I'm super new to programming in general and need some help with this one. I recently got an uno r3 to play around with servos for an upcoming project I want to attempt and I've run into an issue. Previously, I was able to run code just fine and get my servo to respond appropriately, now all of a sudden I am getting this error message a few days later when testing different codes again:
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
Error: programmer is not responding
Warning: attempt 1 of 10: not in sync: resp=0x00
Error: cannot obtain SW version
Error: initialization failed (rc = -1)
- double check the connections and try again
- use -B to set lower the bit clock frequency, e.g. -B 125kHz
- use -F to override this check
Failed uploading: uploading error: exit status 1
I've been using Arduino IDE 2.3.10, the code that I ran to get that error was the default BareMinimum, I've tried unplugging and replugging, I double checked that I was using the correct board and port connections, when I press the reset button the little light next to "L" blinks a few times and stays lit. I'm not sure what else to do to fix it and I really hope it doesn't come down to needing to get a whole new board.
