Hello, I am unable to upload any sketches to my arduino mega. I've used to board without any problems before. When uploading it compiles, and the progress bar indicating updating reaches the end but never stops and I am given an error. I've looked at forums but not found any solutions that work. Any help would be much appreciated. Below I've pasted the error.
Sketch uses 1462 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
C:\Users\ehardwick\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\ehardwick\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM1 -b115200 -D -Uflash:w:C:\Users\ehardwick~1\AppData\Local\Temp\arduino_build_199128/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\ehardwick\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM1
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
An error occurred while uploading the sketch
