Error: Programmer is not responding
I used two UNO R3's to flash an ATMEGA328p. Since then I have been unable to upload to the Arduino. I have put a fresh Arduino ATMEGA328p with boot loader preinstalled into the UNO R3 and I still get this error. I'm sure its a setting in the IDE software but I'm drawing blanks.
I have the UNO R3 connected to the PC using an Arduino usb lead. Its a fresh chip. I have tried others as well. I have a few here. The board LED's light up. I am trying to upload the blink example script. When I attempt the upload the RX LED blinks twice.
Any thoughts? :folded_hands:
Thankyou
Does it indicate that the upload was good
avrdude: 924 bytes of flash written
avrdude done.  Thank you.
No, It did, when it was working. Now this is what I get.
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\8.0.0-arduino1/bin/avrdude" "-CC:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\8.0.0-arduino1/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM3" -b115200 -D "-Uflash:w:C:\Users\User\AppData\Local\arduino\sketches\6F3F12918AA26446C2F24EBA8F76089A/Blink.ino.hex:i"
Avrdude version 8.0-arduino.1
Copyright see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
System wide configuration file is C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\8.0.0-arduino1\etc\avrdude.conf
Using port            : COM3
Using programmer      : arduino
Setting baud rate     : 115200
Error: programmer is not responding
Warning: attempt 1 of 10: not in sync: resp=0x00
Warning: attempt 2 of 10: not in sync: resp=0x00
User abort
Follow the troubleshooting process outlined here,
When I try pressing the reset button I don't get any blinks of the 'L' LED. Does this indicate an issue with the bootloader?
Yes, it should blink 3 times.
However, there may also be other problems with the board.
Try doing a loopback test
Is this an official Arduino Uno R3 or a clone?
fantastic, thankyou, thats what I needed.
It has passed the loopback test so that means corrupted bootloader. So I will work on re-uploading a boot loader. Last time I used an official UNO and a clone. But this time Ill use the official and a bread board.
I have and have tried both, but I am using an official UNO R3.
Probably but other problems could also cause the 328 from running and thus not running the bootloader.
oh, well I'll try again tomorrow and if it doesn't work I'll be back.
Thanks for you help :)
No hurry
