No funciona POST en Nodecu ESP8622, en el siguiente código:
La respuesta de response_code siempre es -1
Alguien puede ayudar para saber a qué se debe?
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#ifndef STASSID
#define STASSID "your-ssid"
#define STAPSK "your-password"
#endif
const char* ssid = "VI";
const char* password = "A33";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
// Define Static IP Setting
IPAddress ip(100,100,1,215);
IPAddress gateway(100,100,1,1);
IPAddress subnet(255,255,0,0);
//Variables used in the code
unsigned int Actual_Millis, Previous_Millis;
int refresh_time = 10000; //Refresh rate of connection to website (recommended more than 1s)
// prepare LED
pinMode(2, OUTPUT);
digitalWrite(2, 0);
// Connect to WiFi network
Serial.print(F("Connecting to "));
Serial.println(ssid);
WiFi.begin(ssid, password);
WiFi.mode(WIFI_STA);
WiFi.config(ip,gateway,subnet);
delay(10000);
Serial.print(F("."));
Serial.println(F("WiFi connected"));
// Start the server
server.begin();
Serial.println(F("Server started"));
// Print the IP address
//We make the refresh loop using millis() so we don't have to sue delay();
Actual_Millis = millis();
if(Actual_Millis - Previous_Millis > refresh_time){
Previous_Millis = Actual_Millis;
if(WiFi.status()== WL_CONNECTED){ //Check WiFi connection status
WiFiClient client;
HTTPClient http;
String dato = "hola" ;
http.begin(client,"http://www.httpbin.org/get"); //Indicate the destination webpage
http.addHeader("Content-Type", "application/x-www-form-urlencoded");
Serial.print("Dato a enviar : ");
Serial.println(dato);
int response_code = http.POST(dato); //Send the POST. This will giveg us a response code
String msgsrv = http.getString();
Serial.print("Respuesta POST : ");
Serial.println(response_code);
Serial.print("Respuesta del SRV : ");
Serial.println(msgsrv);
//If the code is higher than 0, it means we received a response
if(response_code > 0){
Serial.println("HTTP code " + String(response_code)); //Print return code
if(response_code == 200){ //If code is 200, we received a good response and we can read the echo data
String response_body = http.getString(); //Save the data comming from the website
Serial.print("Server reply: "); //Print data to the monitor for debug
Serial.println(response_body);
}//End of response_code = 200
}//END of response_code > 0
else{
Serial.print("Error sending POST, code: ");
http.end(); //End the connection
}//END of WIFI connected
else{
Serial.println("WIFI connection error");
