I am not so good at coding, but I am trying to make my Arduino play a sound when you hit a certain button on an IRremote! I am using the <IRremote.h> library.
The problem is that It always gives me an error when I compile it.
using the buzzer itself works, and the IR part works as well when I try it secretly. I have had the same problem with the use of the <Ping.h> library
If you have any suggestions that would be great!
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Read the how to use this forum-please read sticky to see how to properly post code. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
Without seeing your code and the errors that it generates, we have to rely on our crystal balls to try and give an answer. Mine is not working well this morning. It is most likely a timer conflict but can't be sure without more info.
There are likely to be conflicts between the libraries over use of internal timers.
Always check the Arduino reference pages for the functions you intend to use.
Thanks for getting back so quickly! here is the error
Using library irremote_2_6_1 at version 2.6.1 in folder: /home/builder/opt/libraries/latest/irremote_2_6_1
Tone.cpp.o (symbol from plugin): In function `timer0_pin_port':
(.text+0x0): multiple definition of `__vector_7'
/tmp/247143052/build/libraries/irremote_2_6_1/IRremote.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2: error: ld returned 1 exit status
exit status 1
Check out this thread that I found with a search for "arduino tone irremote".
That is unsurprising, and almost certainly due to a timer resource conflict between libraries.
