I am working with the ESP32-Cam, I have been able to get it online and capture an image. What I want to do now is pass that along to a REST webservice with the image and the data. I have been trying to solve this for 3 days now and have finally thrown my hand up. I have tried many different variations, i cannot seem to figure out why the server claims the request is bad. I am in the process of trying to figure out WireShark to see if that offers any additional insight.
Here is most of everything i know so far, i hope someone is able to help.
myhost.com is fake, i replaced the host that was in there in order to post online, i am able to connect to the web server, the server access log shows this each time I attempt to post:
[06/Mar/2020:00:25:35 +0000] "POST /api/image/add HTTP/1.1" 400 762
I have tested the webservice in PostMan, This is what is shows as the code output for HTTP:
Host: myhost.com:8443
Content-Type: multipart/form-data; boundary=----WebKitFormBoundary7MA4YWxkTrZu0gW
Content-Disposition: form-data; name="serialNumber"
1234-5687-1234-5678
Content-Disposition: form-data; name="imageData"; filename="photo.jpg"
Content-Type: image/jpeg
(data)
This is the function i have to upload the image along with the serial number
bool upload() {
WiFiClientSecure client;
if (WiFi.status() != WL_CONNECTED) {
Serial.println("WiFi Not connected!");
return false;
Serial.println("Connecting to portal...");
if (!client.connect("myhost.com", 8443)) {
Serial.println("Connection to portal failed!");
return false;
Serial.println("Posting image ...");
client.println("POST /api/image/add HTTP/1.1");
client.println("Host: myhost.com:8443");
client.println("Content-Type: multipart/form-data; boundary=--7MA4YWxkTrZu0gW");
client.println("Connection: keep-alive\r\n");
client.println("--7MA4YWxkTrZu0gW");
client.println("Content-Disposition: form-data; name = \"serialNumber\"\r\n");
client.println("1234-5687-1234-5678");
client.println("Content-Disposition: form-data; name=\"imageData\"; filename=\"photo.jpg\"");
client.println("Content-Type: image/jpeg\r\n");
//Send actual image
Serial.println("(data)");
File file = SPIFFS.open(FILE_PHOTO);
//send using buffer
while (file.available()) {
int nextPacketSize = file.available();
if (nextPacketSize > 1350) {
nextPacketSize = 1350;
String buffer = "";
for (int i = 0; i < nextPacketSize; i++) {
buffer += (char)file.read();
client.print(buffer);
client.println("\r\n--7MA4YWxkTrZu0gW--");
file.close();
client.print("\r\n");
Serial.println("Response:");
while (client.connected()) {
if (client.available()) {
String response = client.readStringUntil('\n');
Serial.println(response.c_str());
Serial.println("");
client.stop();
Serial.println("Connection closed");
return true;
This is the response i get:
HTTP/1.1 400
Content-Type: text/html;charset=utf-8
Content-Language: en
Content-Length: 762
Date: Fri, 06 Mar 2020 00:25:35 GMT
Connection: close
<!doctype html><html lang="en"><head><title>HTTP Status 400 – Bad Request</title><style type="text/css">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;background-color:#525D76;} h1 {font-size:22px;} h2 {font-size:16px;} h3 {font-size:14px;} p {font-size:12px;} a {color:black;} .line {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP Status 400 – Bad Request</h1><hr class="line" /><p><b>Type</b> Status Report</p><p><b>Description</b> The server cannot or will not process the request due to something that is perceived to be a client error (e.g., malformed request syntax, invalid request message framing, or deceptive request routing).</p><hr class="line" /><h3>Apache Tomcat/9.0.30</h3></body></html>
I turned on the ESP logging level 5, this is what i get out of the serial console window
Taking a photo...
The picture has been saved in /photo.jpg - Size: 3328 bytes
Uploading
[V][ssl_client.cpp:56] start_ssl_client(): Free internal heap before TLS 201252
[V][ssl_client.cpp:58] start_ssl_client(): Starting socket
[V][ssl_client.cpp:93] start_ssl_client(): Seeding the random number generator
[V][ssl_client.cpp:102] start_ssl_client(): Setting up the SSL/TLS structure...
[I][ssl_client.cpp:156] start_ssl_client(): WARNING: Use certificates for a more secure communication!
[V][ssl_client.cpp:180] start_ssl_client(): Setting hostname for TLS session...
[V][ssl_client.cpp:195] start_ssl_client(): Performing the SSL/TLS handshake...
[V][ssl_client.cpp:216] start_ssl_client(): Verifying peer X.509 certificate...
[V][ssl_client.cpp:225] start_ssl_client(): Certificate verified.
[V][ssl_client.cpp:240] start_ssl_client(): Free internal heap after TLS 160948
[V][ssl_client.cpp:279] send_ssl_data(): Writing HTTP request...
(data)
Response:
HTTP/1.1 400
Content-Length: 762
Connection: close
[V][ssl_client.cpp:248] stop_ssl_socket(): Cleaning SSL connection.
