'ERROR' responce for AT commands from A7672
Hello Experts,
I am trying to use SIMCOM A7672S module with ESP32 & I had connected everything properly with sufficient power supply.
The issue I have is that when I send any AT command from ESP32 to A7672S then I recieve 'ERROR' as responce...
Like I sent 'AT', then I gets ERROR as responce...
When I make a call from My mobile to A7672 then the A7672 shows incoming calls, but when I send 'ATA' to recieve the call then again I get responce 'ERROR'...
Please help me with my issue...
Thanks & Regards!!!
-SRJ
Since you’re getting incoming notification messages, I’d start looking at the serial data format. Typically 8N1
I changed the 'No LINE' Option in serial monitor to 'New LINE' & it started working...
I don't know what does mean but it worked...
Thanks for your valuable help..
Thanks & Regards!!!
-SRJ
