We have two options, search & destroy and sabotaje play again options so!
      if(sdStatus){
        startGameCount();
        search();
      if(saStatus){
        saStatus=true;
        startGameCount();
        start=true; //to set iTime to actual millis() :D
        sabotage();
    if(var == 'b' ){
      menuPrincipal();
void failSplash(){
  cls();
  delay(100);
  endGame = false;
  lcd.setCursor(1,0);
  lcd.print("  TIME OUT");
  lcd.setCursor(4,1);
    tone(tonepin,i);
    delay(20);
  noTone(tonepin);
  if(relayEnable){
    activateRelay();
  delay(5000);
  cls();
  //end code
  lcd.setCursor(0,1);
  while(1)
    if(var == 'a' ){
      if(sdStatus){
        startGameCount();
        search();
      if(saStatus){
        saStatus=true;
        startGameCount();
        sabotage();
    if(var == 'b' ){
      menuPrincipal();
void disarmedSplash(){
  endGame = false;
    lcd.clear();
    lcd.setCursor(2,0);
    lcd.print("BOMB DISARMED");
    lcd.setCursor(3,1);
    lcd.print("GOODS WIN");
    delay(5000);
  //end code
  lcd.clear();
  lcd.setCursor(0,1);
  while(1)
    if(var == 'a' ){
      if(sdStatus){
        startGameCount();
        search();
      if(saStatus){
        saStatus=true;
        startGameCount();
        sabotage();
    if(var == 'b' ){
      menuPrincipal();
void drawBar(byte porcent){
  //TODO: Optimize this code
  int box=(8*porcent)/10;
  lcd.setCursor(0,1);
  while(box>=5){
    if(box>=5)
      lcd.write(4);
      box-=5;
    switch(box){
    case 0:
    case 1:
      lcd.write((uint8_t)0);
    case 2:
      lcd.write(1);
    case 3:
      lcd.write(2);
    case 4:
      lcd.write(3);
void cls(){
  lcd.clear();
  lcd.setCursor(0,0);
void printTime(unsigned long minutos, unsigned long aTiempo){
  timeCalcVar=minutos-aTiempo/60000;
  //Hours
  if(timeCalcVar/60==0 && refresh){
      lcd.clear();
      refresh=false;
      //delay(100);
      lcd.setCursor(3,1);
      Serial.println("!!!!");
  if(timeCalcVar/60>=1){
    if(timeCalcVar/60<10)
    lcd.setCursor(2,1);
    lcd.print("0");
    lcd.print(timeCalcVar/60);
  lcd.print(":");
  //minutes
  if(timeCalcVar%60<10)
    lcd.print("0");
    lcd.print(timeCalcVar%60);
  lcd.print(":");
  //seconds
  timeCalcVar=aTiempo/1000;
  if(59-(timeCalcVar%60)<10)
    lcd.print("0");
    lcd.print(59-(timeCalcVar%60));
  lcd.print(":");
  //this not mach with real time, is just a effect, it says 999 because millis%1000 sometimes give 0 LOL
  lcd.print(999-(millis()%1000));
void printTimeDom(unsigned long aTiempo, boolean showMillis){
  //minutes
  if((aTiempo/60000)<10)
    lcd.print("0");
    lcd.print(aTiempo/60000);
  lcd.print(":");
  //seconds
  if(((aTiempo/1000)%60)<10)
    lcd.print("0");
    lcd.print((aTiempo/1000)%60);
  if(showMillis){
    lcd.print(":");
      lcd.print(999-millis()%1000);
void startGameCount(){
  lcd.clear();
  lcd.setCursor(1,0);
  lcd.print("Ready to Begin");
  lcd.setCursor(0,1);
  lcd.print("Push ANY Button");
  keypad.waitForKey();//if you press a button game start
  cls();
  lcd.setCursor(1,0);
  lcd.print("Starting Game");
  for(int i = 5; i > 0 ; i--){ // START COUNT GAME INIT
    lcd.setCursor(5,1);
    tone(tonepin,2000,100);
    lcd.print("IN ");
    lcd.print(i);
  cls();
void checkArrows(byte i,byte maxx ){
  if(i==0){
    lcd.write(6);
  if(i==maxx){
    lcd.setCursor(15,0);
    lcd.write(5);
  if(i>0 && i<maxx){
    lcd.write(6);
    lcd.write(5);
void activateRelay(){
  delay(RELAY_TIME);
Your code is incomplete. I suspect you tried to cut and paste. In particular, the end is incomplete. Please, in the IDE, press ctrl-T then ctrl-shft-c to copy, then in a new message here press ctrl-v. That should insert a complete copy of what's in your IDE screen. Then we can start.
Please also list the Error message, in a separate part of that same message; to do that, at the bottom of the IDE window, you'll see a button to copy the error window text. Use that to capture the complete error message and put it in your message here.
Thanks
P.S. It's also possible you're using the IDE 2.x, and didn't get the complete code through no fault of your own(it is, or was, related to a bug, I think). If so, just scroll to the bottom of your IDE and grab the complete last function and cut-and-paste to your message here.
#include <Wire.h>
#include <Keypad.h>
 Arduino Bomb Pro
 The circuit:
 created 4,Sep, 2010
 by Ignacio Lillo
  { '1', '2', '3', 'a' },
  { '4', '5', '6', 'b' },
  { '7', '8', '9', 'c' },
  { '*', '0', '#', 'd' }
  12, 13, A5, A4
  A3, A2, A1, A0
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
char codeInput[8];
byte time[4];
boolean refresh = true;  //1 refresh one time...
char password[8];
int key = -1;
char lastKey;
char var;
boolean passwordEnable = false;
char BT_UP = 'a';
char BT_DOWN = 'b';
char BT_LEFT = '6';
//leds
//RELAYPIN
//TIME INTS
int GAMEHOURS = 0;
boolean defusing;
boolean cancelando;
// SOUND TONES
unsigned long iZoneTime;  //initial time for zone
byte team = 0;            // 0 = neutral, 1 = green team, 2 = red team
  lcd.begin(16, 2);
  tone(tonepin, 2400, 30);
  lcd.print("BLUECORE TECH");  // you can add your team name or someting cool
  lcd.print(" AIRSOFT BOMB");  // you can add your team name or someting cool
  //PinModes
  byte bar1[8] = {
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
  byte bar2[8] = {
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
  byte bar3[8] = {
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
  byte bar4[8] = {
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
  byte bar5[8] = {
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
  byte up[8] = {
    B00000,
    B00100,
    B01110,
    B11111,
    B11111,
    B00000,
    B00000,
  byte down[8] = {
    B00000,
    B00000,
    B11111,
    B11111,
    B01110,
    B00100,
    B00000,
  lcd.createChar(0, bar1);
  lcd.createChar(1, bar2);
  lcd.createChar(2, bar3);
  lcd.createChar(3, bar4);
  lcd.createChar(4, bar5);
  lcd.createChar(5, up);
  lcd.createChar(6, down);
  menuPrincipal();
void keypadEvent(KeypadEvent key) {
  switch (keypad.getState()) {
    case RELEASED:
      switch (key) {
        case 'd':
          defusing = false;
        case 'c':
          cancelando = false;
    case HOLD:
      switch (key) {
        case 'd':
          defusing = true;
        case 'c':
          cancelando = true;
void menuPrincipal() {  //MAIN MENU
  saStatus = false;
  sdStatus = false;
  doStatus = false;
  //Draw menu
  cls();  //clear lcd and set cursor to 0,0
  int i = 0;
  lcd.setCursor(15, 1);
  checkArrows(i, 2);
  while (1) {
    if (var == BT_UP && i > 0) {
      i--;
      cls();
      checkArrows(i, 2);
      delay(50);
    if (var == BT_DOWN && i < 2) {
      i++;
      cls();
      checkArrows(i, 2);
      delay(50);
    if (var == BT_SEL) {
      cls();
      switch (i) {
        case 0:
          sdStatus = true;
          configQuickGame();
          startGameCount();
          search();
        case 1:
          saStatus = true;
          configQuickGame();
          startGameCount();
          sabotage();
        case 2:
          doStatus = true;
          configQuickGame();
          startGameCount();
          domination();
        case 3:
          config();
void config() {
  //Draw menu
  lcd.clear();
  int i = 0;
  checkArrows(i, 3);
  while (1) {
      i--;
      lcd.clear();
      checkArrows(i, 3);
      delay(50);
    if (var == BT_DOWN && i < 3) {
      i++;
      lcd.clear();
      checkArrows(i, 3);
      delay(50);
    if (var == BT_CANCEL) {
      menuPrincipal();
      lcd.clear();
      switch (i) {
        case 0:
          //gameConfigMenu();
        case 1:
        case 2:
          cls();
          cls();
          delay(2000);
          config();
void configQuickGame() {
  cls();
  //GAME TIME
  if (sdStatus || doStatus || saStatus) {
menu1:
    cls();
    delay(100);
    lcd.cursor();
    lcd.blink();
    byte var2 = 0;
    for (int i = 0; i < 4; i++) {
      while (1) {
        if (i == 2 && var2 == 0) {
          lcd.print(":");
          var2 = 1;
        byte varu = getRealNumber();
        if (varu != 11) {
          time[i] = varu;
          Serial.print(varu);
          lcd.print(varu);
    lcd.noCursor();
    lcd.noBlink();
    lcd.setCursor(13, 1);
    lcd.print("ok?");
    //redibujar
    while (1) {
      if (var == 'd')  // Accept
        GAMEMINUTES = ((time[0] * 600) + (time[1] * 60) + (time[2] * 10) + (time[3]));
      if (var == 'c')  // Cancel or Back Button :')
        goto menu1;
    cls();
  //BOMB TIME
  if (sdStatus || saStatus) {
menu2:
    cls();
    delay(100);
    lcd.cursor();
    lcd.blink();
    for (int i = 0; i < 2; i++) {
      while (1) {
        if (varu != 11) {
          time[i] = varu;
          lcd.print(varu);
    lcd.noCursor();
    lcd.noBlink();
    lcd.print("ok?");
    //redibujar
    while (1) {
      if (var == 'd')  //
        BOMBMINUTES = ((time[0] * 10) + (time[1]));
        goto menu2;
    cls();
  cls();
  //ARMING TIME
menu3:
    cls();
    delay(100);
    lcd.cursor();
    lcd.blink();
      while (1) {
        if (varu != 11) {
          time[i] = varu;
          lcd.print(varu);
    lcd.noCursor();
    lcd.noBlink();
    lcd.print("ok?");
    //redibujar
    while (1) {
        ACTIVATESECONDS = ((time[0] * 10) + (time[1]));
        goto menu3;
    cls();
  //sound??
  if (sdStatus || saStatus || doStatus) {
    cls();
    while (1) {
      if (var == 'a') {
        soundEnable = true;
      if (var == 'b') {
        soundEnable = false;
    cls();
    while (1) {
      if (var == 'a') {
        relayEnable = true;
      if (var == 'b') {
    cls();
    while(1)
      if (var == 'a') {
        setNewPass();
      if (var == 'b') {
void domination() {
  boolean showGameTime = true;
  unsigned long a;
  team = 0;
  iZoneTime = 0;
  aTime = 0;
  redTime = 0;
  greenTime = 0;
  int largoTono = 50;
  a = millis();
  while (1)  // this is the important code, is a little messy but works good.
    if (endGame) {
      gameOver();
    keypad.getKey();
    if (timeCalcVar >= 0 && timeCalcVar <= 40) {
      if (team == 1) digitalWrite(GREENLED, HIGH);
      if (team == 2) digitalWrite(REDLED, HIGH);
    if (timeCalcVar >= 50 && timeCalcVar <= 100) {
      if (team == 1) digitalWrite(GREENLED, LOW);
      if (team == 2) digitalWrite(REDLED, LOW);
    if (timeCalcVar >= 0 && timeCalcVar <= 40 && soundEnable) tone(tonepin, activeTone, largoTono);
    if (timeCalcVar >= 245 && timeCalcVar <= 255 && minutos - aTime / 60000 < 2 && soundEnable) tone(tonepin, activeTone, largoTono);
    if (timeCalcVar >= 495 && timeCalcVar <= 510 && minutos - aTime / 60000 < 4 && soundEnable) tone(tonepin, activeTone, largoTono);
    if (timeCalcVar >= 745 && timeCalcVar <= 760 && minutos - aTime / 60000 < 2 && soundEnable) tone(tonepin, activeTone, largoTono);
    if (a + 2000 < millis()) {
      a = millis();
      showGameTime = !showGameTime;
      cls();
    if (showGameTime) {  //THE SECOND IS /2
    } else if (!showGameTime) {
      if (team == 0) lcd.print("NEUTRAL ZONE");
      if (team == 1) lcd.print(" GREEN ZONE");
      if (team == 2) lcd.print("  RED ZONE");
      if (team > 0) {
        printTimeDom(millis() - iZoneTime, true);
    //Check If Game End
      gameOver();
    while ((defusing || cancelando) && team > 0) {
      cls();
      if (team > 0) lcd.print("NEUTRALIZING...");
      while (defusing || cancelando) {
          endGame = true;
        keypad.getKey();
        if (timeCalcVar >= 0 && timeCalcVar <= 20) {
          if (soundEnable) tone(tonepin, alarmTone1, 200);
        if (timeCalcVar >= 480 && timeCalcVar <= 500) {
          if (soundEnable) tone(tonepin, alarmTone2, 200);
        drawBar(percent);
        if (percent >= 100) {
          if (team == 1) {
            greenTime += millis() - iZoneTime;
            iZoneTime = 0;
          if (team == 2) {
            redTime += millis() - iZoneTime;
            iZoneTime = 0;
          team = 0;
      cls();
    //Capturing red
    while (defusing && team == 0) {
      cls();
      if (team == 0) lcd.print(" CAPTURING ZONE");
      while (defusing) {
        keypad.getKey();
          endGame = true;
        drawBar(percent);
          team = 2;
          iZoneTime = millis();
      cls();
    while (cancelando && team == 0) {
      cls();
      while (cancelando) {
        keypad.getKey();
          endGame = true;
        drawBar(percent);
          team = 1;
      cls();
void gameOver() {
  if (team == 1) greenTime += millis() - iZoneTime;
  if (team == 2) redTime += millis() - iZoneTime;
  while (!defusing) {
    keypad.getKey();
    if (defusing) {
      keypad.getKey();
    lcd.clear();
    if (greenTime > redTime) {
      //greenteam wins
      //redteam wins
    delay(3000);
    keypad.getKey();
    if (defusing) {
      keypad.getKey();
    cls();
    lcd.setCursor(5, 1);
    printTimeDom(redTime, false);
    delay(3000);
    keypad.getKey();
    if (defusing) {
    cls();
    printTimeDom(greenTime, false);
    delay(3000);
    keypad.getKey();
    if (defusing) {
      keypad.getKey();
  cls();
  delay(100);
  while (1) {
    if (var == 'a') {
      cls();
      domination();
    if (var == 'b') {
      menuPrincipal();
boolean comparePassword() {
  for (int i = 0; i < 8; i++) {
    if (codeInput[i] != password[i]) return false;
  return true;
void setCode() {
    while (1) {
      var = getNumber();
      if (var != 'x') {
        codeInput[i] = var;
        if (i != 0) {
          lcd.setCursor(i - 1, 1);
          lcd.print("*");
          lcd.print(var);
          lcd.print(var);
void setCodeTime() {
  timeCalcVar = millis();
    while (1) {
      if (ACTIVATESECONDS * 1000 + timeCalcVar - millis() <= 100) {
        codeInput[i] = 'x';
      lcd.setCursor(11, 0);
      printTimeDom(ACTIVATESECONDS * 1000 + timeCalcVar - millis(), false);
      var = getNumber();
      if (var != 'x') {
        codeInput[i] = var;
        if (i != 0) {
          lcd.print("*");
          lcd.print(var);
          lcd.print(var);
void setPass() {
    while (1) {
      var = getNumber();
      if (var != 'x') {
        password[i] = var;
        if (i != 0) {
          lcd.print("*");
          lcd.print(var);
          lcd.print(var);
void setNewPass() {
  while (1) {
    lcd.clear();
    setPass();
    lcd.clear();
    setCode();
      lcd.clear();
      delay(2000);
      lcd.clear();
      if (soundEnable) tone(tonepin, errorTone, 200);
      delay(2000);
char getNumber() {
  while (1) {
    if (var) {  //
      switch (var) {
        case 'a':
          return 'x';
        case 'b':
          return 'x';
        case 'c':
          return 'x';
        case 'd':
          return 'x';
        case '*':
          return 'x';
        case '#':
          return 'x';
        default:
          return var;
    return 'x';
byte getRealNumber() {
  while (1) {
    if (var) {  //
      switch (var) {
        case '1':
          return 1;
        case '2':
          return 2;
        case '3':
          return 3;
        case '4':
          return 4;
        case '5':
          return 5;
        case '6':
          return 6;
        case '7':
          return 7;
        case '8':
          return 8;
        case '9':
          return 9;
        case '0':
          return 0;
        default:
          return 11;
    return 11;
char* menu1[] = { "Search&Destroy", "Sabotage", "Domination", "Configuration" };
char* menu2[] = { "Game Config", "Sound Config", "Relay Test", "Auto Test" };
char* GAME_TIME = "Game Time:";
char* BOMB_TIME = "Bomb Time:";
char* ZERO_MINUTES = "00 minutes";
char* ARM_TIME = "Arm Time:";
char* ZERO_SECS = "00 seconds";
char* ENABLE_SOUND = "Enable Sound?";
char* YES_OR_NOT = "A : Yes B : No";
char* ENABLE_RELAYPIN = "Enable Relay?";
char* ENABLE_CODE = "Enable Code Arm?";
char* GAME_TIME_TOP = "GAME TIME";
char* DISARMING = "DISARMING BOMB";
char* SABOTAGE_FAIL = "SABOTAGE FAIL!";
//void getConfig(){
void sabotage() {
  endGame = false;
  refresh = true;
  cls();
  if (start) {
    start = false;
    if (endGame) {
      failSplash();
    if (timeCalcVar >= 0 && timeCalcVar <= 50) digitalWrite(GREENLED, HIGH);
    if (timeCalcVar >= 90 && timeCalcVar <= 130) digitalWrite(GREENLED, LOW);
    //PRINT TIME ON LCD
    //Check If Game End
      failSplash();
      lcd.clear();
      delay(1000);  //a little delay to think in the password
      lcd.clear();
      setCodeTime();  // we need to set the compare variable first
      //then compare :D
        destroySabotage();
      lcd.clear();
      cls();
    while (defusing && !passwordEnable) {
      keypad.getKey();
      cls();
      lcd.clear();
      while (defusing) {
        keypad.getKey();
        if ((minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) || minutos - aTime / 60000 > 4000000000) endGame = true;
        if (timeCalcVar >= 480 && timeCalcVar <= 520) {
        drawBar(percent);
          destroySabotage();  // jump to the next gamemode
      cls();
  endGame = false;
  lcd.clear();
  int largoTono = 50;
  //MAIN LOOP
  while (1) {
    if (endGame) {
      explodeSplash();
    //Led Blink
      if (soundEnable) tone(tonepin, activeTone, largoTono);
    //Sound
    if (minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) < 10) largoTono = 300;
    //Passed Time
      failSplash();
    //print time
      cls();
      lcd.clear();
      //then compare :D
        sabotage();
      lcd.clear();
      cls();
      lcd.clear();
      lcd.print(DISARM);
      while (defusing) {
        keypad.getKey();
          endGame = true;
        drawBar(percent);
          cls();
          sabotage();
      cls();
void search() {
  refresh = true;
  cls();
  //var='o';
    if (endGame) {
      failSplash();
    //PRINT TIME ON LCD
    //Check If Game End
    if (minutos - aTime / 60000 == 0 && 59 - ((aTime / 1000) % 60) == 0) failSplash();
      lcd.clear();
      lcd.clear();
      setCodeTime();  // we need to set the comparation variable first it writes on codeInput[]
      //then compare :D
      lcd.clear();
      cls();
      lcd.clear();
      while (defusing) {
        keypad.getKey();
        drawBar(percent);
        Serial.println(millis() - xTime);
          endGame = true;
          destroy();  // jump to the next gamemode
      cls();
void destroy() {
  lcd.clear();
  int largoTono = 50;
  //MAIN LOOP
  while (1) {
    if (endGame) {
      explodeSplash();
    //Led Blink
    //Sound
    //Passed Time
      explodeSplash();
    //print time
      lcd.clear();
      lcd.clear();
      //then compare :D
        disarmedSplash();
      lcd.clear();
      cls();
      lcd.clear();
      lcd.print(DISARM);
      while (defusing) {
        keypad.getKey();
          endGame = true;
        drawBar(percent);
        if (percent >= 100) disarmedSplash();
      cls();
void explodeSplash() {
  cls();
  delay(100);
  endGame = false;
  lcd.setCursor(4, 1);
  for (int i = 200; i > 0; i--)  // this is the ultra hi definition explosion sound xD
    tone(tonepin, i);
    delay(20);
  noTone(tonepin);
  if (relayEnable) {
    activateRelay();
  delay(5000);
  cls();
  //end code
  while (1) {
    if (var == 'a') {
      if (sdStatus) {
        startGameCount();
        search();
      if (saStatus) {
        saStatus = true;
        startGameCount();
        start = true;  //to set iTime to actual millis() :D
        sabotage();
    if (var == 'b') {
      menuPrincipal();
void failSplash() {
  cls();
  delay(100);
  endGame = false;
    tone(tonepin, i);
    delay(20);
  noTone(tonepin);
  if (relayEnable) {
    activateRelay();
  delay(5000);
  cls();
  //end code
  while (1) {
    if (var == 'a') {
      if (sdStatus) {
        startGameCount();
        search();
      if (saStatus) {
        saStatus = true;
        startGameCount();
        sabotage();
    if (var == 'b') {
      menuPrincipal();
void disarmedSplash() {
  endGame = false;
    lcd.clear();
    delay(5000);
  //end code
  lcd.clear();
  while (1) {
    if (var == 'a') {
      if (sdStatus) {
        startGameCount();
        search();
      if (saStatus) {
        saStatus = true;
        startGameCount();
        sabotage();
    if (var == 'b') {
      menuPrincipal();
void drawBar(byte porcent) {
  int box = (8 * porcent) / 10;
  while (box >= 5) {
    if (box >= 5) {
      lcd.write(4);
      box -= 5;
  switch (box) {
    case 0:
    case 1:
    case 2:
      lcd.write(1);
    case 3:
      lcd.write(2);
    case 4:
      lcd.write(3);
void cls() {
  lcd.clear();
void printTime(unsigned long minutos, unsigned long aTiempo) {
  timeCalcVar = minutos - aTiempo / 60000;
  //Hours
  if (timeCalcVar / 60 == 0 && refresh) {
    lcd.clear();
    refresh = false;
    //delay(100);
  if (timeCalcVar / 60 >= 1) {
    if (timeCalcVar / 60 < 10) {
      lcd.setCursor(2, 1);
      lcd.print("0");
      lcd.print(timeCalcVar / 60);
    lcd.print(":");
  //minutes
  if (timeCalcVar % 60 < 10) {
    lcd.print("0");
    lcd.print(timeCalcVar % 60);
  lcd.print(":");
  //seconds
  timeCalcVar = aTiempo / 1000;
  if (59 - (timeCalcVar % 60) < 10) {
    lcd.print("0");
    lcd.print(59 - (timeCalcVar % 60));
  lcd.print(":");
  lcd.print(999 - (millis() % 1000));
void printTimeDom(unsigned long aTiempo, boolean showMillis) {
  //minutes
  if ((aTiempo / 60000) < 10) {
    lcd.print("0");
    lcd.print(aTiempo / 60000);
  lcd.print(":");
  //seconds
  if (((aTiempo / 1000) % 60) < 10) {
    lcd.print("0");
    lcd.print((aTiempo / 1000) % 60);
  if (showMillis) {
    lcd.print(":");
    lcd.print(999 - millis() % 1000);
void startGameCount() {
  lcd.clear();
  keypad.waitForKey();  //if you press a button game start
  cls();
  for (int i = 5; i > 0; i--) {  // START COUNT GAME INIT
    tone(tonepin, 2000, 100);
    lcd.print("IN ");
    lcd.print(i);
  cls();
void checkArrows(byte i, byte maxx) {
  if (i == 0) {
    lcd.write(6);
  if (i == maxx) {
    lcd.setCursor(15, 0);
    lcd.write(5);
  if (i > 0 && i < maxx) {
    lcd.write(6);
    lcd.write(5);
void activateRelay() {
  delay(RELAY_TIME);
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:554:15: error: missing terminating " character
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void menuPrincipal()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:229:3: error: 'cls' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:229:3: note: suggested alternative: 'cos'
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:232:13: error: 'menu1' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:232:13: note: suggested alternative: 'enum'
enum
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:234:3: error: 'checkArrows' was not declared in this scope
checkArrows(i,2);
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:263:9: error: 'startGameCount' was not declared in this scope
startGameCount();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:264:9: error: 'search' was not declared in this scope
search();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:264:9: note: suggested alternative: 'bsearch'
search();
bsearch
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:270:9: error: 'sabotage' was not declared in this scope
sabotage();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:277:9: error: 'domination' was not declared in this scope
domination();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void config()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:295:13: error: 'menu2' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:295:13: note: suggested alternative: 'enum'
enum
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:296:3: error: 'checkArrows' was not declared in this scope
checkArrows(i,3);
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:335:9: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:335:9: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void configQuickGame()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:353:3: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:353:3: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:373:20: error: 'getRealNumber' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:424:20: error: 'getRealNumber' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:471:20: error: 'getRealNumber' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:556:5: error: expected primary-expression before 'while'
while(1)
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void domination()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:598:7: error: 'gameOver' was not declared in this scope
gameOver();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:625:7: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:625:7: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:633:7: error: 'printTime' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:633:7: note: suggested alternative: 'iTime'
iTime
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:644:9: error: 'printTimeDom' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:653:7: error: 'gameOver' was not declared in this scope
gameOver();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:659:7: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:659:7: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:687:9: error: 'drawBar' was not declared in this scope
drawBar(percent);
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:713:7: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:713:7: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:741:9: error: 'drawBar' was not declared in this scope
drawBar(percent);
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:759:7: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:759:7: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:787:9: error: 'drawBar' was not declared in this scope
drawBar(percent);
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void gameOver()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:838:5: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:838:5: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:841:5: error: 'printTimeDom' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:859:3: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:859:3: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void setCode()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:896:12: error: 'getNumber' was not declared in this scope
var= getNumber();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void setCodeTime()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:927:7: error: 'printTimeDom' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:929:12: error: 'getNumber' was not declared in this scope
var= getNumber();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void setPass()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:953:12: error: 'getNumber' was not declared in this scope
var= getNumber();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void sabotage()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1131:3: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1131:3: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1149:7: error: 'failSplash' was not declared in this scope
failSplash();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1162:5: error: 'printTime' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1162:5: note: suggested alternative: 'iZoneTime'
iZoneTime
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1167:7: error: 'failSplash' was not declared in this scope
failSplash();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1185:9: error: 'destroySabotage' was not declared in this scope
destroySabotage();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1185:9: note: suggested alternative: 'sabotage'
destroySabotage();
sabotage
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1228:9: error: 'drawBar' was not declared in this scope
drawBar(percent);
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1233:11: error: 'destroySabotage' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1233:11: note: suggested alternative: 'sabotage'
sabotage
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void destroySabotage()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1258:7: error: 'explodeSplash' was not declared in this scope
explodeSplash();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1292:7: error: 'failSplash' was not declared in this scope
failSplash();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1295:5: error: 'printTime' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1295:5: note: suggested alternative: 'iTime'
iTime
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1303:7: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1303:7: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1359:9: error: 'drawBar' was not declared in this scope
drawBar(percent);
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1364:11: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1364:11: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1372:7: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1372:7: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void search()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1379:3: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1379:3: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1393:7: error: 'failSplash' was not declared in this scope
failSplash();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1408:5: error: 'printTime' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1408:5: note: suggested alternative: 'iTime'
iTime
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1413:73: error: 'failSplash' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1429:30: error: 'destroy' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1452:9: error: 'drawBar' was not declared in this scope
drawBar(percent);
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1477:11: error: 'destroy' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void destroy()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1502:7: error: 'explodeSplash' was not declared in this scope
explodeSplash();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1535:7: error: 'explodeSplash' was not declared in this scope
explodeSplash();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1539:5: error: 'printTime' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1539:5: note: suggested alternative: 'iTime'
iTime
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1561:9: error: 'disarmedSplash' was not declared in this scope
disarmedSplash();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1568:7: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1568:7: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1601:9: error: 'drawBar' was not declared in this scope
drawBar(percent);
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1604:28: error: 'disarmedSplash' was not declared in this scope
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1608:7: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1608:7: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void explodeSplash()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1616:3: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1616:3: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1630:5: error: 'activateRelay' was not declared in this scope
activateRelay();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1646:9: error: 'startGameCount' was not declared in this scope
startGameCount();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1651:9: error: 'startGameCount' was not declared in this scope
startGameCount();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void failSplash()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1667:3: error: 'cls' was not declared in this scope
cls();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1667:3: note: suggested alternative: 'cos'
cls();
cos
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1681:5: error: 'activateRelay' was not declared in this scope
activateRelay();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1697:9: error: 'startGameCount' was not declared in this scope
startGameCount();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1702:9: error: 'startGameCount' was not declared in this scope
startGameCount();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino: In function 'void disarmedSplash()':
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1743:9: error: 'startGameCount' was not declared in this scope
startGameCount();
C:\Users\lucas\Downloads\FYW1PMWILGVF3ZU\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:1748:9: error: 'startGameCount' was not declared in this scope
startGameCount();
exit status 1
Compilation error: missing terminating " character
The code comes from https://youtu.be/bZEDZN-EnIM
Fix that first. Try
lcd.print("YES_OR_NO");
Read the error message that line causes and fix it.
Did you build exactly the circuit and use exactly the code form this instructable?
It is not impossible, but it seems unlikely that the code would have one syntax error like the first the compiler seems to discover in your version.
YES or NOT seems unusual, too… did you make a few tiny changes to the sketch?
Try slavishly recreating the project as it is exposed before you go getting creative.
a7
OK, @redwally you have made complete trash of the sketch contained in the zip from the instructable.
When you wrestle this code into an Arduino sketch properly, it will not be one gigantic file... it will be nicely organized in ten tabs.
Also, everywhere you've written
Is, in the original
    lcd.print(YES_OR_NOT);
I laughed when you called it "my code", as it is obvsly not. Except by tinkering with it, you have made it your own. As well as thoroughly breaking it as you evidently had some issues and made stabs at fixing them.
So...
Unzip the archive from the instructable.
In the archive folder that creates, make a new folder named
and move all ten (10) *.ino files in the archive folder into that new folder.
Now open the sketch called
HTH
a7
