ESP8266 - Test POST Request Not Reaching the Server
I used the example code from the Arduino IDE and made just a few modifications. Based on the LED blinking, I can tell that the Wi-Fi connection was established correctly. However, my POST request is not being sent. Again, based on the LED blinking, it seems that the ESP is trying to send it, but there’s no error occurring.
I’m using an online service to test the request sending, which generates a URL that I can use for testing (https://webhook.site/).
Does anyone know what might be going wrong?
   PostHTTPClient.ino
    Created on: 21.11.2016
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#define SERVER_IP "https://webhook.site/fedbf703-b2e7-42a7-9d6d-c72a2441bd0d" //EXEMPLE
#ifndef STASSID
#define STASSID "SID"
#define STAPSK "PASSWORD"
#endif
pinMode(LED_BUILTIN, OUTPUT);
  WiFi.begin(STASSID, STAPSK);
  while (WiFi.status() != WL_CONNECTED) {                      // Wait for a second
    digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));  // Turn the LED off by making the voltage HIGH
    delay(300);
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected! IP address: ");
void piscaRapido(){
  digitalWrite(LED_BUILTIN, LOW);  // Turn the LED on (Note that LOW is the voltage level
  // but actually the LED is on; this is because
  // it is active low on the ESP-01)
  delay(300);                      // Wait for a second
  digitalWrite(LED_BUILTIN, HIGH);  // Turn the LED off by making the voltage HIGH
  delay(300);
  delay(300);
void piscaLento(){
  delay(1000);                      // Wait for a second
  // wait for WiFi connection
  if ((WiFi.status() == WL_CONNECTED)) {
    piscaRapido();
    WiFiClient client;
    HTTPClient http;
    Serial.print("[HTTP] begin...\n");
    // configure traged server and url
    http.begin(client, SERVER_IP);  // HTTP
    http.addHeader("Content-Type", "application/json");
    Serial.print("[HTTP] POST...\n");
    // start connection and send HTTP header and body
    int httpCode = http.POST("{\"hello\":\"world\"}");
    // httpCode will be negative on error
    if (httpCode > 0) {
      // HTTP header has been send and Server response header has been handled
      Serial.printf("[HTTP] POST... code: %d\n", httpCode);
      // file found at server
      if (httpCode == HTTP_CODE_OK) {
        const String& payload = http.getString();
        Serial.println("received payload:\n<<");
        Serial.println(payload);
        Serial.println(">>");
      Serial.printf("[HTTP] POST... failed, error: %s\n", http.errorToString(httpCode).c_str());
      delay(2000);                      // Wait for a second
    http.end();
  } else{
    piscaLento();
  delay(10000);
If you intend to use https, then you need WiFiClientSecure -- which usually requires extra setup (certificates, etc) -- instead of just WiFiClient. Otherwise, it is simpler to use http, which is of course not secure.
Your topic has been moved. Please do not post in "Uncategorized"; see the sticky topics in https://forum.arduino.cc/c/using-arduino/uncategorized/184.
PS
Thanks for using code tags in your first post.
Hello, thank you very much for the tip, it was really something quite simple, just changing the implementation library worked. Since it's just a test for now and I don't intend to send anything sensitive, I just used setInsecure() to make the client ignore the certificate validation and everything worked well.
I apologize for that, and thank you very much for the tip! :slight_smile:
