Error uploading to arduino mega
I'm trying to upload a code to arduino, but it always gives the same error. When I use arduino uno it sends the code normally, but when I try with Arduino mega it doesn't work, I've tried with two Arduino Mega boards, on two different computers, but it didn't work. The error is as follows:
Arduino: 1.8.19 (Windows 10), Placa:"Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)" O sketch usa 2692 bytes (1%) de espaço de armazenamento para programas. O máximo são 253952 bytes. Variáveis globais usam 186 bytes (2%) de memória dinâmica, deixando 8006 bytes para variáveis locais. O máximo são 8192 bytes. avrdude: ser_open(): can't set com-state for "\\.\COM6" avrdude: ser_drain(): read error: Identificador inv lido. avrdude: ser_send(): write error: sorry no info avail avrdude: stk500_send(): failed to send command to serial port avrdude: ser_recv(): read error: Identificador inv lido. avrdude: stk500v2_ReceiveMessage(): timeout avrdude: ser_send(): write error: sorry no info avail avrdude: stk500_send(): failed to send command to serial port avrdude: ser_recv(): read error: Identificador inv lido. avrdude: stk500v2_ReceiveMessage(): timeout avrdude: ser_send(): write error: sorry no info avail avrdude: stk500_send(): failed to send command to serial port avrdude: ser_recv(): read error: Identificador inv lido. avrdude: stk500v2_ReceiveMessage(): timeout avrdude: ser_send(): write error: sorry no info avail avrdude: stk500_send(): failed to send command to serial port avrdude: ser_recv(): read error: Identificador inv lido. avrdude: stk500v2_ReceiveMessage(): timeout avrdude: ser_send(): write error: sorry no info avail avrdude: stk500_send(): failed to send command to serial port avrdude: ser_send(): write error: sorry no info avail avrdude: ser_recv(): read error: Identificador inv lido. avrdude: stk500v2_ReceiveMessage(): timeout avrdude: ser_send(): write error: sorry no info avail avrdude: stk500_send(): failed to send command to serial port avrdude: ser_recv(): read error: Identificador inv lido. avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_getsync(): timeout communicating with programmer Este relatório teria mais informações com "Mostrar a saida detalhada durante a compilação" opção pode ser ativada em "Arquivo -> Preferências"
Did you select the Mega in the Tools menu?
Yes
Please select the "all error" option for uploads in the Settings, and post the entire error message verbatim.
This one?
C:\Users\guilh\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\guilh\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM6 -b115200 -D -Uflash:w:C:\Users\guilh\AppData\Local\Temp\arduino_build_676470/Sistema_de_Registros.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\guilh\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
avrdude done.  Thank you.
Ocorreu um erro enquanto o sketch era carregado
Which version of Arduino Mega are you using? Does your board have the CH340 USB to TTL converter chip?
Thanks for that. When you plug it into the PC, is it visible as USB serial device in the device manager (assuming Windows)?
When I connect it appears with the name: USB-SERIAL CH340 (COM6)
It has a CH340 office chip
Have you installed the CH340 driver software?
yes
