I've tried with HttpClient and I couldn't either, now I'm trying with <WiFiClientSecure.h>
But it is returning Bad Request 400
Does anyone know how I could try to make this POST request successfully?
I want to send the photo.png to the API
const char* host = "api.ocr.space";
void conectasecure() {
WiFiClientSecure client;
client.setInsecure();
if (client.connect(host, 443)) {
url = "http://api.ocr.space/parse/image";
photo = "http://i.imgur.com/fwxooMv.png";
client.println("POST" + url + "HTTP/1.1");
client.println("Host:" + String(host));
client.println("apikey:K873541123456789");
client.println("Content-Type:multipart/form-data");
client.print(photo);
long int tempo_inicio = millis();
while (!client.available()) {
Serial.print(".");
delay(100);
if ((tempo_inicio + tempo_espera) < millis()) {
Serial.println("Sem Resposta.");
while (client.available()) {
Serial.print(char(client.read()));
Serial.println("A conexão ao " + String(host) + " FALHOU ");
client.stop();
When you looked at the log files of the web server, what is the error message being reported when your project makes a request?
This:
HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Thu, 16 Feb 2023 13:40:06 GMT
Connection: close
Content-Length: 326
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request - Invalid Verb</h2>
<hr><p>HTTP Error 400. The request verb is invalid.</p>
</BODY></HTML>
Your POST request is not a valid request
In HTTP context, the multipart/form-data content-type is used for submitting HTML form. In the case of multipart/form-data, as the name suggests the body consists of different parts separated by a delimiter or...
Est. reading time: 4 minutes
I put this empty line at the end of the request and it no longer returns an error, but it does not return anything, not even code 200
client.println("");
I tried again with HttpClient.h because it is simpler for my little knowledge. But it has always insisted on not recognizing the png photo format. It gives error 99.
I tried to create and add another filetype header, but not so
If it's via GET it works like a charm.
String url = "http://api.ocr.space/parse/image";
void conecta() {
HTTPClient http;
http.begin(url);
http.addHeader("apikey", "K87354123456789");
http.addHeader("Content-Type", "Content-Type: image/png");
http.addHeader("File-Type", "filetype: png");
String httpRequestData = "http://i.imgur.com/fwxooMv.png";
int httpResponseCode = http.POST(httpRequestData);
if(httpResponseCode > 0){
String response = http.getString();
Serial.println(httpResponseCode);
Serial.println(response);
Serial.print("Error on sending POST: ");
http.end();
delay(5000);
ERROR
200
{"OCRExitCode":99,"IsErroredOnProcessing":true,"ErrorMessage":["Unable to recognize the file type","Unable to detect the file extension, or the file extension is incorrect, and no 'file type' provided in request. Please provide a file with a proper content type or extension, or provide a file type in the request to manually set the file extension."],"ProcessingTimeInMilliseconds":"0"}
Using this works. But how to transform it into a request in HttpClient.h ?
Dissatisfied, I changed the API, because I'm just testing out of curiosity, it's not a job. I am learning.
But it's amazing how even in this other API the image that I try to send by URL is also not recognized
void posthttp() {
url = "https://api.z-api.io/instances/3B90F2295A2E30DSHGDS7848J5F/token/0966E05GKJGJKGHHTR45/send-image";
phone = "552294656878";
token = "0966E5897554785rkrD26523C";
image = "https://i.imgur.com/fwxooMv.png";
if(autorizaenvio == 0) {
if(WiFi.status()== WL_CONNECTED){ //Check WiFi connection status
HTTPClient http;
http.begin(url);
http.addHeader("phone", phone);
http.addHeader("image", image);
http.addHeader("Content-Type", "image/png");
int httpResponseCode = http.POST(url);
if(httpResponseCode>0){
} else{
http.end();
} else{
Serial.println("Error in WiFi connection");
} autorizaenvio = 1;
Does anyone have any ideas ?
Thanks
