Hello everybody,
I'v got a couple of Arduino nano's which I am learning the basics on. I just started this whole arduino thing and grasp the basics.
Now I've get a 433mhz rx/tx set and a bit of simple code
#include <RH_ASK.h>
#include <SPI.h> // Not actualy used but needed to compile
#define relay 7
RH_ASK rf_driver;
RH_ASK driver(2000,6); //"2000" standaard snelheid, pin nummer
void setup(){
pinMode (relay, OUTPUT);
rf_driver.init();
void loop(){
uint8_t buf[1];
uint8_t buflen = sizeof(buf);
if (rf_driver.recv(buf, &buflen)) // Non-blocking
int i;
// Message with a good checksum received, dump it.
for (i = 0; i < buflen; i++)
int c = (buf[i]);
if (c==49){
digitalWrite(relay, HIGH);
else {
digitalWrite(relay, LOW);
Even though it looks like a mess (incorrect spacing, enters and placement of brackets and such) it works fine on my Nano!
Now I thought: this can be smaller, so I ot myself a Digispark. I tested this with my i2c lcd 16x2, printed a hello world, made a led blink, measured some temperature. all fine.
But when I want to upload above sketch it gives me an error....
Arduino:1.8.7 (Windows 10), Board:"Digispark (Default - 16.5mhz)"
In file included from c:\users\ten broeke\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5\avr\include\avr\io.h:99:0,
from c:\users\ten broeke\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.8.1-arduino5\avr\include\avr\interrupt.h:38,
from C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\cores\tiny/WProgram.h:8,
from C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\cores\tiny/Arduino.h:4,
from sketch\433mhz_RX__relais_activation.ino.cpp:1:
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h: In member function 'void SPISettings::init_AlwaysInline(uint32_t, uint8_t, uint8_t)':
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h:146:16: error: 'SPE' was not declared in this scope
spcr = _BV(SPE) | _BV(MSTR) | ((bitOrder == LSBFIRST) ? _BV(DORD) : 0) |
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h:146:27: error: 'MSTR' was not declared in this scope
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h:146:65: error: 'DORD' was not declared in this scope
In file included from C:\Users\Ten Broeke\Documents\Arduino\433mhz_RX__relais_activation\433mhz_RX__relais_activation.ino:2:0:
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h: In static member function 'static void SPIClass::beginTransaction(SPISettings)':
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h:203:5: error: 'SPCR' was not declared in this scope
SPCR = settings.spcr;
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h:204:5: error: 'SPSR' was not declared in this scope
SPSR = settings.spsr;
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h: In static member function 'static uint8_t SPIClass::transfer(uint8_t)':
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h:209:5: error: 'SPDR' was not declared in this scope
SPDR = data;
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h:217:14: error: 'SPSR' was not declared in this scope
while (!(SPSR & _BV(SPIF))) ; // wait
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h:217:25: error: 'SPIF' was not declared in this scope
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h: In static member function 'static uint16_t SPIClass::transfer16(uint16_t)':
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h:223:11: error: 'SPCR' was not declared in this scope
if (!(SPCR & _BV(DORD))) {
[i][u][b](there is loads more here but i cut it because my post length was over 9000 (ha-ha))[/b][/u][/i]
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h: In static member function 'static void SPIClass::detachInterrupt()':
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h:310:42: error: 'SPCR' was not declared in this scope
inline static void detachInterrupt() { SPCR &= ~_BV(SPIE); }
C:\Users\Ten Broeke\AppData\Local\Arduino15\packages\digistump\hardware\avr\1.6.7\libraries\SPI/SPI.h:310:55: error: 'SPIE' was not declared in this scope
exit status 1
Fout bij het compileren voor board Digispark (Default - 16.5mhz)
It is quite a bit of error... and I have no clue what it means! Who could shed some light on this?
It seems to bog down on the spi library, but i wouldnt know how to fix this ![]()
Kind regards,
Tim
