Error while accessing RTC from an ISR
Hello!
I recently got this great adafruit shield which has an RTC on board. The RTC communicates using I2C (analog 4 and 5 on my arduino uno), and it uses this library.
I am trying to make the RTC work. If i try to access it (using RTC.now()) from loop() it works as expected. However, I would like to be able to get a DateTime object in the ISR, to know if I should wake up the processor just yet. If I try to use RTC.now() from the ISR the program hangs permanently.
I have shortened my code so you can see the problem. If the "DateTime dt = RTC.now()" line in the ISR is commented, there is no hang.
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 RTC;
void timerOneInit(){
  cli();
  TCCR1A = 0;// set entire TCCR1A register to 0
  TCCR1B = 0;// same for TCCR1B
  TCNT1  = 0;//initialize counter value to 0
  OCR1A = 65535;// = (16*10^6) / (1*1024) - 1 (must be <65536)
  // turn on CTC mode
  TCCR1B |= (1 << WGM12);
  // Set CS10 and CS12 bits for 1024 prescaler
  TCCR1B |= (1 << CS12) | (1 << CS10);
  // enable timer compare interrupt
  TIMSK1 |= (1 << OCIE1A);
  sei();
//called when timer one overflows
ISR(TIMER1_COMPA_vect){
  Serial.println("Timer one");
  Serial.flush();
  DateTime dt = RTC.now();
void setup(){
  init();
  while(!Serial) ;
  Serial.println("Serial Initialized!");
  Wire.begin();
  RTC.begin();
  if(!RTC.isrunning()){
    Serial.println("RTC is trying to set up...");
    RTC.adjust(DateTime(__DATE__, __TIME__));
  Serial.flush();
  timerOneInit();
void loop(){
Why is this happening, and how can i fix it?
Thanks!
Interrupts are disabled in an ISR. Serial.print and I2C use interrupts. Move that code from the ISR to an if block in loop(). Set a flag in the ISR, check the flag in loop() and run the code if the flag is set, then clear the flag.
okay i got it! Thank you for the explanation
