I have started to get myself familiar with arduino, and have tried to use a WEMOS D1 Board (Model:v210) with an ESP8266 built in.
I installed the esp8266 board from: http://arduino.esp8266.com/stable/package_esp8266com_index.json
and selected the "Generic ESP8266 Module"
Computer: Windows 10 64x Surface Book 2
I have simply connected the WEMOS to my computer on USB-SERIAL CH340.
I am uploading a simple test code (blink):
The error message I am getting when trying to upload is:
esptool.py v2.7
Serial port COM3
Traceback (most recent call last):
File "C:\Users\Loznero\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0/tools/upload.py", line 25, in
esptool.main(fakeargs)
File "C:/Users/Loznero/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 2840, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "C:/Users/Loznero/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 237, in init
self.port = serial.serial_for_url(port)
File "C:/Users/Loznero/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/pyserial\serial_init.py", line 88, in serial_for_url
instance.open()
File "C:/Users/Loznero/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/pyserial\serial\serialwin32.py", line 62, in open
raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port 'COM3': FileNotFoundError(2, 'The system cannot find the file specified.', None, 2)
This is my first time posting, so if I have made anything unclear please let me know!
Thank you in advance.
I understand now. I'm surprised you don't already have one on hand.
I'm not sure what the best keywords are. I would expect that if it specifically says "data" then it will be good. Probably it's best to avoid any that mention "charging". I got burned from buying a charge-only USB cable on eBay from a listing that didn't at all make it clear it wasn't for data. That caused me a few minutes of head scratching, as I hadn't heard about the charge-only cables at that time. So it is easy to accidentally buy the wrong type.
