Hello everyone! I am using WeMos D1 R1 for my project. I copied an example, and I was trying to verify and upload it. I get the error message saying "Error compiling for Board WeMos D1 R1.
Arduino: 1.8.12 (Mac OS X), Board: "WeMos D1 R1, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
fork/exec /Users/sarthpatel/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3: no such file or directory
Error compiling for board WeMos D1 R1.
option enabled in File -> Preferences.
<void setup() {
pinMode(LED_BUILTIN, OUTPUT); // Initialize the LED_BUILTIN pin as an output
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is active low on the ESP-01)
delay(1000); // Wait for a second
digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
delay(2000); // Wait for two seconds (to demonstrate the active low LED)
I copied your code (below), and it compiles and runs on my WeMOS D1 development board, blinking the LED. Note that I'm using IDE 1.8.10 on a windows 10 machine.
The problem is the ESP8266 platform has a tool dependency on Python 3, but rather than installing a dedicated copy of Python 3 with the package, the ESP8266 platform developers assume you have Python 3 already installed at /usr/local/bin/python3.
The python3 file at the path shown in the error message is just a symlink to that location. So either you have Python 3 installed somewhere else, like /usr/bin/python3, or maybe you don't have Python 3 installed at all. If the former, you need to modify the symlink, as described here. If the latter, you need to install Python (and possibly modify the symlink as well if it was installed to a location other than /usr/local/bin/python3.
